ProDave Posted January 11, 2020 Posted January 11, 2020 On 11/01/2020 at 21:11, Cpd said: I will do some research but if anyone had a “go to” place online to buy 221 please do share ! many thanks. Expand https://www.screwfix.com/search?search=wago+221 https://www.toolstation.com/search?q=wago 221 https://cpc.farnell.com/search?st=wago 221 http://www.discount-electrical.co.uk/search.php?xSearch=wago+221&x=0&y=0 https://www.tlc-direct.co.uk/tcl/search?query=wago+221&Submit=Search I think everyone does them 1
Jeremy Harris Posted January 11, 2020 Posted January 11, 2020 I've always bought 221s from CEF, fair bit cheaper than Screwfix and usually in stock. Not as user friendly as 222s IMHO, it's easy to break fingernails opening the 221s. Nice and compact, though, not really much bigger than the push fit Wagos. 1
dpmiller Posted January 11, 2020 Posted January 11, 2020 got a kit of chinesium clone 221s and they're very good.
Onoff Posted January 11, 2020 Posted January 11, 2020 On 11/01/2020 at 21:47, dpmiller said: got a kit of chinesium clone 221s and they're very good. Expand Check out the test of real WAGOs vs the counterfeit ones on YouTube!
Stewpot Posted January 11, 2020 Posted January 11, 2020 Never heard of Wagos before - real or fake. I've just been watching Big Clive[1] take one apart, and he seems to like them. Can you put more than one wire into each slot, as you can with a choc-block? [1]A man whose opinions seem trustworthy.
PeterW Posted January 11, 2020 Posted January 11, 2020 On 11/01/2020 at 22:44, Stewpot said: Can you put more than one wire into each slot, as you can with a choc-block? Expand Yes if it’s stranded wire twisted together but they do the lever ones in 2 3 4 5 so very little point in scrimping.
Markblox Posted January 11, 2020 Posted January 11, 2020 On 11/01/2020 at 22:44, Stewpot said: Never heard of Wagos before - real or fake. I've just been watching Big Clive[1] take one apart, and he seems to like them. Can you put more than one wire into each slot, as you can with a choc-block? [1]A man whose opinions seem trustworthy. Expand No, but you get different sizes so you don't need to. Great to use in a wiring centre and you also have Wago boxes of different sizes including very small ones to use with downlights. Save a lot of time and pretty foolproof, just strip back 15mm of insulation.
dpmiller Posted January 12, 2020 Posted January 12, 2020 On 11/01/2020 at 21:57, Onoff said: Check out the test of real WAGOs vs the counterfeit ones on YouTube! Expand yes, I've seen'em. More of an issue with 222s I thought. Can't see me needing them for anything other than lighting circuits tho so I'll happily risk an amp passing through. /now the ones that come with cheapo lights, that look like chokblocks with release buttons on? Purest kelp. Wire isn't caged within the terminal so you're reliant on the plastic to keep the pring pressure up. Naff.
SteamyTea Posted January 12, 2020 Posted January 12, 2020 Re Steps. I had a pair open up on me. Hit the deck with my left are underneath them, right foot twisted between two bottom rungs. Trapped like a goodun. Broken arm and several broken ribs. 18 years on there is still a painful spot on my left arm. The plumbers on the site were impressed that I turned up the next day and carried on working.
Onoff Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 11:00, SteamyTea said: Re Steps Expand I liked the dark haired one. 1
SteamyTea Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 11:06, Onoff said: On 12/01/2020 at 11:00, SteamyTea said: Re Steps Expand I liked the dark haired one. Expand I still wonder if Baby Spice tastes of prawn cocktail crisps. Not sure if that is a good thing.
Onoff Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 11:08, SteamyTea said: I still wonder if Baby Spice tastes of prawn cocktail crisps. Not sure if that is a good thing. Expand Sounds better than "tastes like a burnt switch" ?
SteamyTea Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 11:13, Onoff said: tastes like a burnt switch Expand Was in a Kent cafe where they had never heard of a ham and cheese toasty. "Looking in the wrong place" I quipped.
Onoff Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 11:47, SteamyTea said: Was in a Kent cafe where they had never heard of a ham and cheese toasty. "Looking in the wrong place" I quipped. Expand Weird, pretty common in this part of Kent.
ProDave Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 11:13, Onoff said: Sounds better than "tastes like a burnt switch" ? Expand I'll bet a burnt switch tastes nothing like it smells,.
Cpd Posted January 12, 2020 Posted January 12, 2020 On 11/01/2020 at 21:28, Jeremy Harris said: I've always bought 221s from CEF, fair bit cheaper than Screwfix and usually in stock. Expand just had a look and very reasonable.
Jeremy Harris Posted January 12, 2020 Posted January 12, 2020 Main advantage for me is that CEF is about 2 miles closer to me than Screwfix, plus they rarely have a queue at the counter, plus pretty much everything they stock is pretty good quality. My experience with Screwfix recently has been that they tend to be a bit expensive now, plus the quality of some of their stuff can be a bit suspect.
Onoff Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 16:13, Jeremy Harris said: Main advantage for me is that CEF is about 2 miles closer to me than Screwfix, plus they rarely have a queue at the counter, plus pretty much everything they stock is pretty good quality. My experience with Screwfix recently has been that they tend to be a bit expensive now, plus the quality of some of their stuff can be a bit suspect. Expand Yes, I bought some 20mm galvanised couplers from CEF. Much thicker steel that the ones from Screwfix. Much more expensive though!
Onoff Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 11:08, SteamyTea said: I still wonder if Baby Spice tastes of prawn cocktail crisps. Not sure if that is a good thing. Expand Been thinking about this all day: Scary - Chilli chocolate Posh - Prosecco (possibly Lambrini as she's from Essex). Ginger - Irn-Bru Sporty - Lucozade
SteamyTea Posted January 12, 2020 Posted January 12, 2020 On 12/01/2020 at 19:11, Onoff said: she's from Essex Expand We all love an Essex Girl, frequently. (though I thought she was from Hertfordshire)
Rob99 Posted January 16, 2020 Posted January 16, 2020 (edited) On 11/01/2020 at 19:12, MJNewton said: There are smaller lever Wagos available too - the 221 series: Same rating as the 222's, and I prefer the transparent case for reassurance of correct insertion. Incidentally, re the push connectors they are releasable/reusable - you just twist the wire whilst pulling. Expand I've used hundreds of the 221's in my house, especially on my RGBW ceiling downlights which have 5 connections. Disconnecting and dropping the lights out to decorate was just a doddle. I rarely use choc blocks anymore. My electrician swears by them too. I've also used a couple of these wiring centre's which have the 221's clipped into them, very user friendly. Edited January 16, 2020 by Rob99
Barney12 Posted January 16, 2020 Posted January 16, 2020 Wago's.....Oooooh for some reason I find a huge desire to collect them and keep them neatly stored in compartments. They have the same allure as stationary. I think I better stop typing. ??? 1
Jeremy Harris Posted January 16, 2020 Posted January 16, 2020 I've mislaid loads of stuff after our house move, and the one thing I keep finding when looking for something else is yet another box of wagos. I have no idea how I have come to have so many part used boxes of the things around, but the bugger is that they are all ones that I never use very much (like 224s and 773s).
