Oz07
    6
Everything posted by Oz07
  1. Let's hope OP has a commercial bread oven to hand 🤣
  2. Do you mean structurally or thermally? Structurally if they've lasted this long then should be fine. Must have quite a few intermediate walls? Thermally as @ProDave says be a hell of a lot better than nowt. Some modern houses still have 4" in the cavity.
  3. You'd be closer to 4 quid a meter or thereabouts where I live but difficult to say for Scotland
  4. What do you bed your trays on @Nickfromwales
  5. Can you pull your paths away from wall of house by like 2 or 300mm?
  6. Dunno if short for owt but yeh midlands.
  7. Compo here. As in "COMPO ON THE GABLEEEE" no please or thankyous.
  8. I had tanking peel off 1 wall before tiling once. It was the external wall and I wonder if the plaster hadn't dried enough to accept tanking. I stanley knifed up 1 corner and peeled it off in sheets. The 2 other stud walls were fine. It must need a good dry surface to adhere properly. Ive used it on other projects no problem but usually on stud walls
  9. Aco in the potential pond then. Most bco would want to see dpc 150mm higher than external ground id have thought
  10. Is it a truss or a rafter? Not to be pedantic but one is a lot easier repaired or replaced that the other. As it is probably be fine. How far from that horizontal ceiling to a purlin if that is a rafter?
  11. Sounds fine some will do it tight the trays can accommodate the thickness of the tiles overhanging on them usually
  12. Ive seen big commercial renovations where they just use metal stud with rockwool behind and in-between. This is on 9" solid brickwork. Surely if good enough for that be fine for modern cavity?
  13. Yeh my incoming was dirty, the outgoing I just found dusty. It is satisfying seeing all the crap its catching. Expensive satisfaction though
  14. Need a big old hole for the proper site gates. I think heras would be fine without the netting but you want the privacy
  15. You'd use metal studs with the brackets and rockwool its easier than timber stud
  16. Do you change or clean the filters? Mine were washable
  17. I don't think it's possible now on the buying side. Im going through the motions on a plot atm and the vendors solicitor couldn't even communicate with me because of law society rules. I said to the agent what if I was diy conveyancing he didn't really have an answer apart from its rare. Also the money laundering regulations are insane now I don't know how you'd convince vendors solicitor your money is legit.
  18. I've zero rated jobs in the past there is no form you have to fill in with site details. It would only ever crop up if investigated and I think as long as vat man can see a newbuild has been built at x address which your invoice is for you're good to go. The works could of potentially been done months before its invoiced out.
  19. Good point, me too. If its only the skimming labour could you not find someone who isn't vat registered? They're gonna put a markup on any materials they supply I'd have thought.
  20. Is there a minimum vat reclaim amount? I have seen somewhere councils can verify bng self build exemption by way of proof of vat reclaim rather than Unilateral Undertaking. If using a contractor to build and they are zero rating could you literally buy just like all your driveway blocks at the end and claim for only these? I suspect you'd get a phone call but surely couldn't be refused? There must be similar occurrences where people have employed a contractor upto a certain stage then finished off themselves?
  21. It's more a question of if you can convince the trade to zero rate as part of newbuild. It seems a grey area to me on a diy vat reclaim you'd probably get rejected but as your doing works as part of the planning for the new build if you can convince them to zero rate I'd probably go for it. Liklihood of them being investigated and vat assessor then researching your completion date would be small I'd think. Your probably going to pay more in profit and overheads than the vat you will save if you get contractors in. Are you are able to diy?
  22. I have an expandastore they can be put up and taken down by a few guys. Can be handballed around when in pieces. Don't see how it solves your problem entirely though.
  23. More jobs for the boys. Bureaucracy gone mad.
  24. Every time I've had it done its been less than 500 quid. The cheapest service by far. I think it is subsidised somehow because I can't see them doing the job for that.
  25. I did wonder as you said your windows were made locally. Why could they 3g the windows but not the door?
