Pocster
    29
Everything posted by Pocster
  1. I just thought it would be quicker with ct 1 . Blob on tile , stick - repeat x 1000000 Wasn’t sure if tile adhesive would take to osb ... So this type of thing https://www.crowntiles.co.uk/cubics-grey-porcelain-wall-tiles.html?gclid=CjwKCAjwu5CDBhB9EiwA0w6sLfBL8rzaqifupt5BRQ-Ngtt87d3vDtROzBLs8DZSC3Zz8cgSI1s0dxoCkoAQAvD_BwE I presume I can place them tight to each so no grouting ! ?
  2. SWMBO wants a tiled wall inside running the full height of the stair well . About 3m wide and 6m high . So this runs from the dungeon up to the ceiling at ground floor . I’ve got to build / board a wall to take the tiles . But what should I use ? . No need for protection from damp/water . SWMBO wants some small tiles ( so probably need a billion of them ) . Rather than tile adhesive could I stick them on with ct1 ? . But stick to what ? Osb ?
  3. I’ll leave it “ as is “ for now ?
  4. That requires planning and knowing things in advance ! . That needs organisation and structure . Why change the way my project has been run now ! ?
  5. True . I did forget that . They’ll be pre hung made to measure
  6. One of my doorways is tight to perpendicular stud so there’s not much room for architrave. The doorways are all 84cm wide . Should I reduce the width of this one ( I.e screw a length of timber vertically in the frame ) so architrave will fit ? . Should I then adjust all the doorways so they are the same width ?
  7. You wait until you visit you (expletive deleted)er
  8. Yes uniqueness is a difficult thing to replicate
  9. Best thing in my house is me ?
  10. How do you know it didn’t cost 20 million ?
  11. You picking on me ? . Tbh you labelled “ plumber “ - so I’m good with that ?
  12. Yeah but we know someone will take the opportunity..... Assume the worst, hope for the best !
  13. Coooooor ! You’ve got a massive chopper !
  14. I take that as a “ yes please “ ...
  15. Been there . My daughter “ tv doesn’t work , microwave doesn’t work , oh lights don’t work “ Flick magic consumer unit switch love ! . Fixed !
  16. @ProDave some walk on glazing would go well with all that glass ...
  17. Oi ladies . Men buy Dewalt !
  18. I’m going to do it ! 2 macerators shovelling ? left , right and centre . The brave will inherit the Earth ! ( or get covered in poo )
  19. This thread is progressing nicely. We've established it is possible with some "risk". The other thread you refer to is Zoot the Hoot. I believe he has immigrated to a warmer climate. This solved his ASHP issue immediately.
  20. No. Because the liquid will run ahead of the solid from the WC. So eventually you will get a blocked pipe. Saniflo confirmed this method was a bad idea.
  21. Macerator at bog ( which is no issue ) . Then 3m horizontally to next Macerator.
  22. This type of thing for the black macerator . Block the conventional inlet and use a low one ( so I get the fall from the Wc macerator ) https://www.plumbworld.co.uk/flo-force-max-macerator-pump-101425-1252355
  23. Inlet looks too high for me . I can’t sink it into the floor ( ufh ) . Do standard black macerator have another input that’s lower than the wc one ?
  24. Sure . I know that’s what I need . My question would you be able to turn it with 3m of ? vertically stacked ? . Would it turn ? . Pressure too much ?
