Boris Posted April 30, 2020 Posted April 30, 2020 We have purchased an Ashton and Bentley ISIS bath. It weighs 82kg. One of our plumbers is jittery about Covid 19 and doesn't want a 3rd person helping to move it, the plumbers have moved heavier baths. At the current time we have a narrow temporary staircase, but I cannot see this as being an issue as a 150kg Juliet balcony went up there with two men at the bottom and one at the top. Any hints or suggestions please.
Ferdinand Posted April 30, 2020 Posted April 30, 2020 (edited) Check your insurance policy and leave them to it. Be out of earshot. Others may have a different view. Edited April 30, 2020 by Ferdinand
Jeremy Harris Posted April 30, 2020 Posted April 30, 2020 Welcome. I can understand the issue, as I believe the safe lifting load limit is normally restricted to 25kg per person (under the Manual Handling Regs). There is a solution, though, and that's to hire an electric stair climber. These come in a wide range of sizes and can shift loads fairly easily and safely up and down stairs. Most bigger hire shops have electric stair climbers, and probably worth looking into, if only from the peace of mind one of these would give, over the risk of damage from manual lifting. This is one around the right size: https://www.speedyservices.com/71_6010-h-stair-climber-powered-310kg-swl
BotusBuild Posted April 30, 2020 Posted April 30, 2020 (edited) Break out the rope and tackle or a chain hoist. Boards underneath. Drag it up. Done! Edited April 30, 2020 by BotusBuild
Jeremy Harris Posted April 30, 2020 Posted April 30, 2020 On 30/04/2020 at 15:43, BotusBuild said: Break out the rope and tackle. Done! or a chain hoist Expand That's how I got a ~150kg Sunamp up the stairs on my own. Took me the best part of a day, and was damned hard work (and it slightly damaged the stairs). That was before I discovered just how very useful an electric stair climber can be. 1 1
ToughButterCup Posted April 30, 2020 Posted April 30, 2020 Ours is going up from outside and will be posted through the bedrom window using a material handler - I hope. Thank God I haven't had time to fit the julliette balcony yet - in @ProDave's words, both my first floor doors are currently suicide doors
JFDIY Posted April 30, 2020 Posted April 30, 2020 I fitted an 80kg skylight in a second floor roof on my own, it all comes down to planning and using mechanical advantage. I made a sled from an 8x4 sheet of ply with a couple of battons on the back, and nailed some more battons to the roof to stop it going sideways then hoisted it up using a simple pull winch. As mentioned above, by @BotusBuild a few planks to make a ramp up the stairs and drag it up.
Mr Punter Posted April 30, 2020 Posted April 30, 2020 On 30/04/2020 at 14:33, Boris said: We have purchased an Ashton and Bentley ISIS bath Expand Is it part of their Taliban range? Who thinks up these names?
SteamyTea Posted April 30, 2020 Posted April 30, 2020 On 30/04/2020 at 17:12, Mr Punter said: Is it part of their Taliban range? Who thinks up these names? Expand Isis is the River Thames above Oxford.
Mr Punter Posted April 30, 2020 Posted April 30, 2020 On 30/04/2020 at 17:26, SteamyTea said: Isis is the River Thames above Oxford. Expand And the dog in Downton but I still would not name a bath after it!
Ferdinand Posted April 30, 2020 Posted April 30, 2020 (edited) It's also an assertion of identity by my sibling. But I think all this Heath-Robinsonism and proposals for extended self-flagellation argues for my solution. Leave them to it, and go find a cup of char. Edited April 30, 2020 by Ferdinand
joe90 Posted April 30, 2020 Posted April 30, 2020 I used to do quite a few bathroom re furbishments and always refused to remove a cast iron bath (in one piece) told the customer if they wanted it they can shift it!!! (Always ended up smashing it to bits and weighing it in with scrap metal). Sorry no help i know.
Boris Posted May 7, 2020 Author Posted May 7, 2020 Ha ha Mr Punter. I am convinced I am on watched lists by MI5, MI6 and CIA as I have been searching online for 6 months to find the best price. In the end we hired a construction lift for £60 a day. It worked a treat. 1
Boris Posted May 7, 2020 Author Posted May 7, 2020 AnonymousBosch our Juliet balcony 250 kg went up rickety temporary stairs with 2 men from Stoke and my OH. Very quick, I was astounded.
