Everything posted by Pocster
One of those I can manage . The other - not a chance ! Managed to get some sleep once I found that reassuring old photo
Can’t sleep - this keeping me awake . Be nice if the valve was on a caddy with a screw at the front that can move the whole assembly back and forth . Anyway found an old photo . Looks like in theory it should come forward ok ...
Is it strong ? Once printed I mean ? Not brittle ????
Actually I can think of something that would pack it out and give me access . But let me get those 4 screws out first !
Not sure . I think access is the issue . But let me get those 4 screws out first - make sure enough slack in the pipework ( all Hep2o so assume ok )
Will do tomorrow
On the ensuite . Those screws are a long way back . Even if I accessed them all and removed how the hell do I pack behind them ?
No idea if pipework has enough play ! Will find out ! . Now what about that “ what do I do with it “ o ring ??
Took SWMBO’s brand new tv to site ( so I can sort Ariel ) . Screen smashed ? Not a good day today !!
Yeah but I use all the spares for my f ups ! Then there are no spares ? Looking at the ensuite one again . I’ve marked in pencil the face plate corners . Might be able to dremel a wider opening so I can get to the fixing screws and perhaps pack them out
@Nickfromwales unless roper Rhodes come back with a mega solution to the ensuite valve being recessed to much I’ll smash the £&£&& tile out ! Got to make sure tile supplier still has some in stock first !!
Ok . The square collar has an internal o ring which does indeed go against the spindle collar . It’s this other o ring I don’t get . Taking it all apart , putting it on the collar ( so it would have a o ring inside and outside ) it won’t fit in the face plate . You can see it’s mega tight
You mean the bathroom one ? I can’t see where these o rings sit ( those collars are the only things with a ‘notch’ for something . The collars do have a o ring in them already ( which presumably goes against the spindle shroud ) .
Noooooooooo ! Playing with the main bathroom one ( as it’s easy to adjust ) . Instructions show none of this but hey .... Black o ring on reverse - this makes sense ! . But the square chrome collar can still turn !
Emailed roper Rhodes ; they have a special email address for these issues im_a_twat@roperrhodes.ffs
Main bathroom easy . Must of sub consciously anticipated an issue . Can simply push the whole fitting forward ! Can gain 10mm no issue ?? Ensuite though ... erm ..... can’t access from the rear !!
@Nickfromwales got you . This ensuite valve I can’t move forward without smashing the wall apart ( ain’t going to happen ! ) . So can I ‘stick’ something on the end of those spindles to gain 15mm ?? Or anyone got some insane skills to ‘cut’ 15mm off the handles ! ?
Took this end off . By making the screw loose I can gain a few mm . But now of course it wobbles ! Is this a ‘standard’ fitting ? ( need a longer one ! ) . Or what’s a good way to ‘pack’ the end out to make it longer ?
Don’t get what it goes around ? The spindle ???
I might of (expletive deleted)ed up here ! Cant get knob grub screw to bite spindle ! Presume valve is too far back - can’t move it !! Only about 2mm short ! ?
Stupidity on my part ! Instructions https://www.qssupplies.co.uk/bathroom-furniture-shower-taps/75877.htm# What I don’t understand is what stops the water going in behind the controls ? ( I don’t mean the face plate ) Sure I could stick some sealant around it - to stop water running behind the wall - but it could still go around the spindles . So white plastic ‘bits ‘ . A square chrome ‘collar ‘ - but that just sits in the hole - no fixing ; silicone again ??
