Europe’s heatwave is the hottest and most humid ever
saveasteading replied to SteamyTea's topic in Boffin's Corner
That's the excuse of the less well informed that you are repeating. The vast majority of scientists are too busy being scientists (knowledge, analysis, complicated stuff) to get involved in politics. They are not inclined to lie or push propaganda either. They will also say' it isnt that simple ' unlike the worst of politicians who say what the audiene wants to hear, Those who don't understand science are often disinclined to believe just how clever some other people can be. If you excuse me I will exit this otherwise useful conversation: we self builders are designing with climate change in mid after all, and maybe become old if we can keep indoor temperatures in control. after passing some rather tricky exams at school . It's much easier to not understand and to assume it is bluff. -
Paint suggestions for cast iron please.
saveasteading replied to saveasteading's topic in Decorating
Because it has been blotchy for a while so not rally 10 years aesthetically. thanks for the names, Ill read up a bit incl Hammerite. Rustoleum I know the name, but the others are new. Only one typo is good going with my fingers. I dont fancy taking it down as it is probably 70 years since it was last fitted (we are told that the roof was originally shingles but didn't last long.) and will be 25 years older than that. Just the steel brush perhaps, then whichever paint seems to be the stickiest. -
Relax. The planners are well aware that the complaints were vexatious. if there are more then they will contact you. I've had such complaints and as long as you aren't deliberately cheating then it goes away or needs a simple resolution such as retrospective approval.. eg. to high? above what? they don't know. Too wide? an inch is not remotely significant. and so on. If you've added a wing or converted an attic without permission then that's different. Come back to us if there are any more contacts though, of course.
Looks like I need to do my own research. -
YouTube channels and playlists
saveasteading replied to Square Feet's topic in Property TV Programmes
I wonder, with many insurances being via comparison sites and tick list questionnaires, how often people tick the nearest description to theirs. This could result in a claim being refused. Insurance companies vary with some being fair and others being cynical claim deniers. I overheard a manager of one insurer (it happens that I'm seeing their name all over the place at present) saying proudly that they are by far the "most successful" in avoiding claim payouts. There appeared to be a league table of who kept most of their premium income. I think he said "we only pay out 40% of income." That was clearly a target. Ticking the nearest description would be an easy one for them to refuse on the grounds of inaccurate description. -
Sound proofing portion walls.
saveasteading replied to Russell griffiths's topic in General Self Build & DIY Discussion
Doesn't read like an ensuite door. -
Comparing this to the concurrent discussion on insurance of non-standard construction.... how many online questionnaires will have this option to tick? -
Hoping to do as few operations to this gutter as possible. A one coat solution would be welcome. Any suggested products? I last did that about 10 years ago using something like hammerite. As you can perhaps see it was onto variously the previous finish, an undercoat, or iron. Did I do a primer where it was rusty iron? Can't remember, but certainly only if the tin said I had to. Clearly the paint didn't adhere as hoped, or fade as anticipated. So, suggestions for minimal prep, over any surface, in green. Please. 🤞
I have been advised (off the record) that none of the wall constructions perform as well in real life as in acoustic tests. This is because the tests are not between real rooms, but through a central area of a panel. ie no flanking sound. The difference between grey and blue will be fairly accurate though. -
Proposed changes to building regs, limiting the use of timber
saveasteading replied to saveasteading's topic in Timber Frame
You speak sense. Insurers know nothing other than statistics and minimising risk (theirs). On the same course they advised that all the protection specifications are conservative. Eg a plasterboard manufacturer provides a wall panel for testing to half hour exposure, and it gets tested. After half an hour the test is halted so as not to survive an hour and confuse us with the possibility that fire board or thicker boards aren't needed for 1 hour. Similarly whether any jointing at all is necessary for fire purposes. -
That's extremely ageist as well as incorrect. Many of these persons at risk would have years ahead otherwise. I could explain but I don't think you want that. Good luck with your circulation in the years to come. You seem to be troubled, but this isn't the appropriate conversation, or help forum. Stay cool. 😎 -
You suggest 90mm studs. So you could use 90mm as the sole plate etc, then studs of CLS 63mm. -
Good suggestion. On a fire engineering course they explained how long a timber takes to burn through, as the outer faces first become charcoal which protect the core. Hence we see the skeletons of timber house fires, not a pile of ash. And even in a bonfire a 4 x 2 will last a long time. So are you suggesting that above 11m the whole structure gets more protection. Eg 1 hour fire protection gets 90 minutes? -
This from the Timber Development Association. A number of changes have been proposed to Approved Document B – the UK’s statutory guidance on how to meet the fire safety requirements of the Building Regulations. These changes affect the use of combustible materials – including timber – in buildings. We welcome some of the proposed changes, but there are others that we strongly disagree with. One change, for example, is to apply a height threshold of 11 metres upon any building containing timber in its elements of structure. Other changes require higher fire ratings for cladding, membranes and sheathing in external wall systems – which we consider disproportionate. I haven't read it yet but will do., and will respond if I see the need... which seems likely. Responses from individuals like us should have some weight as we have done it, or are about to do it. I have had most of my career in steel, but strongly support timber where appropriate. I've had a couple of run-ins with bco's on timber being 'combustible'. Even when completely encased in plasterboard, it is wood, and wood burns, so you can't use it, went the argument. These are not flexible people and are becoming ever less so., so ambiguity and global statements must be avoided. Plus I've met the sort of people who make these proposed reports and I wouldn't have given any a job. They tend not to be practical or fully understand the whole issue. In a domestic situation what is magic about 11m? as long as there is easy exit. I expect this all follows Grenfell which is fair enough, but common sense may not prevail. 'Something has to be done'. Pursue the guilty parties? Or reduce the use of a material which was not remotely implicated? https://timberdevelopment.uk/approved-document-b-you-have-until-wednesday-july-1-to-submit-your-response/?utm_source=TDUK+Contacts&utm_campaign=2eb47531a6-Designer+Update_COPY_01&utm_medium=email&utm_term=0_4619f835bd-2eb47531a6-223169024
Impact noise or airborne? For both, if you can spare a bit more wall width (how much do you have?) Studs twice, staggered to face each room with plasterboard only on one set of studs, so that you have physical discontinity. That deals with bumps and some loud noise, especially bass. eg a 100mm sole plate but 75mm studs lining up alternately with only one room or the other.. @ 600mm cc, twice, so actually every 300mm Then fill the void with any mineral wool, and you can even put some between studs and the 'other' side. It will snake. One sheet pb each side, possibly upgrade to the denser blue faced grade. for dB figures see the Knauff catalogue. That will be stunningly good, with the weaknesses being at plates to floor, ceiling and existing walls, so you'll still hear the vacuum bumping at skirtings. -
Very important. There are different grades of stainless too. I would only ever buy the big names and after checking the spec. It's not just the steel but the washer incl both the metal and rubber elements. And cedar and anything exotic should be researched.
It's a lot. The sun hits the shutter which , if metal, will be as hot as touching a car's body work. That energy would otherwise be beaming into the room. The Spanish ones I'm familiar with are roller shutters with about 3mm of foam. The inner metal face is still very warm but I'd guess 10°C cooler already. The heat dissipates by convection or wind , I assume. Then there is an air gap to windows as an additional insulater. For a timber shutter I'm guessing somewhat. It still stops the light obviously. Insulation will be much the same. The difference between inside and out on a scorching afternoon can be 8,9,10 degrees. 32 out and 22 in, say. That's with masonry walls and no insulation. That can still be too hot but gives aircon a good start if wanting to go that way. Otherwise it's a case of flushing the cooler air through at night. If a shutter is inside the room it let's lIght in. However I'm surprised how much an internal blind or curtain helps.
Not necessarily. It all depends on the ground, the design strategy and the resulting slab thickness. There is no one answer. But my instinct on good ground is screed (with heating pipes) over pir over concrete over stone. Tolerances getting tighter all the way. No groundworkers walking on pir or ufh pipes. The weakest part of that construction is the pir and the slab is obv much stronger but taking little load. I don't really know isoquick but feel it is a relatively conservative design, reducing risk for the novice but at some (considerable?) capital cost. Structural rafts on poor ground are a different matter. I can't recall ever using one, preferring beam and block (or plank) instead of stone and slab. -
Removing motorhome sealant.
saveasteading replied to TheMitchells's topic in Waterproofing & Sealants
That's so helpful. I was imagining sections lapping or butting together in a single plane. But with these defined angles could you leave the mastic in place and lay a large bead over? I leave proper experts on this to say yea, no, or maybe. -
I've only ever lived in draughty houses tho the steading is pretty well airtight but doesn't get stuffy. I'm of the opinion that the essential vents at fans and through opening of doors etc we get enough oxygen. But maybe when we relax and doze of watching Repair Shop it is lack of oxygen.
It shouldn't dry at all. It hardens chemically , but drying weakens it. A very light spray of water at most, then polythene over it, or hessian and then wet it. After a day it will be hard and can be soaked but the concrete should be kept damp for a week, (and isn't full strength til 30 days.) Then the small amount of free water can be allowed to evaporate.
Thanks. Warms the house rather than cools it but not a lot. We are simply leaving doors open after 6pm ish and the house cools ready to start again tomorrow.
Me too. It's remarkable how a very small leak will spread far and wide. If all your dampness was somehow collected, would it fill a bucket? No. A mug? Maybe. And that's been over a year or more. It could be just one pinprick of a hole in the mastic, if you could find it. @ProDave tarpaulin is such a good idea too. Simple and likely to be effective, and protects the mastic. -
Please help me understand? A fan takes the internal (24°C) air out, through a heat exchanger. It partially cools the incoming air currently at 33°C. What temp is the incoming air likely to be? I'm not understanding how that helps. I have to admit to scepticism in general, from a decade ago when mvhr systems were mostly inefficient bodges which the reps couldn't, or wouldn't, explain apart from ticking a sustainability box. We've gone Spanish. A bit of work outdoors early. 12 til 5 indoors. Evening outside. Dinner later than usually. (Football agony at midnight.) Curtains and blinds closed according to sun movement.
Could I do it? Is a good test. I might be very slow, but if I could do it then so can they, faster and sometimes better... especially if watched.
