Pocster
    29
Everything posted by Pocster
  1. No where really to stick a box . Though I could allow for that if I knew where everything else was going ?
  2. The only reason is I need 3 armoured runs as spec’d by sparky . Unfortunately ages ago when I ordered the cable I ordered 3 rolls of 25m . Just isn’t long enough ?
  3. Found white ones on virusbay
  4. Thanks I was going to pull the cable back out a bit so it ‘loops’ at the base ; I.e to allow drips to drop off Will fill hole with ct1 once I’ve found a suitable white exterior grommet
  5. Need to install some for outdoor electrics . Is it ok to have armoured cable outside ; then once inside the build have it ‘join’ to normal wiring ? . The joint though will have no access - so fit and forget . Is any of that allowed ???
  6. Now ! The next dilemma ! What height should a toilet be from the floor ( finished floor to top of pan ) . Wall hung ones always look lower too me - assume that’s an optical illusion though ...
  7. One of these holes is a mistake ? Other one as intended . Would really like to do one of those really neat ‘rubber’ plugs that the internet guys seem to use when they breach your wall . Never seen how they do it but always looks neat . Though I suspect the answer might just be “white CT1 “ ?
  8. Hey @Onoff that fitting arrived ! Looks like it will work ?
  9. Christ you are right ! I’ve set myself up to be burgled ! . They’ll leave the sink and walk on glazing ( unfortunately) just knick the bog rolls !
  10. When the doors closed I have zero 4g or 3G ? wifi calling enabled
  11. Gave in ! Lowered timber . Finished floor to top of sink around 34” ish That’s it ! Not moving it again
  12. 38” from finished floor to top of sink.. Cant go lower without cutting out that timber and lowering the support
  13. Dear admin @Onoff has made me vomit again with his implied disturbing references. Please ban him ???
  14. ???????? weld only ?
  15. I await your arrival ! Cucumber ready ! You dirty bastard !
  16. Yeah I didn't take into account my stilettos ...
  17. Though on the weekend I came across the Merlyn series 10 with "Halo" handle..... It was awesome!!!
  18. Yeah I know ! Just got home and measured bathroom sink and ensuite sink to floor ; both around 34” If I do the same I can’t be wrong ....
  19. Cheap skate ! ?
  20. Of course - none of you can see the blue LEDs that light up along the length of the handle ?
  21. It’s the house’s “face” . You make a judgement about the people inside based on the front door . Boy ! visitors to my front door are in for a surprise when they meet me ????
  22. Floor to top of sink is 41” not allowing for 20mm of finished floor Too high . I think maybe 36” will be better . Anyway must go and panic buy wine and steak now
  23. Hmmmmm - seems much too high now !
  24. Some things I’m so particular about it’s untrue . I know exactly what ‘image’ I’m trying to create . Tbh - this is all paid for by the savings of me labouring on site everything I can . Save 20k on labour - spend 20k on nice things ?
  25. Can’t remember u value without checking . About 7k ? But we have as you finger print scanner , electronic unlock and customised front and back . All glazing triple glazed - that’s a fairly large panel to the right . RK doors are the jam of jams ! The ‘style’ choices were also more expensive than some of the simpler designs .
