Pocster
    29
Everything posted by Pocster
  1. Wanted solvent weld . Now I have some tiger sealant on the way that will buy me time . Solvent weld I still think is exactly what’s needed for this situation
  2. Ordered a tube of tiger seal . Anything more than 30 seconds would be good . I just used what plumbing website had . If this is just as good but gives time then that is mega helpful ! ?
  3. Yeah ? I was using the usual flo plast stuff
  4. STOP F ‘ing laughing EVERYONE !
  5. It was the right call . This joint ( probably less than a mm gap ) I can see daylight . Doesn’t show in the photo but it’s there . I need to construct a way where I can piece by piece assemble and glue with less time constraint v2
  6. Part of the problem was I needed ‘play’ to fit all this so I unclipped the geberit pan end. Just gave me enough wiggle room . But once glued I had to run upstairs and position the toilet pipe again ( wasting valuable seconds ) . Anyway ! Here I can see not fully inserted - so will never know if it was 100% leak proof .
  7. Ffs ! I’ll cut the bitch out !!! ?
  8. You mean ‘plug’ the fitting to the other toilet ? . Don’t have one to hand and of course no builders merchants open !!!
  9. I currently have another toilet connection to make before the soil pipe could be filled . I should finish this other joint . Block the drain ( best way to do that ? ) . Then fill the entire pipe until I can actually see it in the toilet fitting waste
  10. Ok . Exactly what do I need / do for an air test ?
  11. Yet I thought of that . Sharpie tends not to show up on black pipe . But with hindsight used tape or something as a marker
  12. You mean block the drain ?? To stop it emptying so fast ?
  13. Ok ! zero leaks ! Ran it for a few minutes then opened hose to max . Not a drop . I will cement the joints then wait for 5 years time that ‘brown drip’ on my head ... ??
  14. Going to water test it now ?
  15. Some of them aren’t inserted fully . The problem was the 2 tees needed ‘adjusting’ simultaneously to fit . If I do One bit and let it set it Won’t line up with the other Bit . I was reluctant to glue it all with a ‘tick tock’ over my head but couldn’t see any other way of doing it
  16. Fecking star ⭐️ Didn’t even know that existed . Yes I’ll do it on all those joints just as a precaution .
  17. Ok . I had to glue 4 joints all at once to get this to fit . Tried it dry was tricky anyway . Given I have about 30 seconds top I did ok - but some of the joints aren’t as tight as they should be . Is this ‘ok ‘ ? . Will water test in 30 mins . Assume some CT1 around all joints would do no harm . Second lesser issue . The thicker 50mm white pipe was going to be my AAV run that I wanted to boss strap after the toilet ( end of the drain ) . Can’t see how I can do that now . I can fit it after the toilet ( but before anything else ) - is this likely to cause issues ?
  18. Appreciated. It’s reassuring when someone says it’s ok . I pretended to attempt to sit on the loo - and it’s seemed ok . No good for @Onoff mind - lardy arse .
  19. The sink to the left would have a 10mm gap . Moving it right just to centre the mirrored wall unit . Can’t have wall unit off centre to the sink
  20. I need to shift the sink 25mm to the right . Wall unit is 55cm wide . Those upright edge to edge are exactly 55cm apart . So with tile backer , adhesive , tile I need to gain 25mm So sink would be about 10mm over the geberit frame ...
  21. Acceptable ??
  22. Spirit level on floor represents shower tray edge ... Funny how a relatively large ensuite shrinks !!!!
  23. Skinny asses ! Not sure what you mean . That rear wall is a false wall . Too the right of the WC will be a shower enclosure .
  24. How much can I move right ? Can I go right to the edge of the geberit frame ? My next problem now is recessed mirror requires cutting out that vertical timber the frame is attached to . How do I cut it vertically off but still have the frame supported strongly ?
  25. What about this ? Just feels really tight on the left . Once I board ( just tile backer ) and then tile . Also got to fit a recessed mirror unit above it .
