Kate12 Posted June 12, 2019 Share Posted June 12, 2019 is it sensible and/or difficult to build rooms with ceiling heights that are different from 2.4m, I understand that this is the standard length of plasterboard, but I was looking for a slightly higher room height of 2.6m? Link to comment Share on other sites More sharing options...
jack Posted June 12, 2019 Share Posted June 12, 2019 It's quicker and therefore cheaper if you don't have to cut boards. You can get 2700mm plasterboard though - easy enough to cut off 100mm, although why not go for 2700mm high ceilings if your rooms are big enough to handle it? As for whether it's worth doing the extra height, I personally think a bit of extra height helps, especially in larger rooms. We have 2850 ceilings downstairs and I think it makes things feel very spacious. Link to comment Share on other sites More sharing options...
Alexphd1 Posted June 12, 2019 Share Posted June 12, 2019 (edited) Standard plaster comes in 2.4, 2.7 and 3m. Plus 1 for high ceilings. We have 2.9m so cut off a 10cm of the 3m plaster. Edited June 12, 2019 by Alexphd1 1 Link to comment Share on other sites More sharing options...
Kate12 Posted June 12, 2019 Author Share Posted June 12, 2019 Thanks for the replies. I was doing a quick search on boards and only came up with 2.4m so that's great to know. We're looking for higher ceilings but just might have to dig down a bit to stop the house getting too tall. Link to comment Share on other sites More sharing options...
Onoff Posted June 12, 2019 Share Posted June 12, 2019 I used 2.7s as for some daft reason I decided to go with a nom 2470mm floor to ceiling height! Meant wasting nearly 300mm. Idiot, I should have dropped the new joists lower. Could have avoided those rips by the ceiling, took forever. Link to comment Share on other sites More sharing options...
Conor Posted June 12, 2019 Share Posted June 12, 2019 Higher ceilings are really important in large open plan areas that are the fashion. The bigger the room, the higher the ceilings should be. We're going with 2.7m in most spaces and vaulted on the first floor. 1 Link to comment Share on other sites More sharing options...
nod Posted June 12, 2019 Share Posted June 12, 2019 5 minutes ago, Onoff said: I used 2.7s as for some daft reason I decided to go with a nom 2470mm floor to ceiling height! Meant wasting nearly 300mm. Idiot, I should have dropped the new joists lower. Could have avoided those rips by the ceiling, took forever. Oops Should have bought 2.5 boards Link to comment Share on other sites More sharing options...
Mr Punter Posted June 13, 2019 Share Posted June 13, 2019 Bear in mind if you have 2.7m downstairs you will need a couple of extra treads on the staircase. Link to comment Share on other sites More sharing options...
Alex C Posted June 13, 2019 Share Posted June 13, 2019 11 hours ago, Conor said: Higher ceilings are really important in large open plan areas that are the fashion. The bigger the room, the higher the ceilings should be. We're going with 2.7m in most spaces and vaulted on the first floor. This is exactly right. large open plan rooms can feel really low with a 2.4 ceiling. we used 2.7 downstairs and 2.4 upstairs which worked really well. We have a vaulted ceiling with roof light over the stairs so there is no obvious transition from going from the ground floor with high ceilings to upstairs with lower ones. Link to comment Share on other sites More sharing options...
ProDave Posted June 13, 2019 Share Posted June 13, 2019 Well I am well known for being differerent We have standard 2440mm ceilings downstairs, but it's the bedrooms where one gets the full vaulted ceiling with a mezanine, and the other gets a 3M partly vaulted ceiling (so we at least have a small loft space above for storage) Link to comment Share on other sites More sharing options...
jonM Posted June 13, 2019 Share Posted June 13, 2019 I have 2600mm ceilings downstairs and cathedral ceilings upstairs. I think the extra height is well worth it. Just the bathroom and en-suite have standard ceilings which give me a small amount of storage space. Link to comment Share on other sites More sharing options...
