Everything posted by worldwidewebs
Adhesive for EPS
worldwidewebs replied to worldwidewebs's topic in General Self Build & DIY Discussion
The sample of dibond I got looks pretty good - gloss on one side, matt on the other. I did get a quote for powder coated aluminium but it was over twice the price and no better I don't think. One aspect I'm not sure about is the fixing of it to the EPS. What do you do with both the blue membrane and the plastic (damp-proof?) sheet? Do you just cut it off where the render finishes? The obvious answer is yes but I just wanted to check first -
This was the one (well, 1 of about 4) area that MBC screwed up on. I'd had a site topological survey done previously so I got them back to mark out the area of dig and back again to mark out the exact area that the house should go once the base had been laid. Despite marking out with blue paint, steel pegs and setting the levels it was all ignored - I came back from work to find that they'd removed the steel pegs (they were in the way!) and covered the paint with the blinding material. They did wonder what it was for apparently!!! So, the moral of the story is to treat everyone as an idiot - most people are. And realise that experience is not the same as ability.
We got a staircase from Travis Perkins - I think it cost about £100. Bargain!
Adhesive for EPS
From www.cutplasticsheeting.co.uk I've just requested a sample but hopefully it'll be fine -
Adhesive for EPS
For how long? -
Adhesive for EPS
Would this stuff work https://www.cloudfixing.com/products/tremco-illbruck-fm330-air-tight-expanding-foam?utm_medium=cpc&utm_source=googlepla&variant=42267657038 (air-tight expanding foam) ? -
I think I've settled on using Dibond aluminium composite for the plinth on our house and would rather stick it to the EPS than mechanically fix it. Are there any products I should look at or avoid?
Installing Shower Screens
worldwidewebs replied to worldwidewebs's topic in Bathrooms, Ensuites & Wetrooms
Yep, cheers. -
I want to fit a shower screen into a wet-room area but want it to look as minimal as possible. Reading around, it seems that you need to fix the screen to the wall and floor using either clamps or u-channel and optionally a support bar to the wall or ceiling. I think I prefer the look of the channel but they always seem to be hard to get really clean. Is it possible to just fix/seal the screen directly to the wall and floor? On the face of it I don't see why not, but I've read so many warnings about not resting the screen on a hard surface
Interesting - we had no instructions so maybe that was the problem! I still think it's too thin though. We have a LOT of aluminium on the house and the dry verge is by far the weakest link
- 11 replies
MBC timber frame and cedar cladding closing the gap
worldwidewebs replied to lizzie's topic in General Joinery
May I ask how much you're paying for the aluminium? I need to sort out something asap and was going to use uPVC, partly as it's easier to trim if needed, but we have a fait bit of Al on the house so it might be better to finish the job with it too -
We used Kytun dry verge and I'm not that impressed with it. I like the idea but the Kytun stuff is really thin and there's no easy/neat way to join long lengths
- 11 replies
Hi Jeremy - Can I ask why you didn't just put the uPCV directly onto the EPS? -
Concrete Shuttering Query
worldwidewebs replied to worldwidewebs's topic in General Construction Issues
Yes, just compacted MOT1 on top of soil What did you find was the best timber to use? -
Thanks - that's just the sort of insight I was looking for. I'm not sure how easy it'll be to drive wooden stakes into crushed stone though -
Yes, that's right. Whereas with stone we would just lay sand and then a bed of mortar the tiles need something more substantial. I initially didn't want to go down this route but deep down I know it'll look good and I've come this far... When you put the timber down, how do you best go about filling in any gaps under it in the cases where the crushed stone isn't level? Or don't you... -
We were going to lay stone paving on the largish patio and the paths around the side and front of the house so we put down a base of compacted crushed stone - but it has now been decided that we're having porcelain tiles instead, which means I now need to have a concrete base to lay them on. And this is where I'm not sure how to approach it. The stone is reasonably level but not quite and I'll need a slab which will be between 75 and 110mm thick. What would be the best way of tackling the shuttering? I've been looking at hiring steel road form as it looks like this could help make levelling easier but is timber just as good/easier? I've never done this before please feel free to advise and guide a novice!
Just as I was typing my last reply! I'd assume then that you'd have to tape it all up so that nothing can get under it. I've seen some fleeces, but it feels like overkill to fit the fleece and then correx on top
Thanks chaps. With those correx-type sheets, is anything needed underneath? What I'm trying to guard against as much as anything is all the little scratches from grit/small stones being brought in and getting under any boards and then acting like sandpaper.
We're getting the engineered oak flooring laid soon but I want to be able to protect it from boots and tools while some of the jobs are being finished off. There isn't a lot to do upstairs, but enough that I want to do something about it - downstairs there will be quite a few jobs (kitchen, skirting, final electrics, door sets etc). I need something thicker and more impact resistant than a cling film type stuff like Roll & Stroll and I'm going to assume it will be down for 4-6 weeks in the worst case - I can probably get away with about 150m2. What can anyone recommend to do the job?
The stuff we're using on site at the moment is superb but I can't remember what it is at the moment - I'll update later. For reference, my dad is a painter and decorator and he/we have used pretty much everything decent on the market over the years - this stuff is up there. One constraint is it only comes in limited colours but fortunately one of those is white! Note that paint on new plaster has very different requirements to that on other surfaces
Show me your installation!
worldwidewebs replied to worldwidewebs's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Thanks chaps, all most useful! @jamiehamy Yours is probably closest to what we have - I think we have something like 10 extract and 14 supply ducts, all coming out of between ceiling and wall. The challenge I have is that if I mount the distribution box on the wall horizontally then I struggle to get the ones underneath to connect neatly and if I mount it vertically or on the ceiling then I get many pipes trying to cross over each other. A day of 'playing'awaits! -
Thread resurrection! Anyone care to share a photo of their distribution box installation? Would like to see how much space is really needed to connect everything together -
Trimming Plenums
Thanks -
When is the best time to trim the plenums to length - before skimming or after? We have the plasterboard fitted and skimming is starting this week so should I trim now or wait until after skimming?
