Pocster
    29
Everything posted by Pocster
  1. I’ve got loads of ct1 to use up ! ?
  2. Sikaflex not ct1 ? Does it matter ??
  3. That’s the type of hoist setup I was maybe thinking of .... But I think the hoists ‘legs’ might get in the way .
  4. Yeah I need to ‘drop’ it in somehow . Well , not “drop” lol but “ place “ .....
  5. Think I’ll do similar and glue and screw marine ply across the whole wall then mount the delta board . Not sure I want to screw into the geberit frame ! . Not brave enough for that ! . If I make the ply crossing the frame 1 continuous piece then I reckon it would be rock solid . Need to experiment a bit more before I commit ...
  6. Yeah I know .
  7. No , I’m guessing just the old corona ....
  8. Funnily enough went to the builders merchants and bought bolts and nuts to fix as you did but from ‘outside’ into the frame . Not sure why I thought that would be better . Anyway whilst outside builders merchants I was then sick over their driveway ? - ( not joking ) - I must have caught something............. Have a headache now ..........
  9. Found a thread on this already , mentioning ice cubes and battons My tray weighs an impressive 72kg . As I’m always on my own ( pre self isolate - I set the trend ) ; this won’t be much fun . Want to recess tray into floor . So once wall boarded with marine ply and tile backer board on ; need a nice method to get tray in and out of corner . Battens sound best . But tray won’t be easily liftable once in situ . Was thinking of some kind of hoist ...
  10. No - I’m leaving them for you
  11. Ouch again !
  12. This might do it.... https://www.ebay.co.uk/itm/1PC-12V-Mini-Cooling-Computer-Fan-Small-40mm-x-10mm-DC-Brushless-3-pin-JC/193264503219?hash=item2cff7649b3:g:S9IAAOSwZ~pdzUUo#shpCntId
  13. I'm actually having great difficulty finding the 5 replacement fans I need. Can find them on US eBay at £100 for 5 + postage!!!! https://www.ebay.co.uk/itm/Lot-5x-new-Quiet-fans-NETGEAR-ProSAFE-GS748TP-Low-noise-best-for-Home-Networking-/263162755852
  14. The wall fixings for block work seem the right thickness and length Assume a visit to the builders merchants to get a similar size bolt , nut and washers will do the job
  15. Hmmmm They seem to suggest fixing the feet and just the brackets at the top ! . I’d like a bit more than that ! Show this in the destructions but don’t supply any bolts . I’d like to bolt it to the timbers either side . M10 ??
  16. Padded out with render board either side . So tight probably doesn’t need any fixings ?
  17. Ok - stiff as hell screw return in legs . Tapping it to correct height .
  18. First stupid question . I see the legs are extendable but can’t be locked in place ????!!???
  19. A dry ‘let’s give it a try ‘ fix . The pan hangs just off those 2 bolts with the yellow covers ; that’s it ? Initial ‘guess’ at height is far too low . Also I see geberit give multiple ways to fix the frame . Think I’ll use every possible fixing for peace of mind
  20. Maybe . The mounting bracket doesn’t allow for the cables to pass through it . Cables are rather stiff so bending them to much might damage them anyway
  21. It is over the drain ; though that wasn’t anything to do with it’s placement. I didn’t want to install 2 taps ( one for rear , other for front ) so just installed one half way .
  22. A compromise ! Took some plastic black pipe to builders merchants . Bought a new brown pipe coupler that also fits the black . So ; a compromise was born ! ; just the black coupler exposed externally.
  23. Longest leak ever award .... ffs ....
  24. No, it's PAS24 standard ( from memory ) which is an insurance recognised level of security. Also the reader is separate to the relay ( that is embedded in the actual door frame ). So you can't just stick a magnet on the door anywhere and it would open.
  25. Yes ! I’m watching everything you do . Wish I hadn’t seen that incident in the bathroom though ?
