1 minute ago, Ferdinand said:
Where do we sneak in at the weekend and swap all the labels?
No !!!! - I’d cry !!!!
It has to be organised otherwise a logistical nightmare
12 minutes ago, Carrerahill said:
You put me to shame, I wired our place for network about 5 years ago and they are still all just hanging in the comms cupboard!
Only just powered on the 48 port bridge ( bought off eBay ) rather noisey ! Thought a plane was taking off - that might be an issue ...
This is very common, take it apart, find the little fans, replace with a same voltage same size thing.
I have about 5 switches which are noisy. I actually removed the fans from some and let the rack fans do the job by aiming them right across the case.
So it’s just noisy because of old fan bearings worn ? I.e new fans would be much quieter ??
Yes, the fans are I think like 40mm, they are small, spin pretty fast and just wear out. Chances are it sat in a data-rack in an office for the last 10 years. I know I'd feel kinna rough if I was made to work flat out for 10 years!
You can get them for a few pounds.
Edited by Carrerahill
I got some of these to quieten down my ubiquiti switch & router
https://www.amazon.co.uk/dp/B071J8CZP9/
Be sure to get the deepest ones that fit (e.g. 40x20mm not x10mm for the above size) as they'll move more air per rev hence can be run slower
The switch likely won't have speed control either but you can get little PWM controllers to put in line with them to set at a low speed.
Iirc PoE switches can run a fair bit warmer so check again after everything is hooked up.
Shows how useful network cable is.
3 hours ago, pocster said:
What’s the real difference between internal and external
One can be used as a washing line.  Probably the biggest energy saving device available.
I deliberately hunted around and found both a 16 port switch and a router than don't have fans.  I've two PCs here that don't have fans either.  I even get annoyed by the fan in my laptop, and its replacement is going to be a fanless model.
I know I know - it will come in handy when I actually set things up properly though, media server etc I will also patch phone onto some of them.
Okay I will bite.
Why the termination strip and patch leads?  I would have just crimped an RJ45 onto the end of each cable and plugged them straight into the switch.  That's all I have done with the few I have in use.
19 minutes ago, ProDave said:
Okay I will bite.
Some cables are crimped as stranded cat5 ; some or keystones as solid core cable . I prefer the patch board as it means the cables won’t hopefully get moved - so any unplugging etc . Done by patch cables ( pre bought ! Didn’t fancy making them )
24 minutes ago, ProDave said:
Okay I will bite.
I like the patch panels as they tidy all the cables away.  I have mine flush with the plasterboard.  You can adapt to phone and poe where needed.
This is all in my man cupboard. Flush cables to the wall is just too much ?.
As long as it’s manageable and obvious which cables goes where I’m happy . This cupboard does not need SWMBO approval !! ???
Yeah if you're using solid core runs, the patch panel is the place to convert to stranded cables. Ideally the solid cores then will never have to be touched or moved again and can last decades.
Analogous  to why in a lighting circuit you have a ceiling rose rather than drop T&E to the pendant, say
  • 1 month later...
I'm actually having great difficulty finding the 5 replacement fans I need. Can find them on US eBay at £100 for 5 + postage!!!!
https://www.ebay.co.uk/itm/Lot-5x-new-Quiet-fans-NETGEAR-ProSAFE-GS748TP-Low-noise-best-for-Home-Networking-/263162755852
Edited by pocster
13 minutes ago, pocster said:
Ouch again !
Moi?
Can you sand those wispy bits off those blocks sometime...
3 minutes ago, Onoff said:
Moi?
No - I’m leaving them for you
