Batteries in plant room and 120 minute fire rated walls
saveasteading replied to jimseng's topic in Energy Storage
And that's all that really bothers the fire service. But for an extra layer of plasterboard and some rockwool, isn't it worth stopping or slowing the spread? -
Why we need "Net zero"
saveasteading replied to Beelbeebub's topic in Environmental Building Politics
Long long ago, I designed, and then my employer built, a very large concrete tank for water storage at a coal mine. Only later did I learn that this was part of what was called Scargill-proofing.... doubling all resources at pits. My apologies to the pit communities that soon closed. So it reminds me that stockpiling is more than a big pile of stuff. It would be very expensive. -
It is imported in vast quantities from Canada. A stockpile wouldn't last long and with stock rotation won't rot. Whether this biomass is properly sustainable is another matter. -
The bco can't be an expert on everything, especially with changing technology. The regulations require safety, so I think it is fair that he asks for a formal proposal with references and risk assessment. -
A rotating cowl on a chimney is said to create a significant suction. The bearings are impressive as they spin for years except in exceptionally calm conditions. I've got one on a woodburner outlet, but mainly to limit downdraughts in gusts. It keeps most rain out too. How much suction I have no idea, and there is going to be some on an open flue anyway.
That beam was put there for a purpose, however misguided. For some mysterious reason, it has not been removed. Why not? Because it is part of the structure? Because an SE said don't remove that beam? Because the developer hoped it would all sort out, but it clearly has not? Ask the vendor. Ask to see the building reg's submission or permission to talk to the bco.
Heath Robinson could do this. Fire burns through string supporting extinguisher, which topples forward onto its lever which opens it and the fire goes out., It would be better if every supplier included a self-extinguishing system, and insurance cover for house and contents. -
So a water spray at an early stage could reduce the temperature enough? Or that fire extinguisher as above, but somehow automatically. Someone could sell these. The law could require them. On balance, better to let the heat vent perhaps. We are putting ours in the detached garage so the risk is less. Maybe a polystyrene box around it and vent outdoors. I asked about this at a recent exhibition... negligible risk he said and no special measures required. I wonder if we can get that in writing. -
Doesn't it need oxygen? If so, then a sealed enclosure, just stud and plasterboard, would soon snuff it out. Provided there wasn't a vent for excess heat of course.... but that can be fireproof too. Regardless of the rules and of insurance, I don't want my house to burn down. Homework needed. -
It will say that fire should not be allowed to spread. The rest is examples of how to do this. We can't expect the bco to know about battery technology and risk. So you need to know the fire risk and present this to he bco. But 120minutes may not be difficult. usually just extra plasterboard. -
Was my immediate thought too. To have got this far and not resolved this issue suggests that they have had advice they don't like, and want to pass this problem on. presumably you think it is overvalued. Not everything has a solution. You would need a site inspection by an SE before proceeding any further at all. They will rightly charge but you can ask them for a verbal overview to minimise their charge at this stage. Their overview may be that they can't possibly know without lots of research, so allow £xk for a more formal report and a very large contingency for the works. Some SE's would love this as interest and others will keep clear. The best advice to the seller would be to explain the issue in good faith and to open the beam up for inspection. But first, ask the agent to explain it. They won't tell you the whole story of course. And then tell them this obviously needs an enormous reduction in the price and what will they drop to, or you won't be considering it. My thought on what it is? It looks like a barn. Farmers use whatever is available and this may have been a beam for an engine hoist. The builder has not used an SE, and expected to be able to remove it but been told not to.by the bco. I'm intrigued. please report back. If you do walk away, do please try to find out if it sells. Another thought. Google the property and you may find the original sales advert as a barn for conversion, with some clues. and the planning portal is worth a try to.
Tips on foam to stick PIR (flooring) together?
saveasteading replied to Great_scot_selfbuild's topic in General Flooring
Agreed as above. No need to stick them down or together. I think I would ignore any gaps up to 2mm, as the tape and over-sheeting of dpm will create a closed cell. In any bigger gaps i'd be wary of squirting in foam, for the reason you suggest, , and more comfortable trowelling some in. Or make some slivers and press in. -
Digging a hole, pressing the ground with a thumb and referring to a tree table IS design. Btw you have 80m of footing there. So digging 100mm too deep and 100mm too wide will cost you about 8m3 of concrete and 8m3 of muck-away. (£1400?) An SE and skilled builder can save money from the start.
Should I start stock piling materials?
saveasteading replied to flanagaj's topic in Building Materials
10.00 news.... $110 now. -
Stock piling is seldom a good idea. It ends up being in the way, at risk of damage from operations and the weather, and needing double handling. Nearer to the time of need, ask the BM if any increases are forecast, and maybe avoid 10% cost and store for a few weeks. But I did this recently with insulation. And we had to shift it to suit a change in plan. The handling cost prob equalled the 10% saving. Then there is cashflow. The VAT cost is sitting there needlessly. Spend your time in saving material altogether, through design reviews and planning. -
Last resort.. read the instructions if you can find them.
tiling over trench blocks below dpc?
saveasteading replied to Ajm's topic in Bricklaying, Blockwork & Mortar
The work is very rough and it will have gaps too. I too suggest a complete repointing and a paint over. I like Blackjack as it is easy to use and fills the gaps. Although it is a very basic and plain material I've never known anyone dislike it, as they should be noticing the nice structure above. -
Raft foundation - close to existing structures
saveasteading replied to WisteriaMews's topic in Foundations
Yes and no. This would need very detailed consideration and a site survey, just to give this preliminary advice. After you have had it, may be the time to ask on here for other ideas, which a good SE will be happy to discuss. But do be aware that the term 'raft' is used to mean different things to different people. Do you mean a heavily reinforced slab that could span over soft spots and support structural walls, or simply a concrete floor? -
Own tools on day rate?
saveasteading replied to flanagaj's topic in General Self Build & DIY Discussion
indeed. and it is the contractor who would be in very big trouble for not declaring the income. The IR know when annual returns look imbalanced and the VAT computer spots anomalies too. Plus taxes do have a purpose. That customer is probably going through life complaining about government services, and the brown envelope brigade because that is what they would do. 'How much for cash in hand?' Oh just allow a 5% handling charge. -
Agreed. Just my hunch, but allowing it to settle may give other, less aerobic, bugs an opportunity to prosper.
Forever. There are still the 3 chambers separating and breaking down the contents. These aerators were only introduced about 20 years ago and do make it more efficient, but it works regardless. The caveat would be if you are using at capacity, or there is rainwater connecting into it. Most domestic situations have a tank sized for thee maximum occupancy. This ,might not apply to the klargesters with a wheel going round.. that might get quite gungy.
Backland Development - Unadopted Road
saveasteading replied to Cheesus's topic in Planning Permission
We know that people often do what suits themselves rather than society. Some might leave their bins on the roadside permanently, or on a shared drive. If the bins can't readily be wheeled up the drive then they will be left at the road. The planners have one chance to optimise the design for the good of us all. -
It’s coming out the hole
saveasteading replied to Pocster's topic in General Self Build & DIY Discussion
Have a Google. To my surprise there is a lot of info thereon. I'd have to find my training documents to see the detail. 1/3 or 1/4, and it probably doesn't matter which. I think the point is that the bolts shouldn't be stressed to capacity in everyday, passive mode, and so a load from wind etc doesn't then overstress it. That would apply also to pulling out a resin anchor or rawlpug etc. This will not apply to engines etc. which is a different world. -
Worse is cement and concrete. There's a barrow on site with a lot of concrete in it and collapsed against the wheel. It wasn't my lovely barrow fortunately but it seems to be mine now, to get rid of. Subbies will nearly always look after their own stuff better than yours. They will request plant that they wouldn't hire themselves, and better than they need. Then they will let the use, and hire, drift. BUT sometimes the right kit will do in minutes what will take hours without. What do you want, why, and for how long? Then you manage its use and condition. -
NO. I was involved with a sophisticated steel building system for many years. They were very strict about not overtightening and not using a torque wrench. It puts an unnecessary stress into the threads and the bolt into tension. It is known as "turn of the nut". Turn on to get a snug fit without noticeable effort. Then use effort to achieve 1/4 rotation. One heave on a big spanner basically. I will try to find whether it's 1/3 or 1/4. This applies only for steel and would not apply if the components were in good condition. The supplier wouldn't discuss if there had been previous problems, but it was clearly a big deal. Some erectors complained as they liked to use macho kit. Most accepted it. I did it myself on many foundation nuts. I think being feeble meant I got it right, but it was tempting to try to go tighter.
