Onoff Posted January 22, 2021 Share Posted January 22, 2021 11 minutes ago, pocster said: Nah that’s long gone . I’ll find the invoice then I should be able to contact geberit ( or the frame supplier ) for the bits . So annoyed ! Wouldn’t throw them out !! Grrrrrr Seem to recall you paid £555. It's a UP320 Sigma. Was it 80 or 112cm (that's floor to top of frame height). Link to comment Share on other sites More sharing options...
Pocster Posted January 22, 2021 Author Share Posted January 22, 2021 23 minutes ago, Onoff said: Seem to recall you paid £555. It's a UP320 Sigma. Was it 80 or 112cm (that's floor to top of frame height). Christ was it that much ? How do you remember that . 112cm for sure Link to comment Share on other sites More sharing options...
Onoff Posted January 22, 2021 Share Posted January 22, 2021 20 minutes ago, pocster said: Christ was it that much ? How do you remember that . 112cm for sure One of these 3 then: https://catalog.international.geberit.com/en-ZA/products/CH3_100902/Systems/Installation-and-Flushing-Systems/Geberit-Duofix/Installation-elements/Elements-for-WCs?tab=products&name=&type=Sigma+12+cm&ppp=15 1 Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 22, 2021 Share Posted January 22, 2021 1 Link to comment Share on other sites More sharing options...
Pocster Posted January 22, 2021 Author Share Posted January 22, 2021 23 minutes ago, ToughButterCup said: Just screws those bolts in and ignores the wobble ! ? Link to comment Share on other sites More sharing options...
Onoff Posted January 22, 2021 Share Posted January 22, 2021 Just now, pocster said: Just screws those bolts in and ignores the wobble ! ? Yep. Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 22, 2021 Share Posted January 22, 2021 Ze Tschermans dont knof vot a vobble is.... 1 Link to comment Share on other sites More sharing options...
wozza Posted January 22, 2021 Share Posted January 22, 2021 My recently fitted Grohe frame had wobbly bolts, no extra nuts to tighten. 1 Link to comment Share on other sites More sharing options...
Pocster Posted January 23, 2021 Author Share Posted January 23, 2021 Toilet done ! I like the geberit thought that goes into the design ( apart from wobbly bolts ) 3 Link to comment Share on other sites More sharing options...
Pocster Posted January 23, 2021 Author Share Posted January 23, 2021 Shower doors to look at now . Will fix the whole lot dry so I understand what I’m doing !! Link to comment Share on other sites More sharing options...
joe90 Posted January 23, 2021 Share Posted January 23, 2021 10 minutes ago, pocster said: Shower doors to look at now . Will fix the whole lot dry so I understand what I’m doing !! DONT LOOSE ANY BITS!!!!!! 1 Link to comment Share on other sites More sharing options...
Pocster Posted January 23, 2021 Author Share Posted January 23, 2021 3 minutes ago, joe90 said: DONT LOOSE ANY BITS!!!!!! As if ? 1 Link to comment Share on other sites More sharing options...
Onoff Posted January 23, 2021 Share Posted January 23, 2021 21 minutes ago, pocster said: I like the geberit thought that goes into the design Yep it just works. I must admit it took me a while to get into their instructions for the WC frame/flush plate and then wall drain but once you do it all makes sense. Don't like that they mix mm and cm on the same drawing though. 2 Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 24, 2021 Share Posted January 24, 2021 21 hours ago, Onoff said: ....Don't like that they mix mm and cm on the same drawing though. I have to remind myself that Germans talking about measurements always quote centimetres first and then millimetres, separated by a comma. They actually say the 'comma' . As in 15 , 3 means 153mm. But no Brits ever say that. Bluddy furiners. 1 Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 Attempting ensuite shower doors . Everything ok after some head scratching but this bits got me . Step 2.6 - don’t get how this strip fixes in . The sticky part suggests it goes on the end of the glass . But it then won’t fit in the wall channel . Also the instructions seem to suggest sliding it in somehow - but then the sticky bit doesn’t make sense ... Probably not critical . At the moment the glass is sat in ct1 in the base bit which in turn is ct1’d to the tray . I could just run a thin bead down the inside of the glass .... ?? Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 Top of wall profile . Plastic strip won’t fit in there !! Before anyone asks , yes , there is an arm support to hold the glass Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 Wasn’t happy about that bottom horizontal bit that the glass sits in . It’s just sticky tape on the back to stick it to the tray - wtf ! Crap ! . So I ct1 ‘d it Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 Oh hang on ! I’ve got to some how slide it down behind the glass ?!?!?!? Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 Well ! That’s where it’s going now . Why they can’t simply show the wall profile having it slid in before the glass who knows ! Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 Because of those b stard textured tiles still have gaps between profile and wall . I did ct1 the nuts on it ( used an entire tube for 2 profiles ) . So will have to go inside the cubicle and ct1 those gaps again . Hate textured tiles - cause so many problems!! Link to comment Share on other sites More sharing options...
Gav_P Posted January 25, 2021 Share Posted January 25, 2021 Rip ‘em out and put some decent tiles in ? 1 Link to comment Share on other sites More sharing options...
Mr Punter Posted January 25, 2021 Share Posted January 25, 2021 1 hour ago, Gav_P said: Rip ‘em out and put some decent tiles in ? And next time, hold back on the piss coloured grout! 1 2 Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 Unhelpful shit stains ! 1 Link to comment Share on other sites More sharing options...
Onoff Posted January 25, 2021 Share Posted January 25, 2021 1 minute ago, pocster said: Unhelpful shit stains ! Fair enough, I thought it was your reflection. 1 Link to comment Share on other sites More sharing options...
Pocster Posted January 25, 2021 Author Share Posted January 25, 2021 9 minutes ago, Onoff said: Fair enough, I thought it was your reflection. Post me a rad key please Link to comment Share on other sites More sharing options...
