Bathroom starts !
2 minutes ago, Big Jimbo said:
I hate tiling.....When ever i have seen pro tilers, they always use the little plastic wedges, rather than spacers. I asked one fella why, and he said that no matter how much you pay for tiles, they are never exactly the same size. Bloody tiling.....
That’s true . I can actually see the difference in size and even thickness in my tiles . (expletive deleted)ing expensive rubbish .
So stick a nice metal trim as tight to the ceiling as I can get ( whilst being level ! ) then tile upto it with my pro skills
Sounds like a plan.
4 minutes ago, pocster said:
But If I use trim on that wall won’t it look odd it doesn’t continue up the angled ceiling edge ??
If it were me, I would tile up to the ceiling, then either grout or silicone between tile and ceiling.
silicone will hide the cut edges too
Edited by Gav_P
10 minutes ago, pocster said:
So on this wall return to the metal door surround . Just ct1 tiles to the timber ? . Assume that’s more than enough to hold them ( not very wide as you can see )
 I used CT1 Grab n Bond to stick tiles to marine ply.
Normal ct1 not good enough ?
So any tuned adhesive would be ok .
Only mention ct1 as that’s whats to hand .
Tbh I ran out of Grab n Bond so when it came to doing the tile reveal which was lined with 27mm Gyproc insulated pb, I used CT1, Sticks Like Sh!t, The Dogs B@llocks...whatever.
7 minutes ago, pocster said:
BM said this stuff
will apparently stick anything to anything.
I did ask if I could use it on SWMBO mouth .
He said it wasn’t that good !
Why not stick half on with this and the rest with CT1. Like the Head n Shoulders advert!
17 minutes ago, pocster said:
BM said this stuff
He would as he sells it ...
How much a tube has he taken you for ..??
Yeah it was expensive!
I did frown .
On the shelf price was some like £14.50
I’ll get it for less on account by maybe 10%
To make up for the extortion I’ll nick a tube next time . Put it down the front of my trousers . No one would notice the difference ?
The thing is my BM is local so obviously if I need it ASAP it's convenient .
Also they usually only sell high markup brands like schulter ,Geocel entire range. So *choice* is limited.
Edited by pocster
2 hours ago, pocster said:
BM said this stuff
BTW that large pink hairy mass to the lower right is my knee ?
