Saw a photo of a shower on another thread of a shower cubicle that had so many bits and pieces on all the walls that there was no blank section left.
Ergo impossible to have sex in. Strikes me that I have never seen anyone have this in their shower spec.
Wanted to check that you had not done the same thing.
Would not be able to cope with an even more frustrated @pocster than you are already.
But you (and subsequently the rest of us) are OK.
Good job.
F
Couldn’t get this one as tight to the wall as I would of liked . So squeezed a load of ct1 in there . Guessing that will solve the issue and minimise any movement. Good old CT1 ?
Grab handles a must?
27 minutes ago, pocster said:
Main bathroom wc in, also the obligatory iPad for when in the bath
Is that the iPad in some sort of an IP rated enclosure?
Tbh I'd have jammed it behind the bog to take the gap up!
Yes it’s a special ip00 rating .
Power is via poe - so unlikely to kill you if it gets wet - unlike your electric mains powered heater in the bathroom ?
3 minutes ago, Pete said:
I think you and @Onoffare long lost brothers!!
Brothers from different mothers .... and fathers !! . Apart from that we were twins joined literally at the hip !
41 minutes ago, Ferdinand said:
(As on topic as all the rest)
Bathroom Starts !
always makes me think of
This Door is Alarmed !
F
I think we're all alarmed at some of the stuff that goes on here.
  • 1 month later...
What a complete &@&&&
Panels bitch heavy .
Have to cut the top of the fitting to gain 1mm
Did it dry .
Been gently tapping it in with a rubber hammer . No way am I taking it out . So no ct1 under this horizontal edge . It would just push up and cause more of an issue . Will ct1 then silicone the inside bottom edge once all done .
A complete bitch !!
The top piece
Nice edge and other end , cut by blind left handed man . Bear in mind I filed it a bit better !
Edited by pocster
1 minute ago, ProDave said:
What's the cable for?  don't tell me the shower screen connects to the HA?
Backlit leds on the vertical profiles
Edited by pocster
