Everything posted by Pocster
Lifting AND moving, placing paving slabs painlessly.
Pocster replied to ToughButterCup's topic in Tools & Equipment
This explains why you’re such a lazy (expletive deleted) now -
Get away from my house !
Stalker !!!
Yes they are very contemporary- so if not your thing I understand .
Hi Try RK doors cheers
These are the way to go . Also look at their ‘frame’ systems . Will undoubtedly cost more but makes the job easier -
Yes !!! Do this !!
Just buy one of those mu'vers. Can sell it on later like my walk on glass. -
Because many a fella has raised your blouse ?
When looking up a skirt you don’t care about the material As they say
I knew you’d like that . Bring back memories does it of the fun in your shower ?
WHO’s A BAD MO FO NOW ! ????
I won’t swear . I will just neatly use piss colour silicone around the edges . Will further in from the edges silicone as @Nickfromwales says - apart from the bottom
I think the technical term here is “ a c@&t of a job “ Used marine ply 12mm . Used one piece for the 2 top fittings . Got 1 decent screw in but the ply had slipped . Decided to cheat and use dry wall screw as couldn’t see the hole in the ply and didn’t want to split it with a normal screw. Done 1 of the lower ones . Got the other to do - but it feels stable already . Slightly on the p*as as the valve wanted to go where it wanted to go . Slight visible over cut on tile ( knew that would happen ! ) . But can push the plate long and was going to silicone the edges as gaps due to those bloody textured tiles .
Ever played ? I just have ! . Couldn’t get the dremel in there so resorted to angle grinder ! @PeterW you were right . The screws were cack ! . All taken out slowly by hand ! I can just about gain 20mm ! Now it’s a case of nano operation to get the Packer in there ... ?
Roper Rhodes don’t do an extension kit but a 3rd party one may fit ? Regarding ‘spinning’ chrome square . O ring does go on the back to hold it . He had no idea why it spins . I can’t see why it wouldn’t ! . Anyway bit of silicone will fix that .
MVHR P Trap & outlet
Pocster replied to mike2016's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Lucky boy -
Just won’t ?
D ucking can !
Not sure . How do I extend the brass bit though ?
I did think that . If it was copper I’d be f’d
I did actually allow for it . I allowed 10mm for tile ; 5mm for adhesive . Checked this when it wasn’t tiled and backer board was on . What I didn’t allow for was tile adhesive is more than 5mm also the square collar is around 5mm . So a bit of ‘drift’ adds up . I was actually more worried about it being too far forward - so I guess over compensated. If I did it again I would deliberately leave this tile out and the backing board . Would be easier to judge and place then . Live and learn
Shouldn’t be cheap screws ( but could be ) I always buy Spax . Already thought to undo screws by hand - didn’t want to risk burring them . Once I can access all 4 - will unscrew them about 10mm or so - should be able to judge it better then .
