flanagaj
Everything posted by flanagaj
Can't find a brickie (Hampshire). Any suggestions?
flanagaj replied to flanagaj's topic in Brick & Block
I have 540m2 blocks 147m2 face brickwork So my numbers are not far off yours, but your 13k is way under the estimators 20k labour figure. -
White Lane Cattery 106b Elevations.pdf -
Quotes are labour only and they have allowed 20 days for the job. It's a straightforward rectangle build with gable ends, face brickwork on lower ground floor and then block upstairs. The issue I have, is that if I just say "Oh well, let's just pay 10k more and get going", if that same thing happens for all trades, then I am in real trouble and we'll have to sell the house once it's built. -
They use local labour rates. A brickie is not usually on more than £300/day. So I said 2 brickies and a labourer for 20 days at £800/day. That still only equates to £16000 for 20 days work. So the quotes of 30k, 42k and 60k are just a joke. Anyone would think I was hiring a legal team. -
Here are the estimates that I received from Estimators. Excavation & Foundations - 7 days (2GW + 1 Labourer) Foundation Masonry - 5 days (2B + 1 Labourer) Brickworks - 15 days (2B + 1 Labourer) My theory is that if estimators can't be that far off when it comes to estimating costs for a build. -
I had our plans estimated and it gave me a figure for labour up to plate height. So far, they have ranged from 10k over the estimators 20k figure, up to a staggering 45k over. I really don't know how to proceed now as we have had 4 quotes so far. It's a very simple brick and block rectangle, built using stretcher bond.
ACO drain around whole house?
flanagaj replied to flanagaj's topic in General Self Build & DIY Discussion
The tech architect submitted our drawings to BC as follows. I do however, want level thresholds on the entrance door, garage door and both patio sliders. That makes it difficult to not have it at DPC level or very slightly below. -
Are you saying that as long as I have the correct fall on the ACO system I can have the outside levels at dpc or a few mm under it? -
I understand that for the garage and doors with level threshold, you install some sort of ACO, but what about the areas of the house which are not entrances, but you want at the same level? Could you for instance run some sort of ACO drainage around the whole house so that you have the exact same level? I am trying to avoid having a 150mm step down from level threshold areas. For example, I have a path that runs down the back of the house. It has steps one end, but at the other end is our patio. If I keep this section 150mm below dpc, I will then have a 150mm step up to the patio and will create a potential pond.
Triple glazed Vs double glazed patio doors
flanagaj replied to flanagaj's topic in Doors & Door Frames
In the end I've gone with the Norrsken 319A sliders. They have a fixed pane and the frame is chunky, but I'm ok with the aesthetics. I really liked the way that when you closed the door, it felt like you were closing and aircraft door. The sealing is very impressive. -
I've been using Heras panels for our site entrance, but last night's storm has busted them and I lost a pair last year to wind. I'm now contemplating just buying a set of proper steel site gates and putting them. Yes. They are nearly £900, but I just need a better solution than Heras. We have nosey neighbours and I like to screen it off and am currently using the hoarding that supposedly allows the wind through, but it's definitely not that great and is probably the reason for panels snapping. Caravan life is great. It's either been Baltic or lashing down. We want to get cracking, but the weather is certainly not in our favour.
I think they just said "Oi scrote, make some more muck". There were no pleasantries back then, when I was 17
Conventional floor build up. Eg, screed on top of insulation.
I didn't know whether the detailed drawings from the manufacturer would suffice. Eg, Velfac provide the below, so I suspect Norrsken do to? https://products-commercial.velfac.co.uk/products/18760/18789/19843/
I think I need to get on and get details finalised, but I didn't want to get too specific now regarding floor finishes. I've decided to cancel the idea of a power floated floor. Nice idea, but just too much chance of it looking xxxx or going badly wrong.
When we had our technical drawings done for building regulations submission, we hadn't finalised the sliding patio doors and windows, but we knew the sizes. So now, we are thinking about getting started, I've now got loads of questions. 1) Footing details (already discussed this on BH) 2) Level threshold detail, but the build up detail is dependent on the door frame manufacturer Do most people give their tech architect all this information upfront, to enable the associated junction details to be created?
As someone who laboured when they were young and understands that just shovelling sand and cement into a mixer is not conducive to creating a uniform mortar colour, I'll make sure that they grade the sand and cement to ensure we don't get that.
We have had our material palette signed off and I'm curious as to how you'd achieve the mortar look below. I'm conscious that it's not going to be the cheapest. Are we talking simply white cement and a pale sand, or is there a lime constituent in there too?
Thanks. Windows and doors along with brickwork are areas that I'd rather get right, even if that means cutting back on the interior finishing. They are difficult and expensive to change once you have built the shell. -
I have had quotes from both Norrsken for triple glazed alu clad sliders and also Origin for aluminium double glazed sliders. The Origins are obviously cheaper than the Norrsken offering, but I'm trying to understand whether in the grand scheme of things, the 4k difference for the two 4.4 * 2.2m and 2.4 * 2.2m sliders is worth swallowing. I'm concerned that large double glazed patio doors might be cold.
Husqvarna stone saw popping and flames out of muffler?
flanagaj replied to flanagaj's topic in Tools & Equipment
It was actually New Years Eve day, but I do wish I was more brazen about getting cracking on and not worrying about the neighbours. -
The carb was left on the manufacturer's settings. The old carb is long gone. -
I used my husqvarna stone saw yesterday and noticed that it was occasionally popping and I could see flames coming out the muffler. I replaced the rings and fitted a new genuine carburettor at the same time. Does anyone know what might be the issue or how to diagnose it?
I enlisted an SE 'Barrat Associates' online job. I am most likely to blame, they were quick and cheap. I sent across the building control drawings to them and got back nothing more than the structural calcs for the steels. I wasn't sure what to ask for, so I said I want full calcs for the drawings. These were submitted to building control and they signed the drawings off.
