Onoff
    207
Everything posted by Onoff
  1. You have to be careful with some of the pipe seal products as some are not meant for use on potable supplies!
  2. I tried the No Nonsense stuff. A biatch to get out of the bottle after the first few uses. Sets too hard for my liking as well as in a git to undo joints afterwards though I was quite liberal with it. The fact that Jet Blue Plus sorted my 25mm MDPE to brass stopcock weep at 9 / 10 bar convinced me on it. Makes doing up a compression fitting a pleasure. It lubes, quietens and allows it all to nip up tighter.
  3. This is the stuff I have: https://www.plumbcenter.co.uk/product/center-center-jet-blue-plus-500-g/
  4. An all metal AMD3 consumer unit under the stairs would have done Jack Schitt in this case! Phew! Not a bad shout to have a smoke detector in there for future peace of mind.
  5. There's some on the way home I pass every day that look the mutt's nuts. They come up automatically out of the ground as a barrier. Like this: http://www.ardengateautomation.co.uk/barriers-bollards-c12/bollards-c13/beninca-24v-vigilant-500mm-automatic-rising-bollard-p383/s384?utm_source=google&utm_medium=cpc&utm_term=beninca-24v-vigilant-500mm-automatic-rising-bollard-vigilant500&utm_campaign=product%2Blisting%2Bads&gclid=EAIaIQobChMI7YyS__mC2AIVpbDtCh2POg0wEAYYBSABEgLWHfD_BwE
  6. I always previously had the most issues with compression joints, having to really give them loads of grunt to do them up and them ending up squeaking!. I used to use PTFE tape. Not any more, now it's Jet Blue Plus paste. No more weeping joints. Lubes and seals. Superb stuff IMHO. For copper I have the Benzomatic torch and MAPP gas.
  7. I couldn't agree with you more!
  8. Thanks, useful link, I shall order one. In the photo above of the old patio doors I'm pretty sure I can feel a strong draft up where the frame meets the wood trim / meets the (lilac?) painted woodchip over hardboard wall. It might be that the doors were just fitted in a ragged hole. A liberal application of gun foam around the edges might help...If I could get in there. The door & frame is white painted / powder coated aluminium so I guess an emissivity of 0.9?
  9. Are these cheap as chips, eBay laser pointer / IR thermometers any good for pinpointing cold spots around doors and windows? You can buy similar in Screwfix (Titan brand) for £35): https://www.ebay.co.uk/itm/Digital-Infrared-Handheld-Temperature-Gun-Thermometer-Non-Contact-IR-Laser-Point/332426284743?epid=1756017825&hash=item4d66268ec7:g:tZEAAOSwyGZZ8ZGh
  10. So far, so good. Now to get this touch screen going!
  11. The Yanks seem keen on building South facing doors as solar warm air heaters in their own right. Clear plastic front face. Thin slit at the base, air gets drawn up over a black painted fly screen mesh backed by foil faced PIR. Exit duct at the top rear. Small pc fan optional driven by a small PV panel.
  12. That's handy! Found a a 250GB 2.5" SATA drive from an SSD upgrade on my brother's pc a while back. So out with the 40GB original which of course will mean all the drivers etc stay intact.
  13. I tried that. Think it might have worked but my leak was under a concrete path rather than under "dirt" along the run. Stick it in a hollow tube concentrates the sound. I used a scaffold type metal tube the same dia as the stethoscope. Make a good directional mike if nothing else!
  14. I might have another go but tbh bored now. Will probably just Linux it up and give it to my mate who's after a basic desktop. I need to make a presentable desk stand for it really to allow it to sit at comfortable angle. (I saved the same mate from buying a Mac a while back by putting Zorin on his old Vista laptop! )
  15. It's in Sys32..Drivers/DrvStore etc. I didn't just plug into the ethernet port and try IE...I really didn't!
  16. So its an Intel Core Duo CPU U2500 1.2GHz with 1GB RAM. Where do all the drivers live in XP in case I want to go back to it as a pure XP machine for just AutoCAD? Seems Zorin OS has good touchscreen support. Just downloading 12.2.
  17. Belay that, its DIMM slot 1 that appears goosed. The 1GB original stick works in slot 2:
  18. GET IN THERE! I had a spare PC2 memory stick in yet another "piece of crap" I was considering dumping! Seems it was the memory stick at fault. Just got to decide on what flavour to put on it but looking good!
  19. Anyone got one of these? https://www.ebay.co.uk/itm/Water-Pipe-Leak-Detector-Electronic-Stethoscope-Earphone-Detection-Equipment-Kit/322555337835?hash=item4b19cbdc6b:g:aq4AAOSwjvJZQkPG
  20. Having another play. Just tried clearing the CMOS - page 59...to no avail! http://literature.rockwellautomation.com/idc/groups/literature/documents/um/6181p-um002_-en-p.pdf EDIT: Just put the memory in the other slot and it started "better"....no 1/3/4/3 beeping. Just ONE single beep. Going to put the touch screen back on now...
  21. To get video out from VGA or DVI.....in the BIOS or like in a laptop Fn+F4?
  22. Nope, it's got a 1GB stick in it. Just can't fathom the no screen action at all when the DVD is "working".
  23. Here's another reason to insulate. For me outside "work" at home stops when the weather is like this. If I had a decent, insulated workshop and garage I could get in with other stuff, mad little projects etc. Btw, anyone want plans for a snowmobile? A vintage design with ply body but easily brought up to date with a GRP shell. (Quite serious). Things like that I could be doing in a WARM workshop!
  24. Many times! I wouldn't know where to start with the finance etc. I've already got 3 mortgages!
