11 minutes ago, pocster said:
Nah that’s long gone . I’ll find the invoice then I should be able to contact geberit ( or the frame supplier ) for the bits . So annoyed ! Wouldn’t throw them out !! Grrrrrr
Seem to recall you paid £555.
It's a UP320 Sigma. Was it 80 or 112cm (that's floor to top of frame height).
Christ was it that much ? How do you remember that . 112cm for sure
One of these 3 then:
https://catalog.international.geberit.com/en-ZA/products/CH3_100902/Systems/Installation-and-Flushing-Systems/Geberit-Duofix/Installation-elements/Elements-for-WCs?tab=products&name=&type=Sigma+12+cm&ppp=15
10 minutes ago, pocster said:
Shower doors to look at now . Will fix the whole lot dry so I understand what I’m doing !!
DONT LOOSE ANY BITS!!!!!!
21 minutes ago, pocster said:
I like the geberit thought that goes into the design
Yep it just works. I must admit it took me a while to get into their instructions for the WC frame/flush plate and then wall drain but once you do it all makes sense. Don't like that they mix mm and cm on the same drawing though.
21 hours ago, Onoff said:
....Don't like that they mix mm and cm on the same drawing though.
I have to remind myself that Germans talking about measurements always quote centimetres first and then millimetres,  separated by a comma. They actually say the 'comma' . As in
15 , 3 means 153mm. But no Brits ever say that.
Bluddy  furiners.
Attempting ensuite shower doors .
Everything ok after some head scratching but this bits got me .
Step 2.6 - don’t get how this strip fixes in . The sticky part suggests it goes on the end of the glass . But it then won’t fit in the wall channel . Also the instructions seem to suggest sliding it in somehow - but then the sticky bit doesn’t make sense ...
Probably not critical . At the moment the glass is sat in ct1 in the base bit which in turn is ct1’d to the tray . I could just run a thin bead down the inside of the glass .... ??
Top of wall profile . Plastic strip won’t fit in there !!
Before anyone asks , yes , there is an arm support to hold the glass
Wasn’t happy about that bottom horizontal bit that the glass sits in . It’s just sticky tape on the back to stick it to the tray - wtf ! Crap ! . So I ct1 ‘d it
Well ! That’s where it’s going now .
Why they can’t simply show the wall profile having it slid in before the glass who knows !
Because of those b stard textured tiles still have gaps between profile and wall . I did ct1 the nuts on it ( used an entire tube for 2 profiles ) . So will have to go inside the cubicle and ct1 those gaps again .
Hate textured tiles - cause so many problems!!ED7398C4-44CA-430F-8FB4-97D48FD05C63.thumb.jpeg.3bbb2fc357eb6b6f8158ae0a579a72f9.jpeg
