Onoff Posted May 18, 2021 Share Posted May 18, 2021 9 minutes ago, pocster said: Yep . When I bought the wc and frame it didn’t cross my mind to check the cost of the flush plates . I recon @Onoff could print them and make zillions ! I shopped around and got my two Geberit flush plates (Kappa 20 Chrome Gloss) for around the £25 - 30 off of I think eBay & an end of line place. Both bnib. Need another one. There's a few Geberit spares can be found and 3D printed from Yeggi. 1 Link to comment Share on other sites More sharing options...
AliG Posted May 18, 2021 Share Posted May 18, 2021 (edited) We have Noken/Porcelanosa concealed cisterns which as far as I can see are exactly the same as the Geberit ones. The push fit for the water connection to the pan is the weak point. One of our WCs was installed with this leaking. We kept saying we could smell something, the builder said it was fine until flies appeared! It shouldn't move after it has been installed but it definitely can be installed incorrectly and leak. We also had one installed incorrectly in our last house. The builder mounted it behind the studwork instead of inline with the studs and the same pipe leaked through the ceiling. All these cisterns look nigh on identical to me and I have wondered if the flush plates are interchangeable. I think Grohe and Geberit are a different size, but maybe between Geberit and Noken. I ended up paying for some of the Noken glass ones as I don't like the plastic chrome ones, but in the end they aren't as bad as I thought and better at £25 versus well over £100. Edited May 18, 2021 by AliG Link to comment Share on other sites More sharing options...
Adsibob Posted May 18, 2021 Author Share Posted May 18, 2021 4 minutes ago, AliG said: The push fit for the water connection to the pan is the weak point. This is what a friend warned me about. He said the Geberit ones are easier to install incorrectly for some reason and steered me towards Grohe. Not sure if that is everyone's experience though. Odd why they make it push fit, which is surely more likely to be installed incorrectly, compared to regular screw fit. Link to comment Share on other sites More sharing options...
AliG Posted May 18, 2021 Share Posted May 18, 2021 (edited) Having looked at a video just now the Grohe ones seem to use exactly the same kind of push fitting. All three seem to use exactly the same connecting pipes. I was a bit nervous, but we have 9 of them and they have all been fine for three years now. Just keep an eye on them when first installed. Edited May 18, 2021 by AliG Link to comment Share on other sites More sharing options...
AliG Posted May 18, 2021 Share Posted May 18, 2021 You can save a lot on some of this stuff buying from here in Europe. https://www.skybad.de/en/k/frame-and-cistern.html As they all seem the same I would just use Geberit which is quite a bit cheaper. Link to comment Share on other sites More sharing options...
Adsibob Posted June 17, 2021 Author Share Posted June 17, 2021 So my saga of a search for the right toilet frame and flush plate has almost come to a close. I'm most likely going to go for: Grohe Rapid SL frames bought here in the UK and order flush plates from Europe (as was suggested by @Temp on this thread) One that that surprised me though is that the same product appears to have drastically different warranty period depending on where bought from. The 1.13m SL Rapid frame and cistern comes with a 12 month warranty, or a 5 year warranty, or a 10 year warranty. Contrast this builderdepot product listing versus this victorianplumbing one. Can anyone explain this? Is the customer really being asked to choose to spend more to get the 10 year warranty, or is this just a mistake on the builderdepot site? 1 Link to comment Share on other sites More sharing options...
Temp Posted June 17, 2021 Share Posted June 17, 2021 (edited) Would be interesting to see what the small print on the warranty says. In my limited experience ... Geberit Fames will easily last 10 years. I've had flush valves fail after 4 years. The chrome plating on the flush plate buttons can also wear through in 4 years. Edited June 17, 2021 by Temp Link to comment Share on other sites More sharing options...
Adsibob Posted June 17, 2021 Author Share Posted June 17, 2021 8 minutes ago, Temp said: Would be interesting to see what the small print on the warranty says. In my limited experience ... Geberit Fames will easily last 10 years. I've had flush valves fail after 4 years. The chrome plating on the flush plate buttons can also wear through in 4 years. I’m not worried about the frames themselves. It’s all the moving bits inside that can eventually fail and cause leaks. Link to comment Share on other sites More sharing options...
Temp Posted June 17, 2021 Share Posted June 17, 2021 Now you remind me we did have a problem with the flush pipe on our Geberit cistern. The rubber seal degraded and the whole joint became loose and leaked but I think they have changed the design now.. Link to comment Share on other sites More sharing options...
Adsibob Posted June 17, 2021 Author Share Posted June 17, 2021 1 hour ago, Temp said: Now you remind me we did have a problem with the flush pipe on our Geberit cistern. The rubber seal degraded and the whole joint became loose and leaked but I think they have changed the design now.. This is why I decided to go for Grohe instead. Difficult to know which geberit models suffer from that problem and which ones don’t. Link to comment Share on other sites More sharing options...
VapourSnow Posted August 7, 2021 Share Posted August 7, 2021 On 04/04/2021 at 13:11, Adsibob said: Well both actually. For most of our toilets I want them wall hung, but we don’t have the thickness in the wall to do this with one toilet, so for that the pan will be floor mounted, but if possible I’d still like to conceal the cistern. How much wall thickness do I need just to conceal the cistern? We had the same challenge with a wall hung pan against an internal stud walls. We have used steel (Unistrut) inside the wall to support a Geberit frame without increasing the wall thickness. Not finished yet ? I mention this in case it may be helpful. Thanks Craig Link to comment Share on other sites More sharing options...
SuperJohnG Posted November 8, 2022 Share Posted November 8, 2022 On 17/06/2021 at 17:59, Adsibob said: So my saga of a search for the right toilet frame and flush plate has almost come to a close. I'm most likely going to go for: Grohe Rapid SL frames bought here in the UK and order flush plates from Europe (as was suggested by @Temp on this thread) I need to buy these now. Did you you buy the grohe ones? Also would be good to know about the flush plates too. Thanks Link to comment Share on other sites More sharing options...
Adsibob Posted November 8, 2022 Author Share Posted November 8, 2022 9 hours ago, SuperJohnG said: I need to buy these now. Did you you buy the grohe ones? Also would be good to know about the flush plates too. Thanks Yes, I went with Grohe for all but one bathroom, which has Vitra. That was because i wanted a matt black flush plate for that bathroom and Vitra did them for a mere £30. Seems to work ok, though it's probably only used at most once a day as not a main use toilet. Flush plate has nice matt finish to it which does not show finger print marks. I would avoid anything that is shiny, as it shows fingerprint marks. Of the grohe plates, some are shiny and really do show finger print marks, whereas some are not like their supersteel range. Even their cool sunrise, which is described as "brushed" is actually shiny. Link to comment Share on other sites More sharing options...
Temp Posted November 8, 2022 Share Posted November 8, 2022 (edited) The Geberit frames and the cisterns that come with them are fine but we had issues with their regular concealed cistern. As per the OP post there was an issue with the flush pipe where it exited the Cistern. It leaked and could have caused a big flood because when the level dropped it opened the fill valve. This is how loose the fitting was when I took it out... https://youtu.be/t8Qvs-VkPBk Edited November 8, 2022 by Temp Link to comment Share on other sites More sharing options...
Nickfromwales Posted November 8, 2022 Share Posted November 8, 2022 Geberit every single time for me! Never been let down, and the flush pipes are all single piece moulded items too, so no leaks there, ever. Link to comment Share on other sites More sharing options...
trialuser Posted November 8, 2022 Share Posted November 8, 2022 (edited) 1 hour ago, Temp said: The Geberit frames and the cisterns that come with them are fine but we had issues with their regular concealed cistern. As per the OP post there was an issue with the flush pipe where it exited the Cistern. It leaked and could have caused a big flood because when the level dropped it opened the fill valve. This is how loose the fitting was when I took it out... https://youtu.be/t8Qvs-VkPBk Whats happened to youtube, I had to watch a 20 second ad to watch a 13 second video! Crazy!! Edited November 8, 2022 by trialuser 1 Link to comment Share on other sites More sharing options...
markc Posted November 8, 2022 Share Posted November 8, 2022 1 hour ago, trialuser said: Whats happened to youtube, I had to watch a 20 second ad to watch a 13 second video! Crazy!! They want you to sign up and pay monthly to be ad free Link to comment Share on other sites More sharing options...
Gone West Posted November 8, 2022 Share Posted November 8, 2022 1 hour ago, trialuser said: Whats happened to youtube, I had to watch a 20 second ad to watch a 13 second video! Crazy!! https://www.telegraph.co.uk/technology/2022/10/25/google-shares-drop-youtube-suffers-first-ever-fall-advertising/ Link to comment Share on other sites More sharing options...
Temp Posted November 8, 2022 Share Posted November 8, 2022 I usually read the comments while waiting for the ads to end. I expect they will stop that soon. Link to comment Share on other sites More sharing options...
