Oz07
    6
Everything posted by Oz07
  1. Was there a bit of controversy with strength and cement content with these ready mixed mortars? Glad to hear its holding up ok. You cant trust these young brickie labourers now I see them squirting the plastersiser in like its water.
  2. You're the science boffin whats the theory on the copper?
  3. I'd be tempted to try to copper on a newbuild. It costs next to nothing while you're up there on the scaff. Id guess a window cleaner would want atleast 50 quid to clean them especially full 2 storey. That's a chunk out of your return each year
  4. I just thought for the sake of a few blobs of silicone or something and a coil of copper wire when installing. Would it be effective or is that a myth?
  5. This one as well maybe more SSW but you can see in full sun. Maybe older panels and protective coating wears off?
  6. SE I would say
  7. Seen some panels with moss on today walking around. What's the way to keep this off? Regular cleaning or can you just stick a length of copper wire to the house ridge or at top of panels?
  8. I meant the mist coat super diluted. There must be a way to make it stick to another paint else they are basically saying you need a fresh plastered wall if your going to use this paint ie not suitable for existing walls without re skim.
  9. Are heat pump warranties 10 years or more like a boiler? Genuine question I've never looked in to them
  10. What about if super diluted? Still same?
  11. Gas won't be phased out before your boiler packs up. Or if it is you have a really well made boiler.
  12. Is there any universal mist coat you can use? I used that cheap Leyland in last place for mist and put the dulux diamond matt over the top no problems and that was pretty expensive paint
  13. Keep till the boiler packs up. Likely 10+ years.
  14. It's difficult to guess in that case then. I doubt you'd have a flat roof in that space. What id guess is a 3x2 or 4x2 timber plate ontop of your window, following each section, then some ceiling joists resting on this plate or window heads, then your rafters joined to these. With a brick or possible stud wall in line with first floor wall as you've said it used to be a bungalow
  15. Ok then well its probably a lintel in line with first floor walls and the hipped roof built off this resting on the bay window. I doubt its your floor joists cantelivered out as your ceiling is flush inside. Can't you go upstairs and check out the wall below that first floor window? Knock it is it solid or hollow.
  16. It's a modern house isn't it looking at the brick bond? I'd guess a mono truss arrangement above window although might be wrong as its hipped
  17. Do you pull the applicant name and details and write them letters ? Dear sirs seen this on planning portal would be interested in purchasing for family home etc etc
  18. Yeh I know about the cuts being cracked control done it plenty. Just curiosity post people tend to tie ufh pipes to mesh if in slab or alternatively clip to insulation if in screed. Was wondering if the pipes accommodate movement ok if in actual slab with no mesh
  19. Research height above plate. That's what you're trying to match if you want to keep everything in plane up top.
  20. FYI this is exactly how I'd expect a frame to be installed in an existing opening. End of story. What would you propose as an alternative chat gpt?🤣
  21. I think these responses are being written by AI Is there any way bots can join the forum and post these type of queries or is op just utilising ai to draft their responses. You suspect the original query is copy paste due to the formatting. There have been a couple of posts on this forum recently that make me suspicious. The user the other week quoting replies and inserting spam links.
  22. In this case I doubt it will be noticeable. It normally happens more when you have a bastard valley. The ones you see are not purposely setting it lower they are just keeping the internal line set flush to the rafters Think of it if you cut a 6x2 at 10 deg it will be near enough 6" across the cut, cut it at 45 degrees and will be a lot longer.
