ETC
Everything posted by ETC
Put the DPM above the slab and look out for cavity tie locations in relation to the height of the tanking.
Hmm. Sounds very strange. I thought from an earlier post that there was a suggestion to use a straight through vent and keep the FGL down as far as possible. Would also negate the need to drain the sub-floor void. Pity the void wasn’t filled. No void - no ventilation.
Sorry for being stupid but is the sub-floor block work solid and if so how will the telescope vents work if there is no cavity to hide the vertical riser? Or are you just going for through wall vents without the riser? Thanks.
Shouldn’t there be at least 100mm bearing for the outer leaf at the top of the plinth? I’d love to see a section detail through the plinth @LA3222. I’d have thought it would have been better widening out from 100mm brick down rather than up.
Post some pictures please.
Speak to a passivhaus designer/architect. There are plenty out there.
Agree with @Declan52You’ll need about double the amount to get the same u-value. Check with your SAP assessor before you set your ground floor build-up to make sure you’ve left enough sub-floor depth. You’d be surprised how easy it is not to lay floor insulation properly. Where pipes are placed below the insulation the back of the insulation is - in many cases - hacked out to let the pipes sit comfortably within the insulation and in some cases the PIR insulation is fixed through the DPM to the floor slab. Solutions I see use two or more layers of insulation so that a single layer is cut between the pipes and the remaining insulation installed above and flush with the top of the pipes. But where there are placed pipes below the insulation there will always be some gaps in the insulation. I have also seen insulated pipes installed above the floor slab and then just enough insulated floor screed put down to cover the pipes then PIR insulation put down on top. Granny and sucking eggs but don’t forget: That the insulated floor screed will not replace your sub-floor slab. A DPM needs to go down before the insulated screed - and it needs to be 1200 gauge. You will need a VCL and perimeter insulation. Don’t fix any pipes through the DPM. Don’t fix the PIR insulation through the DPM.
That’s the best advice you will get. Retain the existing front door, redecorate the door and possibly think about some new brass period door furniture. You may even think about a stained glass panel in the door but if the glass is original it should be kept.
Don’t see the big deal. Put the sockets in at the required BC height.
A Building Regulations application will be required for the works irrespective of when it was carried out. It’s called unauthorised works and it always comes out in the wash. Don’t hide it - get proper advice from your local BCO.
How to reduce thermal bridge / draughts with RSJ beam
ETC replied to WWilts's topic in Heat Insulation
Wouldn’t worry too much - you’ve a massive window right next to it leaking heat. -
Pump it. -
Our regulations ask for reasonable sound resistance to be provided between a room containing a WC and any other room AND a bedroom from any other room. Sound resistance is not required to en en-suite or to a wall containing a door.
All this to clean a roof light? Jeez - dump the roof light and put in a light bulb!
Advice Needed - Cold Bridge Behind Full Fill PIR Insulation
ETC replied to Johnny Jekyll's topic in Heat Insulation
Having looked at the photographs it doesn’t look that bad. Have you tried pulling it in? Could you drill a few holes at say 1200mm horizontal and 900 mm vertical centres in the inner leaf from the ground floor up and pull the insulation towards the inner leaf and mechanically or glue fix to the inner leaf? Just a thought. what breed of insulation did you use? -
Remove as much of the cavity insulation as you can and pump the cavities. Or discount the insulation already installed, speak to your SAP assessor to run a new SAP with internal wall insulation. Guessing an insulated plasterboard thickness is a waste of time - the TER/DER needs to work with this new thermal element. As an aside I’d be a bit concerned if the boards were - at some time in the future - slip, touch the inside of the outer leaf and act as a bridge for moisture/water to pass across the cavity. -
Seems like a lot of energy spent on this thread. Simple answer - remove the access to the roof! Why on earth would you you need access anyway? If you need to to maintain it (once a year) get a specialist cleaner in with a cherry picker.
Get the brick/block layers to take it down and rebuild it with the insulation tight against the inner leaf. They should have been using wall ties with retaining discs on them. Not acceptable to you or to Building Control. -
New build floorplans - opinions welcome
ETC replied to Indy's topic in New House & Self Build Design
Glad you like it. Please let me know how you get in with your architect and please post your final design. I’ve suggested moving the front door and providing a small flat roof L-shaped canopy in zinc over the front door which I think could be a nice contrast the rest of the house.
Have you thought about the office as part of the entrance hall/circulation space or do you want it behind closed doors?
That’s a big house.
