Everything posted by Onoff
Around £230 for 25kg and it comes with it's own plastic containment vessel! If there's space for expansion inside the Sunamp then how does it expand / rupture? For some reason I always thought the PCM was contained in a vacuum, is it?
Yeah but this a box with sharp corners and dodgy welds. They probably need to take a leaf out of sealed lead acid battery book. That plastic enclosure looks less structural than a washing up bowl. If you took the appliance white shell as the biscuit tin, the containment the translucent flimsy insert that holds the biscuits! Is the thermistor string in its own tube or direct in the PCM?
https://onlinelibrary.wiley.com/doi/abs/10.1002/maco.200290004
Did he say earth loop impedance?
I was thinking fill the container with the PCM post welding. Tbh they could have a fine thread filler cap. I'd hazard make the containment well and strong enough out of stainless and it would nigh on be immortal. You could even periodically swap out the PCM. I wonder if there's any mileage if someone had an old unit with failed containment to do just that.
Why not use a grade 316 marine grade stainless box to contain the PCM? Could be TIG welded and internally braced to limit "swelling". Thinking 316 (marine grade) stainless would be ok with the "salt" that is the SAT. OK this is ali but I know some mustard TIGists:
Is this a new issue? Is the B20 RCBO he's fitted the same make as the C16 one it replaced? The type of RCD section within RCBOs can vary: https://www.electrical-installation.org/enwiki/Types_of_RCDs The individual RCBOs should have an RCD test applied to gauge tripping and also their ramp times. The fact that it's been upped to a 20A and not tripping is perhaps telling. B curve is for low inrush currents, C for medium and D for high. If it's an inrush issue then it's usual to go from B to C curve or even D not the other way. If the cumulative load is too much for the incoming supply then you might need to think about spreading it across phases if you have 3P coming in. Or timers. As for diversity on heating then in a domestic premises this would be 100% up to 10A + 50%. There are other ratings for other than domestic in the OSG. Find out the rating of each unit.
If the floors solid you could likely fix down 4 sides with CT1 or something.
I was worried you'd been ill when I read that!
I would print in ASA. The X1C will handle it without issue. ASA has something like ten times the UV resistance of ABS.
Forming shower niche - after installing backer board
Onoff replied to markharro's topic in Bathrooms, Ensuites & Wetrooms
No probs at all cutting out for a niche. Consider your niche vs tile size carefully so as to end on a grout line, consider how the trims will sit etc. Oh, and use a tile spacing / levelling system, wish I had 😡 -
I'll raise you square guttering with 3D printed end cap etc.
If was @Andy T iirc. He retired from Sunamp circa 2018.
Salt 'n vinegar crisps? Found this that suggests SAT in it's raw state can suffer issues. I don't for a minute pretend to understand most of it but it seems to suggest SAT needs certain additives to be used successfully as a PCM. https://pmc.ncbi.nlm.nih.gov/articles/PMC7040703/
Sunamp-Thermino-Brochure-JUNE-2022-v2.2 (1).pdfIs the PCM in your "original" unit perhaps different to what's in their current Thermino range? PDF attached. Be interesting on how many similar failures they've had and whether the containment is fit for purpose. Imaging it splitting over a kid's room / cot.
MVHR into a cold roof ?
Onoff replied to Post and beam's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Is there a standard lagging / thickness for MVHR duct in a cold roof? -
Seriously, I'd be happy to pop down and help lift it out etc.
Would an extra pair(s) of hands help with the heavy lifting?
& it still leaks!
Poor bloke, of all the people who could have welcomed him back... 😂 Can't help thinking a 6 year life for a product, that then fails like that, isn't a great advert.
Welcome back! I still haven't finished the bathroom btw..
Overusing expanding foam - an issue?
Onoff replied to lookseehear's topic in General Construction Issues
Illbrück FM330. The end.
