saveasteading
    93
  1. I was on a visit to a school once where the sound from the rain on the roof was surprisingly loud. The head and trachers said they positively liked it, as a link to the outside and what sort of day it was. That wasn't one of my projects but i've done lots of schools and offices with metal roofs. I don't recall noise being an issue except on skhlights, so it must be in the detailing. Standing seam with an air gap may act as a (gentle) steel drum? But then there is the rest of the structure. Are there skylights?
  2. Then it dries? I appreciate that not everything with water in it is wet. I'm all for this being great. But they test it themselves while it's being applied. Next day? Independent testing would be comforting too.
  3. I hadn't come across this before but have now looked at the website. It doesn't give much technical information, which always worries me. Is it a spray of expanding foam that sticks at air leak points? Or a sort of fuzzy felt that does the same? So it is for where the intended airtight structure isn't working properly? Either to get building reg's or as a permanent improvement? Does anyone know...Is it messy? Is it permanently flexible? Is it ever used as the intended airtight barrier rather than a problem solver? Being a combination of cynic and innovator I'm confused and need more info.
  4. https://rawlplug.co.uk/product/wire-mesh-sleeves/ Seems to be readily available from specialist suppliers in UK too. this comes in kits or as 1m lengths. I have never used it so it needs further research. Even filling the gap to the insulation will provide a bit more stiffness. If this worked it could glue to the inner face and not need a bolt inside the room .....Maybe
  5. Do you have to cut out the inside of the block, where you show it recessed? That could be contributing to the strength, and as it's visible you will know it is doing something. Also you would have a conventionally fitted nut there, absolutely preventing the bolt from puling outward. If it can't pull out it won't fall down. Then on the outside, yes use a substantial washer plate to spread the load. The chances of getting any useful fixing on the middle fin of the block are very low. However, I have seen a system of inserting a mesh tube, like a stent, which is inserted into the hole and to which epoxy resin will adhere. It is much used in foreign climes where hollow bricks and blocks are the norm.
  6. 6 litres should do it easily, or there is some design flaw? You would expect that a big name manufacturer will have proven the design with EU standard testing 💩 modules. Sometimes the outlet pipe arrangement can slow the flow. Also. Is it clear which button is full or partial flush? It can be counter-intuitive, or it needs to be held down. Or for a concealed system using tiny air pressure pipes, they can be reversed.
  7. That's interesting that there is the partial use of brick. I can't think why. Are these slits all tapered?
  8. Is it on show in a room? We're doing one that is in a gable and is a void space. So we're putting battens on the internal face then polycarbonate. That leaves the full visual effect from outside and kills all draughts and sufficient heat loss. Where it will be visible in a room, we haven't done if yet. But probably a skinny frame about midway, ie what looks best as balance of seeing the feature and glass area. Perhaps a home made timber frame? I can't picture how frameless works in a tapering slot, with roughish masonry. There must be hundreds of examples, for better or worse. I think most conversions must blank them on the inside.
  9. It's in one line down the slope, so I'd say it is one screw at fault, at or above the start of the wet area.
  10. mortar should also be as strong and durable as possible (while still softer than the masonry). So I'd make local enquiry.
  11. As a slight divergence...this makes diamond drilled holes unsuitable for anchor bolts, unless roughened up with an sds drill.
  12. No. The lime for granite is the hardest grade, and it doesn't keep overnight. Your local BM should know the grade for your sandstone if it is a local product. However, I read that unless there is a quarry nearby, it is as likely to have come in by ship.
  13. I know. But I will try one of the above and report back. I cant remember if the rusty screw was provided or if its my own fault. Either way, in recent years I have invested in Fischer SS screws to fix showers and grab handles and am impressed with them...very hard head and a very good grip...and no rust.
  14. I've now seen SS plates on ebay, 75mm x 3mm thick. I suspect the 1mm thick will be not sit tight. Then just drill a central hole for the screw and plonk on with silicone.
  15. Yes, I've wanted for a while to go to one, out of curiosity. I'm vainly not expecting to learn much, but you never know. Sometimes , at such events, I amuse myself listening to the half truths and exaggerations of the sales pitches. And asking for guide prices is fun. I don't wind anyone up unless they deserve it. My main interest is observing the vibe and who is pitching at the potential self builder. So if anyone thinks they were mis-sold or has forgotten a vital name or information.... No promises though , especially if there is a wait. I'm also wondering just how big the interest is in these troubled times.
  16. Strong Acid on marble could be a problem. I've probably got spare tiles but rather not. I'm thinking of a Grohe "rosette" plate. 65mm. I don't know what their intended use is, but it should be OK.Except that I really need 80mm.
  17. Yes I'm afraid so. But if it went in, and it's visible, then Snibbo might also get in, and neutralise or remove it?
  18. Are you going to build any barrier over the gubbins to keep fingers off? I'm thinking of a stud frame with clip on panels for easy access.
  19. One of the screws on our shower has rusted to failure, leaving a stain. For replacement I will use a branded SS screw, as I always do, in recent years, for wet locations. I've tried baking powder, toothpaste, detergent, vinegar and all combinations ( yes, including mixing acid and alkali, as at least there is bubbling.) Any ideas? Perhaps a big SS or chrome washer if nothing works.
  20. I used them as door stops in the office or placed on shelves to look suitably techy for the industry.
  21. Only if there are thirsty trees nearby or your clay is very soft.. Most founds on clay are 1 to 1.2m. Otherwise it makes sense. So the planners haven't asked for a basement. Could subservience be provided by low profile extensions. Catslide roof? That makes it bow down before the other buildings.
