Must have been on the 'old' site I remember reading a thread about it.
I'm looking for possible options go with a garden room at the bottom of the garden. The toilet bit would seem straight forward, less so options for using water to wash hands etc.
I'll take a look at that. Someone did a DIY bucket composting type but it must have been in the old place. Hoping they're still around.
GBF is probably a better hunting ground for this but its far worse than here.
20 minutes ago, Onoff said:
I won’t deny that living by my myself at the bottom of the garden isn’t appealing but I’m only looking for a basic workable solution, not a fully functional bathroom not renewable energy generator.
If I proceed with a proper garden room instead of a shed, it is going to need some basic facilities that would put off the faint of heart but satisfy a less fussy user and only get used on an infrequent basis.
Edited by daiking
Seen something which churches often use once. Was a dead simple composting soakaway. Diagrams were online somewhere. Not sure what a BCO would say
Think touring caravan facilities.
Porta Potti (other brands of chemical toilet are available) empty at house when required. Go to house for a No 2 :ph34r:
Small hand basin with water from a small tank, refill when empty.
Called trench arch. Used in eg rural churches where the average over time might be equivalent to one person occupying full time, or under a path when there are skeletons and archaeology everywhere. Church archaeology costs a fortune that makes self-build versions seem a smaller challenge.
I was involved in one where they found a plague pit under the floor. 300 tons of sand to fill it rather than several months for archaeology.
How to here:
https://www.gloucester.anglican.org/content/pages/documents/1352755360.pdf
https://www.greengloucestershire.org.uk/content/pages/documents/1424700436.pdf
Edited by Ferdinand
http://www.separett-usa.com/
They are a Swedish company. Doing off grid toilets. Used one in the alps in a chalet. Works perfect and no difference to a WC.
As of washing hands, you probably can dispose this water in the garden behind the shed as it s grey water
I don’t have a serial killer caravaner background so I don’t want to go down that chemical toilet route. Ewwww.
something low maintenance, like a composter, potentially could do a small soak away for liquid waste but conscious of having a stream really close by.
Shed project is a long term thing and as the children get older will probably see a lot more use in the long term. So looking for a long term, low use solution .
lots of advice available at Centre for Alternative Technology - I am sure they will have the info you need. They have  had composting toilets for the last 20 years and use the 'waste' on the gardens as it is a fabulous soil improver.  There was no smell or flies.  Brilliant way of turning our waste into a positive use.
And the Autonmous House near Pershore had two composting toilets in the house - again, no smells and great idea. full info here.
http://www.cropthornehouse.co.uk/
  • 4 weeks later...
@daiking Pulling on this thread, does not @Tennentslager have a compost-loo in his hut at Carbeth? I am sure I recall lids going on of buckets of poo and leaving them for 18 months. Just have to keep them in date order whilst evolving :ph34r:.
There is a piccie here, and the detail must be around somewhere.
PS Section in this piece towards the end
Edited by Ferdinand
Thanks @Ferdinand but I am going backwards on the posh shed at the moment. The flood considerations may require a fundamental redesign (and significant cost increase) ?.
You're thinking of Matt Damon. Lovely spuds though.....
Here he is on the karzi:
