Pocster
    29
Everything posted by Pocster
  1. When I look at these in a show room admittedly not wired in to use - but the wiring seems to go straight into the wall . My electrician has asked for a flex outlet plate . Is this the standard way to have these wired ? . Would be nice to have no visible cable if possible....
  2. Will do a mock up to test alignment!
  3. Wall hung vanity . In theory the vanity unit hides the waste .
  4. Awesome ! .It is a wall mounted vanity unit the sink sits on . As I have to tile walls first was worried where I place the waste in the wall . This certainly reduces the error margin
  5. My bathroom sink waste will come up through the stud wall . The sink is wall mounted I.e you can’t see the waste . How do I position the waste in the stud wall ? . I could be too high or maybe too low to join exactly to the sink trap . Do some traps have adjustments to raise / lower ?? Hope my questions clear ! ?
  6. Yes ! I have genius hub installed in 3 HMO’s works well . Battery failure being the most annoying thing and thick tenants not understanding it ...
  7. The lintels are hard to drill so F off ! ?
  8. No I don’t know what you mean ( even though all the timber is up )
  9. Awkward work on your own ! First section in and glued . Toilet joint relatively near hole for toilet waste Forgot how nice the glue smells !!
  10. Sparky has been . I allowed him a whole day to install this . He took his time and made a super neat job ! . 2 CU’s and my Din box ?
      • 2
      • Thanks
      • Like
  11. Yes - I was going to add a bracket every metre . 100mm fall across 6metres it will be ?
  12. Still doesn’t look like much of a fall . Pipe now nearly 6m Fall is around 5cm . That enough ??
  13. Well ! After much faffing ! Measuring off the floor blocks above ; difference between each end is around 20mm . Doesn’t look like much of a fall !!! Should I make it steeper ? Appreciate from the photo you can’t tell ??
  14. Preliminary test of theory ? Drain through to outside ; got to adjust the clamp length and add a few more . Aiming for 10mm fall per metre ...
  15. You sure that's ok? - regs wise I mean?. I can't find regs about the pipe size to the AAV
  16. Yes it's end of the stack. The main drain is shared with just one other property that does have a stench pipe. I'm not going to have a stench pipe - worst case I'll add an external one later. Does the pipe coming off my 110m smile HAVE to be 110mm to the AAV?? - PITA!
  17. Ok ! Well my soil pipe ceiling suspended will naturally have a fall to outside . So at the other end I.e ‘uphill’ I’ll install it . Pita because I didn’t allow for a vertical 110mm pipe in the stud ?
  18. I’m going to the loft and running it horizontal just to get it near the loft access hatch . Don’t fancy crawling through tight spaces if there’s an issue ? Why do you have multiple AAV’s ? I was just planning on installing one . Thinking now - that HAS to be at the end of the soil run , yes ? I.e past all other connections
  19. Just checking ! 1) Has to higher than highest cistern ? 2) 110mm AAV pipe - preferable ? 3) Can tee off the main drain anywhere ? Doesn’t have to be at the end of cisterns ? Just anywhere ? 4) Must run vertical into loft - can then can go horizontal; must end vertical though ? I’m 99% that’s all ok ... but post just in case ...
  20. I see ! Ok ! I’ll do 32 and 40 off sinks / baths - once through my beam and block swap to 50mm before boss strap into 110mm
  21. I know ! I give up correcting spell check . Every time I try to type ring or sing etc . It’s first choice is “f’ing” - guess it’s learnt too much !!
  22. Got some 32mm pipe spare now then ? Everything in 50mm it will be !
  23. Phone wise ( when I’m above ground ) 3 or 4 - not an issue . This modem though !! You can 4 bars and get a relatively slow speed or 3 bars and it’s actually faster . I think which host it picks is critical.
  24. Ok ! the problem with speed net is it chooses an ‘optimal’ host it would seem at random ! So in the same location I can get anything between 2mb and 22mb - depending on host !!! . Assume there’s some configuration on the router that allows you to choose hosts ....
  25. On site . Ariel outside at around head height . Download 20mb / upload 8mb Not too bad . Will now try Ariel at back of build
