Everything posted by ToughButterCup
@Triassic, they take cold water only, or preheated water.
Because.... ? (remember Germans have no sense of humour reportedly)
Shoes lined up in the morning, shirts all pressed to perfection, tooth brush colour-coded, neatly spaced ties in the tie rack, bread well-polished? I admire you both.
I am looking at my HEP2o sample as I type this. With online help available from @Nickfromwales, and wait for @TerryE to make and report a few mistakes, what's not to like? We're using electric underfloor heating. With a SunAmp for @MrsRA's nightly excursion to the paddling pool, that means we don't need to store any hot water, and almost no hot pipe runs anywhere. Local water heaters under each sink. Which means HEP2o will only need to deliver cold water, except for the hot water run (1000mm) from the SunAmp to Debbie's bath. Yes, @JSHarris taught me a lot, and saved me a few thousand pounds.
Cleaning Runoff from Anti-Climb Paint
ToughButterCup replied to Ferdinand's topic in Networks, AV, Security & Automation
(His wife was gorgeous) -
George Formby. I had one customer who played the tune on his banjo every time I arrived. He was the Channel 4 Racing commentator then... name forgotten. -
The window cleaner. Meths'll get it sorted. As some may know I spent 7 years cleaning windows to keep the wolf from the door while studying. Customers regularly asked me to do little 'extras'. Don't ask. -
Delicate, annoying opportunism. Advice needed
ToughButterCup replied to ToughButterCup's topic in Planning Permission
Silence is the loud reply. Ian- 35 replies
- planning
- part 4 gpdo
(and 2 more)
@Temp, its the one just to the south of my house (PM sent with details) Ian- 35 replies
- planning
- part 4 gpdo
(and 2 more)
Thanks everyone for your contributions. Quite apart from the legal and technical aspects of the issue, it's very reassuring to have access to so many people with whom I can share a problem. None of you had to respond. Ian- 35 replies
- planning
- part 4 gpdo
(and 2 more)
People construct their own online Learning Networks, @Ferdinand. And what people learn from any resource is not always what the producer intends. I always bless @Construction Channel : he has no idea how much his vidoes have taught me about building. I have watched almost all of them 3 times - and each time I learn something new. Poor Faye for one thing
Yes, they can. But they are better than nowt.- 35 replies
- planning
- part 4 gpdo
(and 2 more)
and boys This is what Our Local King of Planning says is happening (in an email copied to me) - the applicant made an application to add a house to the site , and because he did that a blind eye was turned to the caravan. But that application failed. Magically, the caravan is needed to support the build of the stable. And absolutely no progress in building is being made- 35 replies
- planning
- part 4 gpdo
(and 2 more)
Thanks @Temp, I was hoping for a dose of clarity from you. I read a hint into Not so difficult if photographic evidence of inaction , complete with EXIF data (meta tags) were to be obtained. Perhaps? Ian- 35 replies
- planning
- part 4 gpdo
(and 2 more)
Thanks everyone for your interest and input. I feel a bit of local networking coming on.- 35 replies
- planning
- part 4 gpdo
(and 2 more)
To quote the head of planning; '.... Unfortunately [... name...] is currently using Part 4 of the General permitted Development Order to justify the caravan remaining on site. This allows for the provision on land of buildings, moveable structures, works, plant or machinery required temporarily in connection with and for the duration of operations being or to be carried out on, in, under or over that land or on land adjoining that land....' and '... If the works are either permitted development, or have the benefit of planning permission then even if [s/he]is carrying out those works at a slow pace, that would be sufficient to allow [...] to remain with [his/her] caravan on the site. ...' I can't see the logic either - the works are in progress in relation to a stable. I could see the logic if the issue were to be in relation to a house.- 35 replies
- planning
- part 4 gpdo
(and 2 more)
Thanks. I got cross a few hours ago but it's gone now. It's the fair-play issue which gets to me most. And you are (all) right diplomatic nudges are the way forward. Now, where were those Thunderflashes a mate acquired for me a few years ago?- 35 replies
- planning
- part 4 gpdo
(and 2 more)
You are right. I should just get on with it. I sense a slight shift in my thinking - just keep gentle, polite, consistent pressure on the Council to draw things to a close. A carefully worded letter every few months will do. Ian- 35 replies
- planning
- part 4 gpdo
(and 2 more)
Take care. One or two over the eight, a bit of a happy-dragon doze; it doesn't need to catch fire, just smoulder and smoke until the almost inevitable Forgot to add: Stihl do some 'twisting' wedges: get four, that'll see you through the largest tree. Split in half and half again; a cheap saw will cope with the results
Is that stipulation a locally applied bit of legislation? I'm not fighting with my neighbour, I'm cross with the behaviour. Curiously, I also have a grudging admiration for his doggedness. @jamiehamy, you sound like a close relative of mine @MrsRA. That's exactly what she'd say I suspect.- 35 replies
- planning
- part 4 gpdo
(and 2 more)
Yes, there is and they are here: called the General Binding Rules Just a bit of me suspects you might need the Scottish rules, though? In which case, here 'yar Jimmie! Ian
If driving past Lancaster on the M6, you see the tell-tale mushroom cloud of a nuclear explosion, that'll be me. And here's why. Advice please. The land next door to me has planning permission for stables. The owner applied for and was refused planning permission for a separate house on the same land. The subsequent appeal was rejected. The owner continues to live there in a caravan. I asked for advice from my Councillor. This is the response she got from the Head of Planning (verbatim) We are investigating it and will take any necessary enforcement action if and when a breach of planning control is clearly identified. Unfortunately [... name...] is currently using Part 4 of the General permitted Development Order to justify the caravan remaining on site. This allows for the provision on land of buildings, moveable structures, works, plant or machinery required temporarily in connection with and for the duration of operations being or to be carried out on, in, under or over that land or on land adjoining that land. Any building, structure, works, plant or machinery permitted by Class A must be removed when the works are complete. We will check to see what works [s/he] is carrying out and whether they have or need permission. If not we will take appropriate action. If the works are either permitted development, or have the benefit of planning permission then even if [s/he]is carrying out those works at a slow pace, that would be sufficient to allow [...] to remain with [his/her] caravan on the site. We did try to enforce a similar case a few years ago where we felt that the works being carried out were of such a small scale and being carried out at such a slow pace but an appeal was submitted and the council lost. We therefore have to be careful that our case is robust this time. One interpretation of the Head of Planning's response is that it seems to be OK to take 10 years to 'finish' the job because at the end of that time, the person has a right to build. What does temporary (above) mean? I am in dire need of advice on a strategy to deal with this issue. A good outcome for me would be for the applicant to build the stables, and then move out. Or apply successfully for planning permission, and remain.
- 35 replies
- planning
- part 4 gpdo
(and 2 more)
Roof Lights: glass or polycarbonate
ToughButterCup replied to ToughButterCup's topic in Roofing, Tiling & Slating
Eye bolts in the rafters, and some strapping on the top ladder rung - attached to a carabiner. Same method as when I cleaned windows to keep the wolf from the door when I was a student. The Winter Garden was Sam's idea (architect) and @MrsRA fell hook line and sinker in love with it. I like it too, perhaps more from the point of view that the light from the garden will filter into every room in the house except the loos and the utility room. It certainly gets people talking. It's such a small house, and to devote so much space to a garden inside the building means that we will have to be really super careful about its maintenance.- 17 replies
- roof light
- roof
(and 4 more)
Snot fair! Too smart! Ubersmart in fact.
