Pocster
    29
Everything posted by Pocster
  1. Thinking about it . if the vertical black pump pipe is full of ? and it fails would you be able to turn the valve to isolate and stop it running back ? . Trying to think of a guaranteed way to isolate or even drain the pipe in a “nice” I.e controlled way .
  2. Should the pipe run from wc macerator to black macerator be a larger bore ? . My logic being if black macerator blocks ( for example ) the pipe will hold the contents . Or am I overthinking it now ? ?
  3. Can you get a cap to seal off the toilet standard waste input ? ( that’s what you meant @PeterW I assume ) .
  4. The horizontal pipe at the top that goes into the soil pipe . Should both outputs go into that 1 pipe ? . Or better to have a independent pipe into the soil I.e 2 horizontal pipes
  5. Ok . So wc macerator into black water macerator . So ......
  6. Erm . You’ve confused me wc has a ? macerator which then pumps to the first grey pump ( making it not grey anymore ? ) - then up and out ( hopefully )
  7. So with valves
  8. SWMBO was over again ffs Current plan is this . Macerating WC pumps ? into grey water macerator which then dumps into soil pipe . Meanwhile sink/washer etc. grey water uses a seperate pump . I’ll put valves on both vertical runs so I can avoid grey or ? running Back when they break ( not if ) . I’ll set a zwave sensor on macerator that receives the ?. So at least if it doesn’t trigger I.e draws too little current or indeed too much than at least HA can inform me . I’ll probably put a valve on the input pipe . So when it busts can turn inlet pipe and outlet pipe off . My other plan was when it fails I see no reason why I can’t drill a hole straight into the saniflo unit to drain it of ?. Trying to minimise the fun when it goes wrong . Apart from relatively easy access to the pumps any other suggestions to take into account when failure strikes ?
  9. Take your clothes off then sit on it . Far more fun
  10. Bodies from previous visitors . When are you arriving?
  11. Absolutely nothing ?
  12. That's a pants deal. How about you take said SWMBO out and take the walk on glazing. One caveat you don't bring either back.....
  13. @Big Jimbo do you want to buy some walk on glazing?
  14. I love you Big Jimbo. You see the sense in my complete (expletive deleted)ing inept madness. People on here are just worthless (expletive deleted) and want to put me down now Zoot the Hoot is dead. They need their next fix of negativity, I like screwing that's all I can say...
  15. Anyway (expletive deleted) OFF THE LOT OF YOU Just jealous because my wall has more screws in it than yours. Miserable (expletive deleted)'s
  16. 'X' 's? . Board is blank
  17. RASPBERRY! to you. I get carried away with the radio music on. If you drink a glass of wine then I drink two glasses of wine. I am better than you. But I won't 'work' any better. Also I'VE HAD MORE WINE THAN YOU! - so suck on that.
  18. My normal ! Certainly ain’t coming off the wall !
  19. Here’s a normal wall As I said that wall on the left had to be removed and re screwed . So has extra holes
  20. Doubles as an archery board
  21. Should point out that board on the left came off the wall due to “ technical issues “ I.e f up . So all those holes aren’t screws . Just saying ... ?
  22. Plasterer had to add one board . Splatter gun approach far cooler I think ! Did a good job on the ceiling though
  23. TA-DA ! ? https://www.waterlesstoilets.co.uk/toilets/separett-pee-1020-waterless-urinal-toilet/
  24. Is the spirit level having a ??
  25. Hygiene . There’s no rim , so less chance of build up of bad things . Also in my opinion looks better
