Adsibob
    10
Everything posted by Adsibob
  1. this isn't such a bad idea. Would it work though?
  2. If you like Weber & Ducre, have a look at One Light, they have a huge catalogue, but amongst all their stuff, you will find plenty of stuff that you like I think, and it is cheaper than Wever & Ducre and probably just as good quality, if not better: https://toplightco.com/collections/one-light-products?page=6&grid_list
  3. Thank you. Clearly I’m completely useless at searching!
  4. Get better wall lights. E.g. stuff that isn’t boxed in at all:
  5. I just don’t understand this. Good quality high CRI bulbs in a 2700k colour will illuminate whatever you need to see as well as you could ever need to see it, without the harshness of cool lights. 3000k at a stretch, but anything higher than this is not appropriate for a residence.
  6. I’m with @jack on this. I hate downlights. We managed to get away with only 13 in the whole 5 bedroom/3 storey house: one in the porch two in the ground hallway one in first floor hallway two at the top of the stairwell above second floor hallway two in the kids bathroom 5 concealed in the kitchen -these are to illuminate the L worktop, I say concealed because you can only see them directly under them, there is a decorative ceiling that drops 20cm below the ceiling where they are installed. I will try and upload some pictures. i find that lighting works much better with lots of layers, and only using downlights where you absolutely have to because there is no alternative. So we have a lot of wall lights, a pendant in the middle of most rooms, including in our master en-suite, which looks great, and a few floor standing lamps and table lamps. We wired many of the lamps into 5A lighting circuits so that you can still control at the wall.
  7. FYI You could always get a horizontal cylinder if you wanted bigger and height was restricted.
  8. Because they forgot and are not covering their tracks with bullshit! When my builder forgot a step, at least he had the decency to admit it. It only happened once in a 20 month build, but it was pretty important. We forget to put a cavity closer in either side of the opening for the sliding door. Had to cut the bricks and put one in. Not terrible, as sliding door was deep enough that it covered the mistake.
  9. The other issue I have is I would like to trial the light fitting, before I commit to keeping it.
  10. I have an Amazon prime account, so normally get my stuff from there. But was slightly horrified to see that a Euro to UK adaptor costs £10 including so called “free” delivery. Given screwfix do a UK to Euro one for 2.99, it shouldn’t cost any more than this. Unfortunately screwfix does not do a Euro to UK, just the inverse. Any ideas?
  11. Thanks for the tips so far. What would be the difference in outcome/experience/skill required between a spear point drill it and something like this: https://www.screwfix.com/p/erbauer-diamond-tile-drill-bit-6-x-67mm/51908
  12. But reading your posts, they don’t seem very rational. You have said it is nothing to do with the heating, and maybe you are right. But you have not explored other factors in any meaningful way. i do think you need to experiment with a few humidity readings in the building (both the extension and the original house), record some data over a week, then if humidity is higher than about 49% hire some dehumifiers and get it right down to 35% and keep it at that humidity level for at least a week. Meanwhile, remove all mould, airtight and insulate the house and install MVHR. Once that’s all done, switch the MVHR on and return the dehumidifiers to the hire shop. That’s what we did with a 95 year old very damp house and it worked. If you can’t do that, then either do what you can and accept there will be some mould, or sell up and buy somewhere less mouldy.
  13. Very cool and lovely looking house you have there. My only concern would be that the living room where the stove is will always be warmer than other places, but I guess that doesn't matter too much given cooking appliances in the kitchens will help bring the temp up in there when you're cooking and you want the bedrooms cooler anyway. But what about the bathrooms? Do you have any towel rails? Doesn't the tiled floor get very cold?
  14. As long as you make a start, then you’ve banked your PP for life. Not sure what is legally required to make a start, but given you do need to serve your building control application notice either shortly before or shortly after you start, you would have to do that as well, not to bank the planning permission per se, but to make sure two different departments within your local authority didn’t have conflicting data. That way if the planners ever raise an eyebrow later, you can much more credible say “I started this 43 years ago, here is my BC application notice to prove it.”
  15. Just curious about this. Do you effectively have a giant stack of concrete blocks in the middle of your home acting as radiators built into the wall? Sounds really cool but just trying to imagine it.
  16. That’s brilliant, wish I had a time machine. I guess I paid for the labour of cutting and putting all of it together because it was delivered with everything all in its place, which made installation very easy, I think they call it “pre-hung and painted”. Looking at the paperwork now I see it is only FD30 but rated at a 40dB reduction, and they fitted the locks and handles which I supplied, after satisfying themselves that the locks were fire rated, whatever that means. Total price was £815 plus vat and delivery. Seeing what you’ve found, clearly this was very expensive. I will tell myself that the customer service was decent: there was an issue with some of the painting having bubbled up. The day after I raised the issue they came to pick up the door and two days later it was back on site and paint issue resolved. That was about 6 months ago and we’ve not had a problem with it since.
  17. Good luck getting those parts for that money. Yes, the seals on the two uprights and the top are just bits of rubber, but the drop down seal is more complex. I could only find the drop down seal as a standalone item for about £90 quid, and it was rather unsightly, as not integrated within the door. The price I mention was for an FD30 door (might have even been FD60) sold as a Doorset with frame, stops etc, and all seals fitted/rebated, ironmongery fitted (but I had to supply locks and handles, they supplied four hinges) and spray painted. I will see if I can find the rating, but it’s good enough that it eliminates noise of a washing machine, tunble dryer and 35kw system boiler.
  18. Which is your local authority for planning purposes?
  19. That sounds far too absolutist. Who published the “guide”? In any case such guides are not legally binding. Only the planning policy documents, planning law and case law interpreting them matter, as far as I know. Can you post a link to the guide please?
  20. I ordered a system that I think was lorient tech or similar from a company based in Enfield. Came to about £1100 without handles or locks. Not cheap, but worth it in my opinion as it really works well at isolating our utility room from the rest of the house.
  21. Of course the starting position is that you have to build any extension out of the same materials. But that can be rather boring, costly, inefficient and complicated. Ultimately, it is very difficult to match like for like exactly, and so in the last 25 years or so creative architects have found ways to persuade the local planners to deviate from the starting position. Particularly given your extension is a rear one, that won’t be seen from the front of the house (is that right?), you could argue that it won’t impact the “street scene” though different councils interpret that concept slightly differently. My Council were real sticklers for the rules and applied a stupidly expansive interpretation of Street scene, but still allowed our rear extension to be built with completely different materials to the rest of the house. They made us match the materials for the first floor extension, but not for the full width ground floor extension. So unless you want to build your extension out of stone, don’t.
  22. @Grian go for it! The first thing I ever built was a small wood store with a sloped felt roof. If I managed it, you will be fine. My tip is to go to your local diy store (a big B and Q or Selco for example) and see what outdoor treated timber they supply. Take a note of the lengths available, then plan your wood store accordingly, so that you can minimise the amount of cuts required. And buy self driving wood screws and a decent drill. I think I managed to build mine with only 6 cuts, and is still standing 8 years later. If it is at least a quarter full of wood at all times, it won’t blow away, but if you are worried, make the uprights 20cm longer than they need to be so that they can be buried in the ground and then anchored with diagonal somethings (maybe very long nails?) that are then covered with the ground.
  23. If this is your belief, then you desperately need an architect!!!
  24. If you get it installed by a decent installer, they will use a composite which closely matched the predominant colour of the stone, and give you a 0.6mm join which is hardly noticeable.
  25. That pole is wooden right? There is a great song by the Prodigy that comes to mind…
