Hi all
trying to use the endless downtime waiting for planning to pick my cladding and windows etc  — please excuse my ramblings but appreciate if anyone has been through similar thoughts
We are going for a contemporary look with thin vertical Timber cladding and likely grey or black windows. My architect has steered me towards aluminum windows and Smart Aluminium being his recommendation so I’ve started looking here first,  They do indeed have many profiles and in particular a flush version ( Alitherm 500) we like).
https://www.smartsystems.co.uk/product/508/alitherm-500
Trouble is many of them are listed as having frame suggested  UValues of 1.3-1.6. I’m aware the building regds enforce 1.4 as the minimum -  The window sales person has mentioned this overall UValue can’t be brought down seemingly to any value required depending on the glass.  I’m a little suspicious here but does anyone know what kind of calculation is used to calc overall window UValue once you add glass of a certain spec.
Now I’ve read many posts and alu clad Timber seems to be many people’s choice and I’m guessing this is for the improved UValues.which I see are down into the 0.5-0.8 area. I’ve many more to look at (Rationel, Velfac,, etc) but From my initial look at idealCombi the sighlines do seem reasonable (53mm) which fit my modern brief but the frame depth seems huge ( I guess the strength comes from somewhere). We not fans of the dual colorings so the view of the windows at a slight angle shows the all important frame depth which is putting me off
I’m also becoming increasingly aware when doing a self build how you can get carried away trying to hit and beat numbers - yes keen to be energy efficient and have no SAP/BC issues but also aware how good is good enough.  Seems pointless to spend a fortune if the payback is a few pounds a year or repayment beyond my lifetime (Sorry Environment I’m trying but there is a limit) -  Appreciate any thoughts
thanks
Dan
Take a good look at Rationel aluminium clad timber windows (Aura plus)  Lots of people on here happy with them nice simple frame profiles, and when i got quotes they were the cheapest of the 5 that bothered to quote.
I have used Smart Systems in the past.  You could look at Raynaers and Schuco as well.  These are mostly all ali products
IdealCombi, Velfac and Rationel are all from the Dovista group.  Rationel are the most favoured by installers I know who do all 3.  They are mostly all ali clad / composite products.
Expand
When I was getting quotes first time round A lot are not keen on self install Or didn’t quote bother to quote for Something  that was 12 months down the line
Where Ratiobel ok with self install
Just remember one thing.
The frame value is generally always the worst aspect, suppliers will compensate with a good Ug (glass) value to make it better.
However, your still left with a poor Uf (frame value). Just because the overall Uw changes as a result, it does not mean your getting a “fantastic” product.
Aluminium windows will generally struggle to get frame values below 1 unless your looking at the certified systems.
Edited by craig
Appreciate your thoughts
am I right in thinking any of the thinner Ali clad windows ( frame width/sight lines) will therefore have a significant wooden inner frame (depth) than pure Ali?
the wife isn’t keen on black/ grey frames and white interiors so this leaves me with chunky black/grey wood inside which so far I’m not keen on!
Assuming I can get the Smart Ali down to 1.3 (maybe lower) with better glass in real terms am I going to notice a difference with a 0.8 window?  Appreciate lower is always better but at what point is it noticeable...... i know BR was 1.6 max previously so is 1.3 so bad - anyone else less worried about the window UV compared to the walls - I don’t have huge glass expanses
thanks
Expand
Thanks yes this was my guess and I may be OK accepting the overall value isn’t as good as it could be to suit the aesthetics.
Would you recommend a target overal value to target that A) meets Building Regs and B) is better that large home builders would target for a budget perspective but low enough to make a noticeable difference and where quality/ feel starts? -    Appreciate very subjective!
Also,  any idea how the overall UValue is calculated when better glass is added to a lesser frame? Window supplier may say X but I guess it’s me that faces off to building inspector so keen to know!
Head is spinning with options and haven’t even seen the costs yet which I’m sure will be a huge discussion factor!!!!!
thanks again
The Alitherm 500 is pretty poor in terms of insulation.  It can only achieve a Window Energy Rating of B and I guess this is for a large window with high spec glazing.
Comparing window u values is difficult as it is dependant on the glazing and the window size.  They should really give you the value for the frame (Uf).  Smarts are a bit naughty and give you a U value for a window including glazing.
Have a look at https://www.reynaers.co.uk/en-UK/product-selector-0 and you can have a play with various options for frame style, function, energy efficiency etc. They are open about their Uf values.
Expand
Yes definitely.  It was actually the builders that built the timber frame that installed them for me.
Expand
It's UW value for each window that goes into the SAP calculations, that is all you need to worry about.
Expand
That’s good to know Dave Rationel
look really smart
Also we will spend the extra money for 3G that wasn’t an option last time
The window manufacturers need to pull their fingers out imo and sort this issue.
Catnic have already done it - I'm having these (thermally broken metal lintels) and I don't see why the window manufacturers couldn't do similar. The first to do so won't be able to make them fast enough I expect...
Edited by Matt60
Decent window manufacturers will give the Uwindow value (for the whole unit). See also BFRC website for energy rating of windows.
We're going for 3g Internorm alucald PVC units, from my research best compromise of performance, looks and cost. We're going for a very light silver colour on the outside, and the standard white PVC on the inside. We both agree that dark grey has been done enough.
Our worst unit is about 0.8 (small bathroom), and the best are under 0.7.
Expand
Who is providing your windows?
3 years since we ordered ours and Internorm were the best option for us also.
Expand
To be fair to smart they just make the profiles for other window companies  - ali fenestrations I think they call it
