Everything posted by Pocster
I always thought this was a dark blackish colour . I ordered a bathroom vanity unit ages ago and just opened it . Box says anthracite - unit looks ‘grey’ - is this right ???
And that spinning / raising bloody shower head thing ! ?
Yeah I need to dig that out
Got another fan . Still no joy !
Just had an RK door installed. yes - pricey! But sooooo worth it!
True. Still looks tight too me . Also the Geberit original destructions do only show fitting from stud into metal frame. You didn't do it the Geberit way!!! UMMMMMM!!! ?
Well! This one didn't work. Might just be the wires need swapping around... https://www.ebay.co.uk/itm/1PC-12V-Mini-Cooling-Computer-Fan-Small-40mm-x-10mm-DC-Brushless-3-pin-JC/193264503219?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Just ordered some self tapping screws at 100mm long so will just screw through the timber into the metal frame . Less hassle than breaking the cistern !
Whats "Gently" mean???
Call to geberit - told me not to remove the cistern . Their advice drill a pilot hole into the steel then use a wood screw ! Not happy with that . Think I need long self tapping screws - can then drill through timber from the outside - then use screw that bites the steel properly.
Hey @Onoff What am I doing wrong here ? Managed to get 1 bolt in but the rest are basically inaccessible - does the actual cistern come out or something ? . Don’t see how I can get a bolt from the outside in and hold the nut ...
I believe I need this https://www.jtmplumbing.co.uk/pipe-fittings-c433/mcalpine-multifit-waste-c136/mcalpine-t16-trap-inlet-1-1-2-x-1-1-4-p22187
I'll order 2!
Ah ! Before purchase of cistern the style of push plate was ‘ unknown ‘ - so currently not bought any . That will be another decision for another day !! ?
Just mocking up the basin waste . Hard not to use a 90 degree tee . Looks like linking white waste pipe ( left poking through ) into black soil might be fun . How far ‘around’ the soil pipe should the boss strap be ? - I assume as high as possible ??
Can you please link me to the correct adaptor ?
Houston ! Check manifold of manifolds open Check inlet valve is dry Check bowl in place We are clear to flush - that’s clear to flush Houston ! Ah ! Bigger bowl required Houston ! Mission deemed successful !
Yeah elbow . I was talking all professional ? TBH I stood here thinking - I should fill the cavity behind with sound insulation stuff - like a true pro !!! ?
Warning warning ! Reaching point of commitment !! Water Hep2o inlet attached - waste in . Just got to sort Hep2o pipe to inlet . Looks like underneath I have no choice but a 90 degree tee . This is it for fitting the cistern I assume ....
Mine are 3 wire . Expensive still for a fan aren’t they
I’ve got loads of ct1 to use up ! ?
Sikaflex not ct1 ? Does it matter ??
