Which internal doors have to be fire doors? if any
saveasteading replied to Post and beam's topic in Doors & Door Frames
Your explanation should be line one of the fire section of the reg's. Maybe people who try to cheat the rules, and principles, will understand this. -
Does brick plinth really add expense?
saveasteading replied to flanagaj's topic in New House & Self Build Design
It must have something from the ground up to the timber level. If not shown on the planning drawing then that is a technical oversight. The planners will accept a clarification. Bricks are relatively expensive but are replacing something else....blocks or concrete usually. -
Just for my interest re ufh manifold
saveasteading replied to saveasteading's topic in Underfloor Heating
Fully ufh. There are 2 manifolds and this one is a long way from the heat pump and plant room. That would explain why this one has the 'short circuit' or figure of 8 principle and the other doesn't need it. -
Classy support equipment now for sale.
saveasteading replied to saveasteading's topic in Tools & Equipment
Got an answer from m y son-in law. Props. Selling these £500. the 16ft Plasterboard lifter selling for £250 NB this is much higher than the average lift requirement. Could potentially deliver them to someone not far from the M74/m6/m5 when we go down south with hired lorry this week.- 9 replies
- acrows
- acrow props
(and 2 more)
Gotcher. So the primary loop gets the hot water to the location, in a comfortably sized pipe with its own pump. Then the manifold and ufh pipes, with lots of resistance, draws the hot water from the loop with its own pump. Presumably both circuits turn off when there is no demand from any ufh loop. It's the first time I have poked at this in action. It surprised me how little difference there is in temperature between the feed and return pipes from each slab loop. But it makes every sense on reflection. There was even less difference in the feed loop but that is now explained too. The plasterboard jointers love the unusual luxury of a warm building and very warm floor. -
This is all working fine, ticking over with 20° feed to make it a pleasant building site. I'm just wondering what the cross pipe at the top is for, short circuiting the system. As it appears, the pump would circulate the water round and round the manifold, with no feed of heating water. So I'm guessing another pump somewhere forces the heating supply. But what is the function of that link?
Green roof DIY instal - any good supplier tips
saveasteading replied to markharro's topic in Flat Roofs
Bear in mind maintenance. Plants grow and die so may need maintenance and you need safe access. The membrane has to be roof resistant. Some of these are not uv resistant so perhaps a joint is required. Consider laying a grid to contain the plants. This is all very heavy (wet earth) and the roof needs to be designed for it. -
Not personally but designed and had it built where the original architect had included it., missing out the package deal people and saving a lot. So yes, you can buy the bits and do it.. Is this a requirement or your own choice? -
My instinct is for beam and block as the slope can stay put. The void may be usable as a small store, accessed from outside. Or as a big store for long thin things.
Friction and turbulence. The extreme would be a non moulded corner, and this is in-between. The same is happening in pressure pipes where sharp turns should be minimised. That's correct. And using too big a pipe can do the same. The range of gradients in the building regulations is slightly conservative but I stick to them to allow for real life level control.
size of excavator for baseworks?
saveasteading replied to sunflower's topic in General Construction Issues
Tempting, fun and macho to diy this. But a jcb with experienced driver can do it much faster and better. IF you are organised and in total control of line and level. Then he takes the machine away, leaving you space. But if you aren't organised, then your diy digger sitting idle isn't costing you as much as the other. -
Liquid screed max depth question
saveasteading replied to Post and beam's topic in Underfloor Heating
I'm at the steading and the floor I'd clear so i have looked closely at the finish. There are ripples which won't affect tiling but will need to be rubbed off with a stone where vinyl is going It is utterly flat. The official test is a 3m straightedge, which you lay every direction and also press down one end at a time. There is nothing noticeable at all. It's flat. It has done that by gravity so must be level too. -
Yes I've been low on expressing symparhy perhaps. I'm not an amateur yet stuff went wrong with our house refurb. I had the day job, building other peoples buildings and left the work to a very experienced and trusted foreman. Costs rose a lot, several things had to be redone. Gradually some poor work emerges. Things do go wrong, esp in remodelling or change of use.
It is a snaking channel. Look at the building regulations for drainage. Enjoy!
You would hope so. But common sense and fairness isn't the basis of our legal system. A judge would want it all pre-argued by construction specialists. Then they would expect arbitration rather than court. Yes, it would count that the builder wrote the contract rather than use a standard one..but it is still the agreed contarct.
That's exactly right. Water and contents going round a 90° bend encounters turbulence. That slows flow, especially of solids. Esp to be avoided for gentler slopes. Free water is also likely to run past the solids. Think bobsleigh going round a sharp bend. If it slings up high it is taking a longer route and slowing.
It's certainly in the building regulaions as an option. Space is the usual reason against it. . But for planning and proven P levels I've no idea.
Sorry, I think the planner is correct. They shouldn't be expected to make their own scale bar off your drawing, or calculate every dimension. It's good practice to state what the scale will be when printed at a certain size. Eg scale 1:100 at A3. That makes it easy for the planner, and also anyone else that wants to look, and they can use a standard scale rule. The same then applies for construction drawings. It's difficult but the above offers of assistance should sort it for you.
Timber Frame Soleplate overhanging cavity
saveasteading replied to john0wingnut's topic in General Structural Issues
If you imagine the overhang being cut off at 45°, the forces from the studs will transfer to the narrower wall. In theory it's a bit higher loaded at the inner edge, but probably ok. Double up the sole plate and it will certainly spread the load.
