Everything posted by Adsibob
Except that you can hook it up to one of these https://www.viessmann.de/de/wohngebaeude/photovoltaik/stromspeicher-systeme/vitocharge.html and store the electricity.
As i mentioned earlier, the Veissman converts the methane gas coming into the house into hydrogen and hot water. There is some C02 by-product which is emitted, but my understanding is that this is 40% less than that which would be emitted by a gas boiler to make the same amount of energy. The hot water is stored so that it can be used later, when needed. Just like you would with a system boiler.
But that is not a fair comparison because green hydrogen is not available now, as you point out. The comparison I was making was against a regular gas boiler. The fuel cell is greener as less carbon emissions overall.
well the process is quite efficient because most of the energy lost in that reaction is captured as hot water. It is not a silver bullet to all of our problems, but it's significantly cleaner than burning gas, and doesn't need to wait for the network to be converted to hydrogen, which will take years!
We didn't even use primer, what's that for? We've only tiled about 20% of the area we are tiling though, so still time for the rest of it to be primed if necessary. But my screed must be pretty dry by now. It was poured 113 days ago and is 75mm to 80mm thick. I think we have another week or so before we do any more tiling. Should we prime it?
This was the thing I was talking about. It's actually bigger than I had remembered: https://www.viessmann.co.uk/products/combined-heat-and-power/fuel-cell/vitovalor
You can already get a hydrogen boiler. Veissman make one in conjunction witha Japanese company, Panasonic I think. It makes the hydrogen from the existing methane gas supply. A useful byproduct of this reaction is hot water. It is really bloody clever. I was going to get one, but it took up slightly more room than I had. They are about the size of a full size fridge.
'Nother fine mess: too tight for fireboard and comfort
Adsibob replied to ToughButterCup's topic in General Structural Issues
She didn’t I’m afraid. I don’t think the report even mentions his name. -
I hope you don’t need anything in between screed and tile, because we haven’t! i think people only use ditra Matt when they are worried there might still be movement in the screed. If your screed has fully cured, and you’ve done the UFH heating cycle recommended by your screed manufacturer, then I don’t think you need ditra.
can anyone recommend a LVT flooring? (Glue down)
Adsibob replied to Mike_scotland's topic in Wood & Laminate Flooring
We laid it in an entire 800 sq ft flat, except a bathroom, so maybe 725 sq ft in total. Really no issues. You leave an expansion gap at the perimeter and that gets covered by skirting board. I'm not even sure the xpansion gap was necessary as this is an engineered fibre board that is coated with a laminate "photo" of wood. Not like real wood that does have some movement to it. -
Not sure. You could probably glue it down, but I'm not really sure why you would want to. It works perfectly well with UFH even if not glued down. I had it at my last place as a floating floor on cellecta screedboard and it felt super solid. -
Pergo is a really good quality laminate plank that looks and, subject to the following, feels like real wood. Apart from the fact that it feels ever so slightly colder than real wood (because the material it is made from conducts heat much better than wood, it is hard to tell the difference, other than the fact that it won’t age. It can be laid in kitchens and it’s really strong. I got mine for about £32 a square meter. Pergo will send you as many free samples as you want, then you buy from one of their suppliers, like Domus. -
Comedy show indeed. I have found some grout that describes itself as suitable for joints that are 0mm to 5mm thick: https://products.kerakoll.com/en-GB/p/fugabella-eco-porcelana-0-5 hmmmm... now I'm really confused.
Keen to get started! If only I could find an architect...
Adsibob replied to jno's topic in Introduce Yourself
With Energy prices so high, I think a passive house will be highly desirable -
But I thought the problem with grout was that it wouldn’t adhere within such a narrow gap? The gaps are probably 0.5mm wide or less.
Thanks. Any particular silicone you recommend?
I think their view is clearly set out in the material you found, which is very helpful, thanks. I’ve emailed it to the architect and given him a telling off and told him to stop instructing non-standard working techniques. It is odd though, because the builder (who did some of the grouting himself) was also reassuring me that this wouldn’t cause a mould issue because the amount of water in question was so tiny and almost all of the 6mm thickness of the tile has been packed out with adhesive. Does it make a difference that all water in that shower area is softened with salt? Reminding everyone that we are talking about a crevice that is less than 0.5mm thin and 2mm deep.
Architect is now saying they will fill it with very runny grout or ask the stone guy who is coming tomorrow to see if he can fill it with silicone. But I agree this is really starting to get ridiculous.
They were cut with a water jet cutter, off site, about 3 months ago. The porcelain is this stuff: https://www.marazzitile.co.uk/collections/grande_stone_look/piastrelle I wouldn't have thought it was porous, but what do I know.
Yeah, on reflection I really don't understand why they did it this way. They should have built out with a touch more adhesive to make slightly bigger gaps which could then be grouted.
I’m thinking of doing our niche with microcement finish. @SimonD is your noche made of cement board or something else?
Hmm, we are about to have a bathroom tiled with marble by a tiler, starting tomorrow. What mistakes did he/she make?
Keeping the dust down - sealing a screed floor
Adsibob replied to Conor's topic in Waterproofing & Sealants
@Conor when was it poured and how thick is it? -
Yes, that’sa good idea. I will give it a try. What is the difference between silicone and grout? Why is grout used in some places and silicone in others?
Painted internal window cills/boards - what material to choose
Adsibob replied to Adsibob's topic in Windows & Glazing
Cheap MDF leaks toxins. Although it only affects a small proportion of the market, very difficult to know what you are getting: https://www.theguardian.com/money/2019/feb/09/mdf-furniture-toxic-fumes-formaldehyde
