Oz07
    6
Everything posted by Oz07
  1. I still don't think penetrations in the main fire stop ceiling would be good. Probably have to fill the gap between board and light with intumescent mastic. What about standard pb double boarded. 15mm if nessecary.
  2. The building in question already has permission to demolish from current approved planning. That's why I can't see how they could require a new survey as you could knock it down currently on existing permission.
  3. Without side tracking the thread. If you already have had a survey confirming no bats how long is it valid for? Could you use it on a fresh application within 6 months/1 year/2 years etc or does it always require a new survey? In which case cheaper to demo roof pre application
  4. How thick are these led lights? You could just fire plasterboard the whole ceiling, filling joints if needed for fire regs, then fit your lights and standard plasterboard underneath. Maybe some battens sandwiched between if you need the depth for the lights. Make sure joist and truss manufacturers allow for the extra dead load on ceilings.
  5. How much is your gas connection? Where i am the quote is normally in the hundreds not thousands. Like @Mr Punter I'd be wary of solar and heat pump on a spec build. Your house won't fetch any more money for having pv. They can always retrofit this themselves if the calcs work for them. Or do you need it for SAP pass? Same story with the hear pump. You won't realise any more money for fitting one so just weigh up what is more expensive to install. Like @Mr Punter says you may in fact have some customers put off by an ASHP. It doesn't sound like they have a good rep round your way and the average punter is not going to be interested in visiting buildhub to find our how good they can be if they already have a negative perception of them.
  6. Why is this any different to a normal gable. Some straps off the timber at the top of the wall built into the inner leaf. Job done. Why complicate it? What am I missing? Some wall start ties tek screwed into that steel post if advised by se.
  7. Ok I was only counting above dpc. Not sure on the rates down there. So you've got more like 9k bricks so around 7 grand plus 550m2 blockwork so around 11 grand. 18 grand plus a bit for extras lintels etc. At this point your best efforts are spent finding some trades people. Pop in merchants get prices for your gear, mention your looking for some brickies. Just get the word out.
  8. The 45k over price is a not interested price just forget them. Keep trying to find people you have a connection to. Building is quiet atm
  9. What are your labour figures for superstructure in that estimate? 400m2 blockwork around 8k 7k bricks around 5k 13k Is that anywhere close?
  10. What estimator did you use. 3 weeks sounds a bit quick to me but I've not seen or can't remember the plans or elevations. Whats your quantities or brick and block. If you were to allow maybe 75 pence a brick and 2 quid a block down your way does that get you somewhere in the ballpark? Very rough and im not sure of rates your way. With regards to getting some decent quotes try to get an introduction or reccomendation off other trades or previous customers. That way your not a cold calling random you're ringing them up saying I know X who's extension you built or I know X plumber who has worked with you guys says you do a decent job etc
  11. Tbf who is going to self build anything other than detached?
  12. I think their planning is a lot more zoned than over here. I assume providing you build within certain parameters planning is automatically given. No silly planners going on about vernacular on a modern estate. You look at the quality of design of houses here before planning was brought in (1940s?) vs after. Which houses look better?
  13. Let's hope OP has a commercial bread oven to hand 🤣
  14. Do you mean structurally or thermally? Structurally if they've lasted this long then should be fine. Must have quite a few intermediate walls? Thermally as @ProDave says be a hell of a lot better than nowt. Some modern houses still have 4" in the cavity.
  15. You'd be closer to 4 quid a meter or thereabouts where I live but difficult to say for Scotland
  16. What do you bed your trays on @Nickfromwales
  17. Can you pull your paths away from wall of house by like 2 or 300mm?
  18. Dunno if short for owt but yeh midlands.
  19. Compo here. As in "COMPO ON THE GABLEEEE" no please or thankyous.
  20. I had tanking peel off 1 wall before tiling once. It was the external wall and I wonder if the plaster hadn't dried enough to accept tanking. I stanley knifed up 1 corner and peeled it off in sheets. The 2 other stud walls were fine. It must need a good dry surface to adhere properly. Ive used it on other projects no problem but usually on stud walls
  21. Aco in the potential pond then. Most bco would want to see dpc 150mm higher than external ground id have thought
  22. Is it a truss or a rafter? Not to be pedantic but one is a lot easier repaired or replaced that the other. As it is probably be fine. How far from that horizontal ceiling to a purlin if that is a rafter?
  23. Sounds fine some will do it tight the trays can accommodate the thickness of the tiles overhanging on them usually
  24. Ive seen big commercial renovations where they just use metal stud with rockwool behind and in-between. This is on 9" solid brickwork. Surely if good enough for that be fine for modern cavity?
  25. Yeh my incoming was dirty, the outgoing I just found dusty. It is satisfying seeing all the crap its catching. Expensive satisfaction though
