Pocster
    29
Everything posted by Pocster
  1. Will add into HA . When I’m underground and someone presses the doorbell - will push a Cctv image to a wall mounted iPad then I can unlock the door remotely if I wish .
  2. Great ! I did ask the installer if thumbs were ok - he said yes . Maybe a newer model ???
  3. Hmmmm Floor to top of unit 87cm - sink is about another 10cm That seem too high ??
  4. You need iPhone with face recognition- pretty reliable ?
  5. It is ! A bit unnecessary I agree - but what the hell - that time I forget my key I’ll be glad of it
  6. Front door looks the absolute b*llocks !
  7. Might try and get planning and build another house over it
  8. Website says for use above ground
  9. I can always build a concrete block housing over that short run of black pipe to protect it .
  10. Sure guys ; push fit at the pan etc. But going into the soil pipe I think welding is best ( in this situation)
  11. Just do solvent weld . Dry fit everything. You’ll be fine . Better to be safe than sorry !
  12. Because it’s all in a ceiling . Welded won’t leak .... ?
  13. Or this ? ouch at the price !! https://www.mytub.co.uk/110mm-solvent-92-5d-rest-bend-only-ss705-product-570233
  14. Think this is it https://www.drainagecentral.co.uk/110mm-PVCu-Solvent-Weld-Soil-Pipe-Bend-925-Degrees-Double-Socket-BS473?gclid=EAIaIQobChMI-sSWsK-Q6AIVVODtCh3z1gt4EAQYCiABEgIY_vD_BwE
  15. That looks good - not sure it exists in solvent weld - will check !
  16. Maybe - the problem is my WC is near the in ceiling drain , so there’s not much ‘room’ to do a gentle fall .
  17. I assume the first drawing is better i.e. try to have 'gentle' bends rather than 90 degrees....
  18. Ok ! Won’t embed it ! Pea gravel all around and over when I’m ready .
  19. Geberit didn’t even send a “we acknowledge your email “ response ; so I called them . Waste of time - kept saying I need a horizontal extender ( 366.887.16.1) which I don’t . He asked me to explain what I was trying to achieve . As soon as I went outside “geberit world “ he said it wasn’t possible to mix push fit with solvent . I asked him if he had a horizontal drainage pipe in his ceiling would he want geberit push fit or welded ? ? After 5 seconds of silence ( and not promoting a geberit product to me ) he said welded . I guess I was stupid expecting a geberit salesman / technical to be a ‘real world ‘ plumber . Anyway ! I needed a solution so reluctantly and with difficulty can just squeeze a 110m through ...
  20. Main run almost done . Welded with pretty good fall Not sure how I’m going to connect ensuite wc ( hole shows point I’m expecting waste to come through ) - straight to end of main soil run I guess . Assume I’m ok to do a 90 tee right at the end and wc straight into that ...
  21. Yep - chamfer and lube up . Agree it shouldn’t really be black pipe exterior but it’s a short run and will probably get buried in concrete
  22. Set myself up for that one !
  23. I use a bit of fairy ?‍♀️ ?
  24. Yeah that was my concern - rather use the geberit supplied fitting initially . Ordered that coupler you linked to earlier - give that a try first .
  25. Black pipe wouldn’t fit in a brown pipe coupler . That was the issue ; and I couldn’t weld a black coupler to the brown pipe . The difference in diameter is minimal but enough to cause a problem . I seem to recall some threads on here where 110mm in one make is not the same as 110mm in another make i.e one of them isn’t 110mm .
