Adsibob
    10
Everything posted by Adsibob
  1. This shape building means your ratio of perimeter to volume is quite high. In other words, every internal room of the house has at least two external walks and in some case three or four. That will make it less efficient from a heating perspective. But if you invest in a lot of insulation, you will be fine, just giving you the heads up that you want to be relying on at least 125mm of EWI. Others will advise better than me.
  2. My gardener is helping me with this and he's concerned that actually we need to build up the sub-base a bit higher given we plan on raising the ground level when we lay turf by adding a couple of inches of topsoil in the future. So for the bottom of the 40mm shed base to be level with the ground, we're going to have to build up the sub ground area by almost 10cm. Should i build a wooden frame, fill it with sub base and then compact it, or will it compact without the frame retaining it on the sides? This is all feeling very over the top.
  3. Thanks everyone. Hmmm, now I need to find some scaffold boards. Building works finished about 6 months ago... so not much left on site.
  4. I need to carry some 50 wheel barrow's worth of soil and MOT down the side alley of my house. At one point, there is a 28cm drop and i need a decent ramp that will carry the weight of one wheel barrow. I was just going to use some spare plyboard (two sheets, doubled up, with one overlapping the other to create a slight diagonal, supported by some sand bags underneath), but it turns out I don't have any left and given the cost of ply I thought I may as well buy a proper ramp as it would have uses in the future. Was flabbergasted that Screwfix didn't have anything for less than £250. Found this on amazon which is closer to my budget: https://www.amazon.co.uk/Black-Range-B5249-Folding-Motorcycle/dp/B076CM3NPS/ref=sr_1_12?crid=1RXLPZKDT9Z4H&keywords=ramp&qid=1667576923&qu=eyJxc2MiOiI2LjgwIiwicXNhIjoiNi4wNCIsInFzcCI6IjUuMTAifQ%3D%3D&sprefix=ramp%2Caps%2C79&sr=8-12 Anyone think it will work, or will it be annoying that it only really holds the wheel barrow, with little space to walk on? Any better suggestions?
  5. I’m fairly sure our rainwater off our roofs and patio are pumped into the sewer, yes. Where else would it go? I should clarify that we were renovating a 1930s semi so it probably had a combined system as opposed to separate rainwater and and sewage channels. But I'm not sure to be honest. Anyone know how i could check?
  6. Ah, apologies. I meant the plughole/trap. I can see water at the bottom of the plughole move slightly as it gurgles, so I guess I was right about a pressure change sucking at that water. I'm fairly sure the pipe runs outside and before it discharges into the drain gully, there is an air gap. But maybe that's for another pipe. We have four sinks on the ground floor and this is the only one that makes this noise, I believe.
  7. Not sure. I don't think so. Where would it be if I did have one? As part of our renovation and extensions our house was completely replumbed recently, to relatively modern standards, but the plumber did cut a couple of corners. Should he have installed one?
  8. After and during some heavy rainfall our kitchen tap will make an intermittent gurgling sound. It lasts for anything between 1 and 4 seconds then stops for about 3 to 5 minutes then happens again. In case it’s relevant this is the type of trap we have under the kitchen sink: There is also a flexible pipe bringing the dishwasher waste water into this, although the angle of the photo hides it - I don’t think it’s relevant though, as the dishwasher wasn’t running at the time of the noise. The only explanation I can think of is that as our sewer fills up with rainwater it changes the amount of airspace in the drainage system and that causes pressure changes which affect the trap??? Not a very convincing explanation but it’s all I’ve got. Any ideas? It’s not bad enough or frequent enough to really bother me enough to do anything about it, other than to want to know why it’s happening.
  9. Even with a DPC between the patio and the house, splash from the patio (the part of it not under cover) would risk hitting your house walls above the DPC if you don’t have the patio 150mm below the dpc. 150mm is best practice. You could probably get away with less, but I wouldn’t go lower than 80mm.
  10. I think because MOT Type 1 base will compact better, whereas gravel won't really compact that well. Query why the trays can't be filled with MOT type 1?
  11. She should pay you commission.
  12. About to order the MOT Type 1 for the sub base. Going to hire a compactor and lay a sub base of about 50mm. Seems overkill for a shed installed on London clay, but there are lots of leylandii tree roots nearby and so I thought I might as well. But then I saw the prices of MOT Type 1 and almost feinted. Do i really need this much: Each bag is 800kg. My shed is going to be about 11 sq metres. One bag is a bit short wheras 2 bags is too much. Could i lay less than 50mm? Would 30mm be enough given that I'm laying the probase plastic grids on top (which are 40mm thick and then filled with pebbles/crushed granite).
  13. Pergo won’t be damaged by dog claws. One of the premium Pergo ranges is completely water resistant. Much cheaper than installing tiles.
  14. Why do you need such a large quantity. Is for several properties or just one? Wood effect porcelain can look good if you go for the super expensive variety. But why not just lay real wood engineered boards? These days you can get very good oils which will make it very moisture resistant. Alternatively, Pergo do a laminate which is pretty realistic. Can't tell without touching it and even then the only tell tale sign is that it is slightly cooler to the touch than real wood.
  15. I think that would make the picture very bulky. The problem is that once the battery pack is big enough to have a 13A socket in it (shallowest I could find is this one), and once you add the thickness of the plug (and any transformer it has) you end up with a very thick build up. But your idea of a separate power pack is a good one. I wonder if I could power it from something like this, which is only 15.5mm thick.
  16. that won't solve my issue though, which is that I want to hang something without any cables/battery packs showing.
  17. I believe those dimensions are in inches. The Netgear is big enough, but not battery powered.
  18. I'm looking for a battery powered version of something like this: https://www.netgear.com/uk/home/digital-art-canvas/canvasii/?utm_source=Google Shopping&utm_campaign=Netgear PLA Feed&utm_medium=cpc&utm_term=244&cid=uk-best-wifi6-srch-cpc&utm_source=shopping&utm_medium=cpc&utm_campaign=uk-best-wifi6-shopping-cpc&gclid=CjwKCAjw5P2aBhAlEiwAAdY7dC4gKaeExybhrmjZTZn5SG2ofi0tO3oBSdmRE69WPKqK1vhUaa-nUxoCX1QQAvD_BwE I'd like to display some art work digitally, but didn't think ahead to have a power socket in the right place on the wall. Thought a battery powered version should exist, but struggling to find something big enough. Needs to be at least A4 size, but preferably closer to A3. Any ideas?
  19. You go and see a civil litigator, one that specialises in property matters, particularly boundary and easement disputes.
  20. More like they upset me! Well I guess we upset each other.
  21. My shed is going to go quite close to the fence. What is the minimum gap I need between the shed and the fence to be able to repair the fence (hopefully not necessary for many years, given it’s just gone up) and paint the shed? Is 60cm enough, or a bit tight?
  22. Anyone seen the Jeffrey Dahmer series on Netflix. Now there’s a man who could have done with a chest freezer.
  23. Chest freezers are also much more useful for storing cadavers.
  24. As long as it is not damp, you can add EWI and then render with a more contemporary finish. I recommend Ceresit.
