saveasteading
    93
  1. You are right. There is no excuse for this lack of info. It would matter a lot if it is tight connecting two fixed end levels. Also, for a long run, the total depth can add up to become unnecessarily deep. Can you put the main runs in a line and still get branches to connect properly at the higher level? Go to your merchant armed with a spirit level and tape.
  2. Dismantling is a nicer word than demolition that doesn't change any need for a demo notice. But I don't think that is a 'building'. It is a shed and they normally don't need a demo notice.
  3. I put a standard wc up on a wooden plinth once. About 75mm up from memory. It made a huge difference for the elderly person concerned and most others were ok with it. The advantages were total solidity, it looked just like a normal wc, and no loose bits to feel insecure, to get lost or to clean. Sadly it became redundant but it could then be lowered to normal height if so wished.
  4. Good question. I will accept any and all advice on this subject please. I don't have an electrician yet , hence needing early advice. such as.... are these radius ducts standard things? do they have to point one to the rear and one to the side as shown? Chuckle. I was thinking of going all diy and amateur and buying 3 bags of ready-mix to make the base. I saw reviews of it, and at first thought they were wind-ups... *when you buy a bag of "Concrete" you don't expect half of it to be chippings! no mention of this in description just a waste of money *Absolutely crap and useless stuff!!!! Most of it are stones! The rest is runny water based- cement colour water!!!! Avoid! Waste of money I wish I would just buy bag of cement and sand. This amount of stones is only half bag of 20kg total bag!!!! And grey water. Disgusting. I have a feeling they both added too much water.
  5. GRP ELECTRIC METER BOX W605 X H1150 X D320 MM , NEW ELECTRICITY CONNECTION £618 incl VAT so that is the right direction thanks. Ahhh. I will bear that in mind. Also re the size. For interest , why do they make 72 variations? I was starting to think the box might be too small. We are going to have a 60m cable onward from there to the house. The location is to stay within 25m of the pole, and keep it as 'minor' works. The box and connection is going in earlier than we wanted, but to please the neighbour/ vendor.
  6. Do it then reverse the spirit level. They are often inaccurate. If you get the same bubble position then you have confirmed the accuracy. If it is a different position then the average applies. a 2p coin is about 2mm thick.
  7. I have engineered flooring that has generally stayed flat but one are has developed a small bulge 10 years later. So, yes it needs allowance for expansion. I had a 'disaster' with non-engineered glued down parquet. I laid it with a 12mm cork surround and it expanded, and made a foot high bulge in the middle. Re-laid with 24mm cork surround....and it shrank leaving gaps all over the place. In any case, the edge of the wood needs protection at the edge into the doorway, especially if cut, so a simple T insert threshold is advisable.
  8. Having a precise specification from UK Power for a new 3 phase supply, I was surprised to see so many different sizes being available, and it is not easy or quick to compare sources. Many are slightly smaller which seems very odd. w600 xH1100 X d300 is the requirement and here is one such. It seems expensive for what it is, and such a standard unit. Any suggestions please? Free Standing GRP Electric Meter Box Green – W600 x H1100 x D300mm, GRP Cabinet , GRP Kiosk £691.20 Incl. VAT
  9. Tent pegs is plenty.but so should be the nails, on angles. Plants will catch the wind bug also anchor it.
  10. Ask your architect to avoid trade names. Not even Kingspan or equivalent.⁸ If you phone a supplier and ask for Kingspan, they aren't supposed to offer any alternative.
  11. That is very specialist. A masonry wall should be half the price.
  12. @bassanclanyour post has settled in the wrong discussion.
  13. I found the hard pointed tile bits to be good First put a bit of Sellotape (other clear sticky backed plastics are available) over the drilling location and it will hold the tip and stop the glaze chipping. these are at SF too. I think I'd buy a big brand though, or from Topps.
  14. Rather than battens? How about the resilient bars fixed to a cleat or block of some sort, so that there is rom for cables? I might think this through and patent it.
  15. No it will not. Try some held under water. It will pop up and be as dry inside as when it went in. you can, in that it is allowed as long as a minimum level is maintained for he each element. I have not found this, so I suspect some flanking path. But you are right that a sandwich PIR will not be as absorbent as a mineral wool one. I have to admit that dew point is not something I've ever calculated, so must have been lucky every time.....or it isn't much of an issue in real life and normal room conditions.
  16. Probably not applicable to you but. Lindab told me that their copper effect finish rwp is often stolen on the assumption that it is made of copper.
  17. It's like being reluctant to have a roof. Gutters and downpipes are the only right answer. Lindab is elegant and precise. I've got about 12m of it with special bends. 15 years on still looking good. Just think carefully on the position for the downpipe, and choose a colour to blend or contrast.
  18. I thought it was about as relevant as I've ever been.
  19. 150mm blocks are usually 140mm or so. Don't ignore B and Q and Wickes. Their prices are sometimes better than the merchants. I got half a lorry load from B and Q once, as they beat Travis P. They turned up on site delivered by TP.
  20. The area of wood increases and of insulation decreases. Prorata the area to get the 2 values.
  21. Agreed. We fretted over losing 100mm of the effective width. As finished it doesn't cross our minds that it might have been wider, especially sitting in the cosy space. Yes optimise the space if there are no other constraints, but build quality comes top.
  22. that is fine and what it is for. it will prevent stone pushing down and mixing with mud.
  23. I see downsides. Big stones will be isolated on either side of this mesh, reducing the interlink, thus reducing the strength. How would you support it? Why not give it away? If it was useful for concrete I'd expect it to be advertised for it.
  24. That is within. Then there is some on the inner face. We've got about 10 construction details because it is 3/4 convert and 1/4 replace.
