Everything posted by JohnMo
Sense check for ASHP & UFH design
JohnMo replied to timhowes's topic in Air Source Heat Pumps (ASHP)
They nearly all do, you just need to search hard as they all call the files different names. Mitsubishi have a excellent data set, for actual UK models, how actuate a Czech data set is for the UK market is questionable. Especially as the data set has models not available in the UK. -
I would look at Hitachi and HiSense also for their heat pumps. Hitachi and Hisense have a sharing agreement, looking at the datasheet outputs are idenical for each model. But Hisense comes with cooling out the box, Hitachi is an additional cost. But modulation is great. Neither are that expensive either. Sounds a lot. What is included in that cost -
30 Year Old 8mm Microbore Circuit Changes
JohnMo replied to PhilT's topic in Central Heating (Radiators)
If get rid of all the small bore stuff, can you get rid of the second circulation pump? -
Yep. Best gains are by getting decent modulation, lengthy cycle times and running the minimum flow temp possible. Everything is sh!te in sh!te out. If you don't have plenty of water volume and good flow rates your stuffed anyway, and stand a chance of getting a decent CoP.
MBC High Performance timber frame energy consumption in November
JohnMo replied to RedRhino's topic in Timber Frame
Some info here also -
This is the first topic I found on it - on another forum https://community.openenergymonitor.org/t/vaillant-arotherm-plus-cooling/26658/15 -
You have to buy a plug to make it cool - Valiant UK want to charge many hundreds of pounds for the part, but the same widget is also used on boilers (not for cooling) and it basically a resistor. There is thread on here that has all the parts numbers. The gas version is about £10. You plug it in and the heat pump that has all the cooling options show up on the controller - another UK ASHP con - premium ASHP you have to buy extras for, to make do a basic ASHP function. -
Grant doesn't state anything or care, MCS don't care either. In the past under a different schem there was a requirement for cooling not to be possible - but that went away about 10 years ago. Most heat pumps will cool, its just a matter of finding what settings are hidden away. The new R290 Grant heat pumps, Grant state they will not cool, but there is a dip switch in the casing that can be set to allow automatic change over of heating or cooling, heating only or cooling only. Grant default is heating only. So exploration you may find it can cool. All ASHP have the ability to cool and they must move to that function (refrigerant 4 way valve) to do defrosts. You've contradicted yourself. -
So obvious question, can you not locate the switch away from the steelwork? Wrap steel in 25mm PIR (or more if you have space) and seal all joints with aluminium tape - cold bridge gone. Or use a dry lining pattress box, instead of the normal ones for skimmed walls?
What insurance needed to move in before completion?
JohnMo replied to YorkieSelfBuild's topic in Self Build Insurance
We started with One Insurance (think that's they are called) now with direct line. I found I answered the questions that were asked only. We are ICF, so our wall construction is concrete etc. Is it an open timber frame - or just a timber frame? -
I would be more concerned that you actually discovered the steel and you can put your hand on it. It should be fully insulated not hidden behind the plasterboard uninsulated.
How big are you planning - floor area and number if storeys, on how big a plot?
But do you really get that many days at -3, compared to days at 7 to 10 degs.
Maybe, but most houses on here are outside their comfort zone, ventilation heat loss just too small, to allow s tick the normal tick box. Hence plenty are specified way over sized.
Use a normal domestic one, your just heating a buffer as far as it's concerned. Depending on hot tub size a big one. To keep the ASHP inhibited and pressurised you may need to plate load the hot tub, but size the Plate Heat Exchanger (PHE) correctly, you have a 2 Deg approach temp. Then you have no issues with DHW heating, it just switches the diverter valve as normal. Add a second zone for cooling, so it bypasses the hot tub or have the hot tub cooler in summer and as cooling buffer. Heat pump doesn't care if it doing heating or cooling it just moving the refrigerant 4 port valve to a different position (as long manufacturer hasn't disabled the cooling function). Most heat pumps have the functionality to have different zones as cooling only, heat only or both. And the functions can be independently set for each zone.
I just looked and came to same conclusion you did, even NE Scotland I can have in two days.
Have you considered using a single heat pump? Size the spa heat pump big enough for the house, use the volume of the hot tub as a heat source for the house via a plate heat exchanger and mixer valve. Heat pump does two jobs, keeps hot tub temp stable, and or DHW via a diverter valve.
Fabric and ventilation heat loss calculator
JohnMo replied to Jeremy Harris's topic in Heat Insulation
Read the data sheet for the heat pump in the offer to make sure it is doing the correct output for your heat loss. The nameplate sizing as with most manufacturers is not very well representative. And make sure you are being pushed into a buffer when you most likely do not need one. Also don't go pre-plumbed cylinder. Lots of stuff on apre plumbed you pay for but may never use.- 204 replies
- heat loss
- ventilation
(and 4 more)
They have rules about country made content, something like 70 to 80% of material content of engineered products have to include, materials and manufactured content made in country, otherwise they get with huge import tariffs or no permission to go ahead with the project. Then cost of manpower doesn't matter then, people are employed government gets income tax etc. Why the heck we don't have such rules is bonkers.
To put that into reality that is double a passivhaus. Really look at how they have accounted for ventilation heat losses. With MVHR ventilation heat loss drops from big to negligible. Another thing we are 192m² living space plus another 26m² in the insulated space. Our roof area is around 50% more than yours as is our floor area, as we are single storey and every room has vaulted ceilings. All of which (part of form factor) really add to our heat loss per m². We are nearer 13W per m². With a 12kW you may need a volumiser, depending on water volume. You can always get a volumiser with immersion that gives you another 3kW if you really need it. We have an oversized heat pump that doesn't modulate well. I can get acceptable SCoP from it, around 4, if it modulated better I would be getting closed to 5. So a 25% reduction in running costs. So sizing is important. Looking at heat pump monitor a 12kW appears to modulate down to about 4.5kW, cannot see any 16kW on there.
