Mikey_1980
    2
Mikey_1980 last won the day on October 5 2016
Mikey_1980 had the most liked content!
Personal Information
  • Location
    Hampshire
2891 profile views
Mikey_1980's Achievements
Regular Member
Regular Member (4/5)
71
  1. I have just had a Reginox Harlem and Reginox hot water tap installed, really pleased with the quality, feels solid and cleans easily. The Hot water tap came from Costco on offer they sometimes have sinks on offer as well.
  2. No Idea of cost or leadtimes but is this what you are looking for 2500 Series Wood Floor Access Cover Trim | Howe Green
  3. If you needed additional help I would be happy to lend a hand.
  4. Could you not just pop a motion sensor bulb in there, https://www.ebay.co.uk/itm/B22-E27-E14-5W-220V-18-LED-Motion-Control-PIR-Sensor-Light-Lamp-Bulb-Cool-Warm-/312012637265
  5. Have a look at noip.com for getting around the static IP address issue. if you have a mini server you could set up you could look at DDNS as well. Noip would probably be simpler though.
  6. Thanks Declan, the handle would be in the middle like in this photo, not in to take a pic
  7. Would anyone know if and how I would adjust these windows for a tighter close against the seal. At present the noise is the same with/without the window shut and I can see they aren’t sealing properly. Any help much appreciated. At a freinds house for 24 hours so hoping to try And hell while I am here.
  8. We had a major issue with the electrics just after we occupied our house. The electrics would trip at random times of the day for no reason. All tests in the house came back as normal and all external tests by SSE came back as normal, this went in for 3-4 weeks, they re cabled our pole, checked out the electrics in all the local barns and farms to try and resolve. . It turned out it was the neighbours sewerage pink was going to earth or something whenever it switched on and trippping our electrics when it happened which was why it was happening at random times. Just thought I would mention as it could be something completely random and un thought of causing this.
  9. i have listed our estimate below, there were extra things we got done along the way so I think it was around £19k we ended paying, but couldn't fault him and his team for workmanship/attitude and being able to work around delays etc. It was basically a 300 m2 Bungalow although there was a two story section which housed a bathroom and ensuite. Plumbing works Pipework: Supply/install 22mm cold pipework, reducing to 15mm at sanitaryware/appliances. Supply/install separate cold water pipework from internal cold mains to 2 no sinks, 2 no outside taps (for future water softener compliance). Supply/install 22mm hot pipework, reducing to 15mm at sanitaryware/appliances. Secondary return hot water system, with pump/timer. Supply/install 32/40mm waste pipework for sanitaryware/appliances. Supply/install 100mm above ground soil/vent pipework for 5 no locations. Supply/install service, air admittance and check valves, fittings, waste traps and 19mm thick hot/cold pipe lagging. Sanitaryware: To install only, the following sanitaryware in positions as shown on drawings: Ground floor: WC cloakroom - 1 no basin/pedestal/mixer tap, 1 no WC suite c/c. Ensuite 1 – 1 no basin/pedestal/mixer tap, 1 no WC suite c/c, 1 no wetroom shower tray, 2 no shower glass side panels, 1 no shower valve/riser set. Ensuite 2 – 1 no basin/pedestal/mixer tap, 1 no WC suite c/c, 1 no wetroom shower tray, 2 no shower glass side/end panels, 1 no shower valve/riser set. Bathroom – 1 no basin/pedestal/mixer tap , 1 no WC suite c/c, 1 no bath/bath filler, 2 no side/end bath panels, 1 no shower valve/riser set, 1 no bath-shower screen. First floor: Ensuite 3 – 1 no basin/pedestal/mixer tap, 1 no WC suite c/c, 1 no wetroom shower tray, 2 no shower glass panels, 1 no shower valve/riser set, 1 no free standing bath/bath filler. General: Pressure testing as works progress. Plastic pipework/fittings, with visible copper tails to be used throughout for hot/cold supply. All works carried out to comply with water regulations and left in satisfactory working order. Tiling works Ground floor: WC cloakroom – tiled floor, splash back above basin. Ensuite 1 – tiled floor, fully tiled in shower area, splash back above basin. Ensuite 2 – tiled floor, fully tiled in shower area, splash back above basin. Bathroom – tiled floor, fully tiled in bath area, splash back above basin. First floor: Ensuite 3 – tiled floor, fully tiled in shower area, splash back above basin. General: Supply flexible tile adhesives and grouts. Standard wall and floor ceramic tiling (no mosaics, borders, patterns/designs, porcelain/natural stone) in the bathroom, WC cloakroom and ensuites, supplied by client.
  10. I would go wired with a switch and access points if you can. If it’s going to prove difficult though, my friend has 3 of these installed in an Old 3 story Victorian town house and they work well. I have never had any issues connections and using the Wi-fi via them. https://www.rselectricalsupplies.co.uk/bg-nexus-metal-brushed-steel-2-gang-wifi-range-extender-13a-socket-with-usb-and-grey-inserts-nbs22uwrg_16809?gclid=EAIaIQobChMI-9GShKDs3QIVioaRCh0jtQvkEAQYBSABEgIZ4PD_BwE
  11. We hired a Caravan for our build, we had it for around 4-5 months and cost around £2k including delivery/collection siting etc.
  12. I can second spectrum, we got a lot of bits from them including cills.
  13. We used ideal work for ours, it has been down two years and still looks great, cost fully installed was around £75m2, https://www.idealworkuk.com/
  14. They could just defer the payment of the stamp duty HM Revenue & Customs requests that stamp duty be paid in the 30 days after contracts are signed in a house purchase, but what happens if you don't? Well, if you pay the tax up to 12 months after the contracts are signed then HMRC will levy a small fee – 10% of the duty - capped at £300.
  15. Thanks all, I will have a play with a double gang box for now and see if it will work. It’s a new build flat, approximately 6 years old so the electrics are all standard nothing has been altered or played with since it’s been built.
