SallyL Posted August 28, 2019 Posted August 28, 2019 (edited) Might be wrong place to ask but if I'm putting in conduit pipe for 32mm water pipe and also 25mm water pipe can anyone recommend which ones to use, is it a case of 40mm for the 25mm and 63 for the 32mm water pipes as I will be pulling them both through to and from house/workshop. Also any recommendation for conduit size for house to workshop armored cable? colour wont matter any better than most suppliers? Edited August 28, 2019 by SallyL
nod Posted August 29, 2019 Posted August 29, 2019 I put the blue ribbed ducting in 63 from memory and the blue 25 mil water pipe You just need to remover that the last two metres of the ducting needs to be insulated ducting I ran it in a trench leaving a 5 mtr coil roughly where we where going to connect to the main and then insulate the house end of the duct 1 mtr in the house 2 mtrs underground
Russell griffiths Posted August 29, 2019 Posted August 29, 2019 Why not put the pipe in the same time as the conduit, the cost is pennies and it will save any hassle later, the conduit is only there for emergency replacement and will probably never be used as the life expectancy of mdpe is huge.
Big Jimbo Posted August 29, 2019 Posted August 29, 2019 I'd go with Russell above. Just put the pipe in now. Job done
ProDave Posted August 29, 2019 Posted August 29, 2019 On 28/08/2019 at 23:46, SallyL said: Also any recommendation for conduit size for house to workshop armored cable? colour wont matter any better than most suppliers? Expand Oh yes it will, BLACK for electrical cables. don't use any other colour, especially not blue for electrical cables.
PeterW Posted August 29, 2019 Posted August 29, 2019 On 29/08/2019 at 08:02, ProDave said: Oh yes it will, BLACK for electrical cables. don't use any other colour, especially not blue for electrical cables. Expand Why will it ..?? conduit colour underground doesn’t matter as long as the correct identification tape is used above the ducting. For connections, some DNOs use black, others use red, some use grey. There is no “official” standard that I can find and if it’s armoured in the duct anyway, what’s the issue ..?
Bozza Posted August 29, 2019 Posted August 29, 2019 I’m just doing some trenching services on my plot right now. I’ll also be doing armoured cabling and water supply from what will be the house to detached garage workshop. Personally I’ll use black conduit for for leccy and blue for water to depths per DNO utilites company etc standards and spec even if not required I’d rather be accused of overkill than killing someone in the future however unlikely. Though no one will see it that’s the type of thing I take pride in knowing I’ve done the best and safest job possible knowing that in 50 years time someone may dig it up, as I have done exactly that on my plot and found stuff which was dangerous.
ProDave Posted August 29, 2019 Posted August 29, 2019 On 29/08/2019 at 08:26, PeterW said: Why will it ..?? conduit colour underground doesn’t matter as long as the correct identification tape is used above the ducting. For connections, some DNOs use black, others use red, some use grey. There is no “official” standard that I can find and if it’s armoured in the duct anyway, what’s the issue ..? Expand Try putting a bit of blue duct into your new build, and then see the reaction of the DNO when invited to feed a power cable through it. Agreed some DNO's use red for LV cables, red is supposed to be used for HV (but I have seen SSE up here putting HV in black)
dpmiller Posted August 29, 2019 Posted August 29, 2019 our DNO (NIE) mandates a red hockeystick, and most of the cabling on rural sites is direct buried.
ProDave Posted August 29, 2019 Posted August 29, 2019 On 29/08/2019 at 15:46, dpmiller said: our DNO (NIE) mandates a red hockeystick, and most of the cabling on rural sites is direct buried. Expand As they mandate a red duct, is the cable they supply red also? or the standard black cable?
dpmiller Posted August 29, 2019 Posted August 29, 2019 standard black stuff. Concentric in our case. 1
Pete Posted August 29, 2019 Posted August 29, 2019 On 29/08/2019 at 15:14, ProDave said: Try putting a bit of blue duct into your new build, and then see the reaction of the DNO when invited to feed a power cable through it. Agreed some DNO's use red for LV cables, red is supposed to be used for HV (but I have seen SSE up here putting HV in black) Expand We put in red ducting as instructed. When the inspector came out to check the ducting before connecting the mains he told us we had used the wrong red ducting. We had used the red flexible duct instead of the 3 metre socketed pipe but at no point was this specified. He passed it after we said at no point was it specified what type of red duct was required and when the cable pullers's arrived on site they said they preferred the flexible duct as it provided a nicer bend for the cable to traverse
