Extension works are underway and my builders will start the brick laying in about 2-3 weeks. I need to order the bricks and have only just found out that the bricks we were going to go with might not be available in the special "dogleg" shape that helps with laying bricks over a 45 degree angle. I have two 45 degree angles on my project so it's quite important we get this right. Are there any structural/damp/longevity issues to consider or is this purely an aesthetic choice? I've uploaded some photos of the different options, as I understand them to be.
IF you cant get the bricks you want in squints, then could you get some contrasting squints to make a feature of it?
We had the second picture at a previous house
They had been payed for over 30 years Can’t remember there being any issues
The top one looks better but more cost
3 minutes ago, ProDave said:
On a bay window (so only a small job) the builder just cut the end off every brick at the correct angle.
I have two angles, so I think that would be about 160-200 cuts. Quite a lot of cutting!
Depending on how many you need you can get them cut and glued from any stock brick. Had to do this on non standard bay windows before, search for brick bonding in your area. Think we paid about £2.20 each but supplied the bricks. Be aware to get the proper bond you need two bricks per corner.
You can do it yourself but you need a brick table to cut them not a stihl saw, and then bond them
with this stuff.
https://www.epoxy-info.co.uk/resins_shop.htm#ThixoRapid
Cut to the correct angle then let them dry and glue. Leave them for 48 hours if possible to set.
Thanks @nod but with the top style, isn't there less brick between the inside and the outside at that corner. Won't it diminish the U value of the wall? Also, why do you say the top one is more cost?
2-3 weeks might be short notice for some standard bricks. Suggest you check if not done already.
Edited by Temp
with this stuff.
Do you have  a pic of the finished look by any chance?
I wouldn’t have thought so
Sorry I meant the bottom pic
special order brick
You beat me to it, ? Cut the back off so the face is good.
Edited by joe90
Not entirely sure if that's achievable. The facing brick is cuboidal so it only has right angles. Unless I'm really clueless with 3D visualisation (which may well be the case!) there is no way of creating a 45 degree angle by cutting it without exposing the inside of the brick.
Also, I'm a bit concerned these bricks won't cut too cleanly. Just unwrapping the bubble wrapped dozen the manufacturer sent me so that I could play try different mortar colours with them, some of the edges have already crumbled off. Is that normal? It's a sand faced brick, not sure if that changes anything.
@Adsibob you cut the brick to a point so the cut face buts up to the next brick. Easy done but the downside is there is no overlap between courses and you get a mortar join up the corner that can look untidy. That’s why squints or bonded bricks are best.
You’ll only do this once so saving £3-400 on this will be something you’ll look at for a lifetime.
+1 to getting them cut and glued.  Get them handed so they are layed the same way up.
Sometimes the specials - like squints - come out a different colour and are more expensive.
