Thorfun
    36
Everything posted by Thorfun
  1. nice. I've decided to do ferrules at both ends. been going great guns this evening and got quite a bit done. will keep going whenever I have free evenings!
  2. same as @Pocster but didn't foam. our plant room is in the basement so basically everything pretty much goes up!
  3. nice. I do have very extensive schedule documentation so I'm hoping it goes quickly. I can definitely see the benefit of having a second pair of hands to assist. while you're on I have another question for you. in the photo of your cabinet I notice that you use the bootlace ferrules at the Loxone extension end as well as the terminal block end for the tri-rated cable. is there a reason why you don't just put the cable in and screw it down? I understand the need for the ferrules at the terminal block end as it's push-fit so needs to be solid but for screw terminals what's the reasoning behind it?
  4. thanks. I made a start in a spare hour I had this evening. I'm pretty sure I'll get quicker at I go along! it's going to take a while though as I only have a few hours a week I can spare on doing this with all the other stuff I have to do but I will get there.
  5. evening. qq. on the Loxone Relay I'm presuming that there isn't any sort of polarity with the relay outputs and it doesn't matter which way round the live and neutrals are put in? I couldn't see any notation in the data sheet so figure it's just a switch and it doesn't care if it's switching live or neutral.
  6. I bought some of this https://www.toolden.co.uk/sealants-adhesives/adhesives/grab/illbruck-pu700-multi-purpose-construction-adhesive/?gad_source=1 seems pretty solid. used it to stick timber to my screed that has ufh pipes in it as I didn't want to screw into the screed. can't you use fixings though? would be rock solid with mechanical fixings
  7. i'm not sure on the regulations but i believe the balustrade needs to resist a certain force and have certification that it does so. maybe Stairbox won't give that certificate if you don't have the extra newel post? 🤷‍♂️
  8. But if you move the shower further from the soil stack won’t you need to dig more concrete out to get the fall to it from the shower trap?
  9. Thanks for the lovely comments about my thread. I wish I could help you but I do really still not know much! I’d have been lost without the wonderful help from the knowledgeable folk on here. Hopefully someone can help with your questions. I did try reading the building regs on the subject of waste but got quite confused! If you’re smarter than me (wouldn’t be hard!) then maybe you can try and glean some knowledge from them. best of luck!!
  10. that's some interesting maths! 🤣 but i understand the sentiment. that's the chippie's problem. 😉
  11. what's the price difference between a solid core 35mm door and a 44mm FD30 door though? probably not a lot. we got a good deal on FD30 doors, they're bloody heavy and should be a good solid door. we got these XL Joinery doors for ÂŁ143+VAT from Jewson. the 35mm version were ÂŁ83+VAT.
  12. i've been told by quite a few friends to get FD30 doors anyway as they're much more solid. yes, they're double the price but you can get a deal if you shop around and i dislike the flimsy feeling non-FD30 doors. ymmv.
  13. Check on the Ubiquiti forums or log a ticket with their support. Maybe someone else has seen the issue or maybe it’s a bug they’re unaware of.
  14. although that says system data and configurations, not firmware. so I'm not sure that the restore from backup will revert the firmware update. seems to be lots of posts on UDMPro rollbacks but not UDR. https://www.google.com/search?client=safari&rls=en&q=ubiquiti+dream+router+firmware+rollback&ie=UTF-8&oe=UTF-8#ip=1
  15. log in to your Ubiquiti account. i navigate to 192.168.1.1 (the IP of my DMPro) from my internal network (whether wifi or cable shouldn't make a difference as you're on your internal LAN) and log in to the web page that shows.
  16. I don’t really use the app much. Much more functionality connecting with a web browser
  17. At least the grout is a decent colour.
  18. How much did the CT1 leave the pan off the wall? 1mm? 2mm? Or more?
  19. Yeah, sounds like that’s right out of @Nickfromwales’s playbook! was just curious if anyone had gone the foam sheet route and had any feedback.
  20. I turned off auto updates on my Ubiquiti kit early on after issues with an automatic update. Now I update manually after ensuring no major issues are found. Sounds like you’ve just exp the same. can you rollback the update?
  21. Ahh….right. I was asking about those foam sheets that sit between the pan and the tiles. I presume you just used CT1 on the back of the pan to cushion it against the tiles? I have read your thread but it was a long time ago! I’m sure most on here just use CT1 as I believe that’s what @Nickfromwales suggests but the MI for our pan shows a cushioning sheet between the pan and the wall so I thought I’d ask the question.
  22. I thought the sound pads were to reduce noise of porcelain against tile?
  23. Not even a “don’t waste your money”?
  24. Welcome!!
  25. we have the Hallmark Trojans as well. supplied by a local dealer https://www.powellblinds.com. we planned for them from the off and so they are hidden behind the cladding above the windows. when they're up you can't tell that we have them.
