Thorfun
Everything posted by Thorfun
We agonised for ages over the same dilemma. Then I realised that after I sprayed water on the various shades of different slate samples they all looked exactly the same. ended up going for the cheapest option we had. I’m sure I wrote a blog and a few posts about our slate journey. A quick search will find them but I came to the same conclusion as the others above.
Buying a SDS+ drill - how many joules needed?
Thorfun replied to Sparrowhawk's topic in Tools & Equipment
my Erbauer SDS+ has done me very proud. cored multiple holes through concrete blocks too. -
Planning conditions still outstanding🙈
Thorfun replied to Amateur bob's topic in Planning Permission
no. these were pre-occupation conditions. we are demolishing the existing property after the new house is built so i submitted the demolition notice and the council sent me an email saying "we've received a demo notice but you've not discharged these pre-occupation conditions you naughty boy". if your builder is starting in Feb i would say that's plenty of time to get the conditions discharged. i'd even go so far as to say that as long as the application to discharge is in place chances are it won't be a problem. but you've got 3 months so i wouldn't worry. just get it in as soon as possible. -
only submitted a few days ago. we received a letter saying that they've received the application. not sure how long it will take for them to discharge the conditions though, sorry. -
£63/m2 exc VAT in Feb 2022. I did say it wasn't cheap! 😉
I've recently had to discharge pre-occupation planning decisions. the architect dealt with it for us as it involved submitting a detailed landscaping and planting scheme and he already had all the plans so didn't take long to update drawings. cost us £215 to the council to discharge them! <expletive deleted> money making scheme if you want my opinion. my cynical self thinks they just add this shit on so they can get more money in their coffers. -
also, won't the gas boiler already be running to heat the rest of the house so adding a bit of wet ufh to the boiler won't make much of a difference, right? not sure why you're even considering electric tbh.
Oh right! We bought ours ready charred. Edges are fully charred and the back was also blackened but not charred to the same extent as the front. might be worth asking @Tom if he did his all around as he said he did his himself.
Not sure what you mean?
We did similar to @nod and was labour only. I saved loads by doing second fix myself which sparky was happy to sign off. Also our lighting is controlled by Loxone and I did all that so electrician didn’t get involved in that side. there are ways to save money if you’re will to do the boring work ( and wiring up faceplates is really boring!) and have a friendly sparks who’s happy to do be accommodating.
Not cheap but we went for Shou Sugi Ban (charred timber). Looks amazing and no maintenance at all. With the benefit of being fireproof, insect proof, weather proof.
found this system in the white book which i could emulate. might stick a 3rd layer of 12.5mm standard pb to the partition wall or a layer of MLV.
I presume these are the same as resilient bars?
Rehearsals/jamming
it's an interesting idea but, tbh, i'm not too worried about how it sounds at the moment i just want to reduce the noise in the rest of the house. once i have that down to a dull-roar i can worry about treatments in each area to improve the sound quality. if that makes sense!
not a french door but a double width opening for double doors. but i'm not worried about that as i will have the new stud wall as a barrier between the live instruments and those doors. i've thought about this and looking through the white book at their specific audio walls there's this option but it's 300mm thick which will eat in to the already small space of the control room.
yeah. I agree with this. I'm actually thinking about hanging the door opposite directions as well so that the hinges/latches are at different ends. the music room and control room area already has MVHR in each part as I always thought about doing this splitting of it. and acoustic sealant was definitely going to be used everywhere! yep. dropped metal ceiling in the plan. 🙂 ok, so this makes sense and having the 25mm of fluffy stuff (not necessarily RWA45 though) behind the plasterboard of the perimeter walls will help with this but be negligible for the total mass of the wall. I have been looking at acoustic foam but wasn't sure I wanted the entire room covered in it but I'll research it some more. so I think you're saying that on the perimeter walls where I have the concrete and blocks a single skin of 12.5mm plasterboard will suffice as those walls already have a lot of mass. so my concern is the partition wall and ceiling (as I thought!). I can't use soundbloc as that only comes in 1200x2400 sheets unless I'm willing to cut it in half and then carry it down to the basement. but I did find Gyproc Plank which has a density of 14.7kg/m2 (denser than Soundbloc F) and comes in sheets of 600x2400. so I'm now thinking a layer of that with a standard 12.5mm plasterboard on that should give a mass of around 22.7kg/m2. I know MLV is expensive but if I add a 2mm sheet of that which gives 5kg/m2 that will be a total of 27.7kg/m2 which is almost the same as 2 x 15mm Soundbloc F (28.2kg/m2). there is also the block and beam flooring above the metal ceiling which has a 50mm concrete screed on top of that so I think that should suffice! totally get this but it's knowing when to stop and fitting it all in our now non-existent budget.
I believe so. XL are good doors but double check the spec yourself to be sure
No. Went for XL joinery from my local Jewson who gave me a good price.
greetings all. as a kind-of follow on from I wanted to start a new discussion on my sound insulating needs for the music room in more detail as I'm concerned I'm overthinking and over-(sound)engineering things as usual. this is the music room. I'm planning on splitting is as shown in to 2 separate rooms, one with the recording desk and the other for the instruments. the room is in the basement and the hashed walls are blocks laid-flat, so 225mm thick and the outside walls are 250mm reinforced concrete with the earth outside. I was planning on using this system from the Whitebook but with a second skin of standard 12.5mm board for the pre-existing walls (I need to use standard board as I can't fit 1200x2400 boards down the stairs to the basement so need a board that comes in 900x1800mm) but I'm wondering if that's complete overkill! I'm doubting that the Rockwool insulation with have much of an effect when there's 225mm concrete blocks behind it as that mass will stop a lot of the noise. and for the outside walls with the earth behind what's the point of even doing a second skin of plasterboard!? so I'm leaning towards scrapping the idea of the 25mm layer of insulation and the second skin, what do you think? I'm thinking that my focus for sound insulation needs to be on the new partition wall, the door ways and the ceiling as the kitchen is above this room. so for the ceiling I am planning on using this system and putting 100mm RWA45 above it and also putting a layer of MLV between the 2 layers of standard 12.5mm plasterboard. for the partition wall I was thinking of using this system and also putting MLV between the 2 layers on the music room side of the wall. for both the doorways I am planning 2 x FD30 doors with MLV on one face and sealed around the edges with rubber. I would appreciate anyone's input on this. tbh, I think I'm happy with the partition wall and ceiling plan but I want someone to tell me honestly that anything more than a single skin of 12.5mm plasterboard against the existing block and concrete walls is a waste! and how, if at all, would you do it differently. for context, our drummer is really <expletive deleted> loud so the amps have to be cranked up to be heard over him. previously as rehearsals we hit around 106dB looking at my Apple health data.
+1. I splashed out on a Dewalt and the accompanying leg stand for it. Well worth the money. It’s done everything from skirting, flooring, stud work and lots more. just don’t tell @Pocster I bought yellow and black as he’ll never let me live it down.
