Pocster
    29
Everything posted by Pocster
  1. It’s been suggested ... I would possibly suggest discarding that pan connector/bend and buying a new pan connector either straight and a bend or possibly flexible and coming away from that in solvent soil so it’s all the same . https://www.jtmplumbing.co.uk/pipe-fittings-c433/toilet-pan-connectors-c187/viva-straight-wc-pan-connector-4-110mm-p4704 https://www.jtmplumbing.co.uk/pipe-fittings-c433/toilet-pan-connectors-c187/viva-long-flexible-pan-connector-300-700mm-p6980
  2. Now I looked online for a push fit to solvent weld converter and couldn’t find anything
  3. Ooooooo push fit one end solvent the other That’s what I need ! But a straight one .
  4. So ! I could take the geberit fitting into a similar grey fitting you have and solvent weld that end to my black 110 soil?? The geberit you show ; just pushed into the grey ?? Must have rubber ring or something surely?
  5. @Onoff what did you do here ? You seem to connect into the brown 110 soil - that grey pipe not a push fit onto it is it ??
  6. You are right ! Doesn’t solve my problem does it - as I still need to get to solvent weld
  7. Hmmmm Hunting - I find this @Nickfromwales suggests the 90/110 reducer ( surely that’s an enlarger ) push fits straight into the 110 soil . Still means I’d have a push fit in my vertical rather than a weld ....
  8. Actually do I HAVE to use any of the Geberit supplied pipework?? - can I not just get weldable in the same size? ( assuming geberit is a 'standard' size )? Or is that initial 90 degree tee a Geberit special fitting.....
  9. Hmmm, sounds like a problem for another day. I'll email Geberit - they do seem to do weld stuff - so hopefully they have a magic coupler that takes push fit to weld. I'll report back with what they say ; assuming they reply....
  10. Yeah I did think that also i.e. downhill away from the push joint, but you know. When I post 5 years from now about this brown stain on my ceiling......?
  11. So in my ceiling I’ll have push fit ? ? I really want solvent weld all the way I.e after the pan 90 tee . If I get one of those geberit extenders you linked to I’ll still need push fit at the end which is bad
  12. Rains beaten me ! Went for it and removed the crack - just the final connection to go ! Thanks for all the help !
  13. Need to look that up . but !!! I managed to force weld fit straight into the access chamber ! By pure luck of course ! So ! Coupler on internal soil to a length of weld pipe ‘push fitted’ into chamber !
  14. Hmmmm - called around a few plumbing online retailers - doesn’t apparently seem possible !! . Problem seems to be the rubber flange on the push fit stops the weld fit going in ( even the weld fit end with no flange )
  15. Ah bum ! @Jeremy Harris you are of course correct ! . Will do it properly with a coupler . Better now than problem later !
  16. Weld coupler fits over push fit pipe fine . But I can’t weld these 2 guys together can I ???? Push fit coupler doesn’t go over weld pipe . Both have a rubber flange which seems to stop them pairing up ...
  17. That’s going to be a right PITA to dig out ; so I can lift the pipe high enough so I can get a coupler over it !
  18. Almost there ! So the internal black pipe is weld stuff . Man hole connection is push fit - how do I marry these 2 up ? Also during my excavation I inadvertently stuck the pick axe through the pipe ? A cut section of curved pipe would act as a nice plaster over the hole . Assume this stuff isn’t weld friendly so CT1 it in place ??
  19. Hmmm I wonder if there’s a nice cat5 or wifi version ... starts googling ... ?
  20. So a cable straight through the wall is ok ? I think it looks neater than a plate in the bathroom
  21. Yep - I’ve googled the correct thing now ! Thanks @Jeremy Harris ; I am now looking at the right thing ! ??
  22. Ahhhhh ! Are all non switched FCU’s like that ?
  23. Ok ! I’m confused ! - dumb question for sure but how does the towel rail cable get into that ?
  24. But a FCU has a switch ; assume that’s not allowed in a bathroom ??? - or have I got it wrong ?
