Everything posted by Adsibob
How to keep a toilet roll dry in a wet room?
Adsibob replied to Adsibob's topic in Bathrooms, Ensuites & Wetrooms
If it wasn’t for my allergy to chrome, this looks like it would tick all the boxes: https://www.google.com/aclk?sa=L&ai=DChcSEwjL3Iz9r9z0AhXP3-0KHbGJCgEYABAJGgJkZw&sig=AOD64_1qB5NoZEDyzMrzY2KxoHNIiwwMnQ&ctype=5&q=&ved=2ahUKEwju8oL9r9z0AhV1nVwKHe9VBnoQwg96BAgBEBs&adurl= -
I probably should have said at least 10 or 11. Don’t they say 12 is ideal?
Yeah, that sounds like it works well. But I didn’t really want to introduce anything else into the bathroom as it’s really small already and having any screens, even partial screens, other than the 550mm one already shown will make the shower feel a bit cramped. So was really just looking for a way to house the toilet roll. -
Bathroom Furniture/Suite Supplier Recommendations
Adsibob replied to Matt60's topic in Bathrooms, Ensuites & Wetrooms
There is a company called bathroombydesign which is quite reasonable for supplying most branded stuff at a discount, but you have to ask for a discount, and then when they give you the discounted price, so for a further discount. I didn’t use their design service, but it is probably reasonable. You can also design yourself, by observing a few guidelines: - avoid placing toilets opposite doorways - make sure showering areas are spacious, smaller than 800 by 1000 not recommended, bigger is better - remember that if a wall hung toilet goes on a solid external wall, you will need to build that wall out to contain the frame - pay attention to matching finishes - don’t skimp on brassware - if installing a free standing bath tub, make sure you have plenty of space around it, as they don’t look good right up against a wall -
If you want to insulate against heat in summer, design your walls and particularly your roof to have space for thick slabs of wood fibre. At least 140mm. From memory, we did 140mm steicoflex plus 40mm of Steico hardboard. You want to aim for a decrement delay of 10 or 11 hours.
That’s not really doable or desirable. That’s not really doable or desirable. I was thinking something like this might work, but I need it in either a matt black or brushed brass finish. Plus, this is crazy expensive for a TP holder! https://www.parkstreetbathrooms.com/Store/product-details/Axor-Urquiola-Toilet-Roll-Holder-42436000.htm?utm_source=google&utm_medium=organic&utm_campaign=surfaces&gclid=CjwKCAiAtdGNBhAmEiwAWxGcUhYscPWapZjL5LIw40_qeqhdbGoSlDKL203ZRmH7Zy7dK8p4aB-yoxoCl74QAvD_BwE -
How do you keep toilet paper dry in a wet room? I’ve seen the TP holders that have the flap of metal over them, but they look badly designed to me. Below is a picture of my rather small wet room. It would have been smaller but I made the architect borrow a bit of space from the corridor to make the shower further away from the toilet. Maybe I should just place a roll loose on the window cill but to me that looks awful.
It’s a mist system, so puts out aerosol sized particles of water. for some reason it needs to go indoors,,I guess to stop it freezing.
No, I know nothing about it, other than it is cheaper. I only need 15m or 16m as I had already bought quite a bit of pro clima with which I’ve done most junctions. Just have a sliding door frame and Velux left to do. One Pro Clima tape in the 150mm width was going to cost £96 inc delivery + VAT. This worked out at £54 for a slightly shorter 25m roll (but still 150mm wide).
In the end, I’ve given up on Pro Clima. Have gone with Isocell Airstop Flex Adhesive Tape, as is about 25% cheaper.
The wall is a bit tricky to describe. It's an original external brick wall of a 1930s semi house (no cavity, just double brick). But because the wall was rather damp, a RICS surveyor advised us to line it with a breathable membrane and then put metal studs in to create an air gap and then plasterboard onto those studs. So it's effectively a stud wall fixed to an old brick wall. I can't really make it floor mounted as no space. Other option is to suspend the shelf from the joists above, which are brand new posi joists, though the chipboard floor is already down, so only way to hang from them is to hang from the bottom joist, but I guess that's okay? Will complicate the ceiling closure. Not possible to hang from another wall or two.
I need to fit a water tank that weighs 40kg quite high up on a wall in my utility room. This is for a sprinkler system pump/tank and the company fitting it has said that normally they only fit these things low down, but that they are happy to bring specialist lifting equipment on the condition that I build a shelf and demonstrate that it is "sufficiently reinforced" to hold the weight of the pump/tank. The shelf needs to be 700mm in length and 350mm in depth. The issue is that not only do i need to build something that will hold the weight, but it needs to be perceived by the sprinkler company to hold the weight, and I don't know how strict they are going to be. Anyone recommend any heavy duty brackets? What shelving material would you use? 24mm ply? Metal? Don't want to spend too much, but need it to be strong.
I actually only need half a 30m roll (the really wide 150mm one). If anyone has some to sell, I will happily buy it off you if you can post it first class to London by Friday (I need it next week).
FFS!!!! Just got this: Good day, Your order 306-4262660-4493149 from the seller Latzel Dämmstoffe GmbH & Co.KG has been canceled. If payment has already been made for this order, we will refund the order within 5-7 working days. The article is currently not available. If you are still interested in the item, you can place a new order at Amazon.de at any time. Below you will find the details of the order again. We are delighted that you are our customer and hope to see you again on Amazon.de soon. Amazon.de
amazon.de is not the cheapest, but they claim to deliver within 5-6 days and usually amazon's logistics is second to none. I only ordered one item, so I will be below the £135 gullibility threshold set by Boris. Above that threshold, I'm not sure if amazon.de include the import tax for you but I suspect not. It really beggars belief how so many people still think Brexit was a good idea.
I recommend this German site: https://www.amazon.de/-/en/Moll-Tescon-Vana-Allround-Tape/dp/B001QSE8NK/ref=sr_1_1?keywords=pro+clima+tescon+vana+tape&qid=1638894113&sr=8-1
How to build a cheap but secure bike shed?
Adsibob replied to Adsibob's topic in Garages & Workshops
I think I need to clarify my original question. I've already decided to do the walls out of block, so it's really about figuring out how to find a secure sliding gate and how to attach that to the blocks, and then how to build the flower bed in a secure way that also has a pitch to it. The bike will be locked inside the shed with a fairly substantial "gold" rated lock. My "gold" rated lock requires 30 minutes with an angle grinder to break through it. Our bedrooms are just above this bike shed, so as long as breaking into it takes at least that long and requires making a lot of noise (which I imagine it will), it will be pretty secure at least when we are there. The alternative is to buy something like this: https://www.gardenstreet.co.uk/garden-storage-c14/bike-stores-c21/trimetals-protect-a-cycle-store-p4424/s10212?cid=GBP&gclid=CjwKCAiAhreNBhAYEiwAFGGKPPzi7XQQOlvabHS0FaOPsOCl2sDW75sKQcLqGkiod7EqnPjicvVTAhoCp_MQAvD_BwE but I'm hoping to be able to build something which is slightly nicer for less money. -
I've already agreed the price for labour and wire. I just need to supply the actual detectors. The TLC site has a few options: https://www.tlc-direct.co.uk/Main_Index/Fire_and_Smoke/Smoke_Alarms_Mains_Lithium/index.html I guess I'll have to start researching this as well.
Just learning about this after a conversation with our BCO. How much do I need to budget for 9 x LD1 smoke alarms plus 1 heat alarm that are all mains wired and interlinked?
Hmmm … I now need to remortgage to find an extra £50k. Ouch.
Libel/defamatory comments on planning application
Adsibob replied to Omnibuswoman's topic in Planning Permission
@Omnibuswoman sorry to hear you are going through this, sounds awful. If it really is libellous, you should sue both the council and the neighbour in question. Libel is quite a technical area, so worth running it by a specialist. Carter Ruck is a law firm that is well known in this area. They might give you an initial consultation over the phone for free. -
I want to get a slotted basin waste to match my vado brushed nickel basin taps. The only option appears to be this: https://www.vado.com/individual-ind-395-brn According to the video on that page, this will work just as a slotted waste, which is important to me because it's a kids bathrooms so needs to deal with a situation where they leave the tap running. Will this definitely act like a slotted waste? Or does it depend on the sink?
I recommend using floor tite screws, not nails. Use the opportunity to fasten down any that might have even the tiniest bit of squeak to them.
