Russell griffiths last won the day on September 19
Russell griffiths had the most liked content!
Personal Information
Location
Gloucestershire
Russell griffiths's Achievements
Advanced Member (5/5)
3.3k
Can you buy the rubber bung separately and retrofit them to the gulley you have.
External type A Liquid applied membrane - holes?
Russell griffiths replied to Ed_'s topic in Basements
Spray it on. go and get a forced action sprayer from the hire shop. look at some American YouTube it’s common practice over there. -
Air tightness around floor joists.
Russell griffiths replied to flanagaj's topic in General Self Build & DIY Discussion
With the amount of good flexible liquid coatings available I think I would forget the pain of the Tony tray and just paint around the joists when it is all up and the roof is on. you could spray airtight paint around them and that would get every nook and cranny. -
Electrician planned it all really all cable runs to led strip is flex as a bit of it is 5 core for colour change strip, I think white only requires 2-3 cores cable is relatively cheap take everything back to a central location, no need to hide drivers in cupboards or under kick boards. Robus is the make of the controler units. if I was to build this again I would not bother with 75% of what we installed, never use them, spend most night with a couple of table lamps on. do you actually need lights in cupboards lighting up some old shite tea set the wife was given. and for the life of me I don’t know why anybody thinks lights under the plinth in the kitchen is a good idea. I think I could have scrapped about £2000 worth of pointless lights we installed.
- 13 replies
- led lighting
- led strip
(and 3 more)
Lead flashing - maximum length?
Russell griffiths replied to Great_scot_selfbuild's topic in Roofing, Tiling & Slating
Get a copy of the Calder lead guide, very useful booklet. probably available online. -
All our drivers and led controls are in a central location with a flex running to the led strips. no driver or control needed near the strips. All dimming and colour changes done on an app, al switching on and off from a switch on the wall.
- 13 replies
- led lighting
- led strip
(and 3 more)
Have you seen the plastic box that sits in the ground, the tap is underground as well as a roll of house pipe all enclosed in the plastic box.
Haven’t read this all but just as a quick one, instead of a central glue lam, change all rafters to kerto beams, they will span longer, will not warp and twist, will come straight. they will need painting as they may not be that attractive unfinished. just a quick thought to chuck in the mix.
Do you mean the gap between the door stop and the door which I think you do or the gap around the door to the lining. if you have fitted the door into the lining and now need to fit the door stop, the standard gap to leave for four coats of paint would be the thickness of a thin credit card, or an old business card, aprox 3quarters of a mm. 2-3mm gap is the gap between door and lining.
Expansion provision for Hep2O?
Russell griffiths replied to Alan Ambrose's topic in General Plumbing
You don’t. there is absolutely no reason to be heating your water to that temp, so expansion is not a thing to worry about. -
Subsidence in Bristol
Russell griffiths replied to Pocster's topic in General Self Build & DIY Discussion
These older houses can be built with lime mortar and a bit of movement is expected, stitch something together ridgid and you move the cracks to another part of the property. im no structural engineer but have been removing trees from properties for the last 40 years when the finger gets pointed at the tree, I’ve been on sites where you could shake hands with the neighbours through the cracks in the walls 😂😂 -
What do you want to know, shrinkable soil, shallow foundations, two of the driest summers on record. there is going to be some serious insurance claims in the next few years. -
I thought some of the manufacturers of these sheets supply the ends with the insulation cut back, you 100% don’t want the insulation exposed, creatures will chomp at it, definitely needs a flashing over it.
- 9 replies
- eaves flashing
- gutter
