vivienz
Everything posted by vivienz
Ah, thanks chaps. OH has managed to get it undone and there is no washer. Looks like a trip to Screwfix.
I noticed a leak from our washing machine waste pipe, on the upper entry side to the u-bend. It's been leaking for a while, as you can see from the effect on the plasterboard. What's the best way to seal this? I should add that I can't loosen the joint.
I'd silence every part I could. Ours has been in for a couple of months now and is located in the loft space above the upstairs landing and our en suite. On any setting above the lowest fan speed, the noise from the unit is like being on a car ferry when it revs its engines up. It's especially noisy when the integral cooling pump comes on - quite thunderous in the en suite and enough to keep you awake at night in the adjacent bedroom.
I have 2 heated towel radiators in my bathrooms that are wired to come on with the electric UFH. Can anyone recommend some not too clunky/expensive elements to put in these? Thanks!
Ventilation Boost switches
vivienz replied to Stones's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Ah, thanks. It seems that I have some redundant switches, then. -
My unit is an ecocent from earthsave products; other than that, I can't tell you much about it, I'm afraid. -
Giving this thread a bump. My bathrooms and downstairs loo have a switch next to the light switch, on the same face plate, that is to allow a timed boost to the MVHR to extract any overly pungent smells after the deed has been done. Although the switches are there (they are rocker switches, I believe) there is no circuitry to link and tell the MVHR system what to do. What should I be looking for to put this right rather than have redundant and confusing switches? Is there a proprietary box of tricks that can be purchased? Thanks. -
That makes sense. The system has been designed to have zoned heat as, otherwise, what's the point of thermostats in each room rather than one single one for everywhere. The hardwiring is in and I currently have cables dangling out of the walls next to the light switch in every room.
Depends on who is behind it.
kill grass and weeds permanently
vivienz replied to deuce22's topic in Landscaping, Decking & Patios
Not the best time of year for weedkilling as they are dying down anyway about now. If you use glyphosate it's best to hold off until late spring/early summer when there is maximum leaf coverage as the chemical is absorbed through the leaves. -
Why does it need to be glass? We've got a pocket door to our main bathroom and it's a standard door but with sliding kit into a twin stud wall.
In the near constant temperature world of UFH and a highly insulated building, does the GMT/BST thing matter?
Thanks, chaps. The bathrooms aren't in the wet UFH loop, I have electric UFH mats and heated towel rails, although there are no elements in the towel rails yet, so the bathrooms will be okay once this is done. I don't mind not having the downstairs heating zoned - there's not much point as far as I can see, but I would prefer the upstairs to be zoned as one of the rooms is my office/sewing room and I don't want to get chilly in there. For the downstairs, then, I'm okay to get hold of some programmable thermostats (not interested in smart ones) and get them wired in, from the sound of things, and that will at least sort out the ground floor.
Sorry for the delay in posting pics here, Sunday lunch for the outlaws gets longer every time; it will extend into a candlelit supper before long (on Royal Doulton china with hand-painted periwinkles, of course). Anyhow, these are photos of the ground floor UFH manifold and the gubbins in the garage, including the willis heaters. I believe that the UFH circuit isn't commissioned yet, in so far as the pump isn't wired up and the pipes need bleeding, so it's just the ground floor for now. I'm not sure how much longer the house will remain at a comfortable temperature so I need to get the room stats sorted asap.
My MVHR is mostly done now but the extract that's in the main bathroom remains to be done before it can be balanced and commissioned. In an effort to conceal, or at least make them less obvious, the extracts were located on the side of the niche that is above the concealed loo cistern. The photos are clearer than my explanation. All of the other vents are the shiny white round ones I posted about earlier but I can't see these working in this location. I have seen others in a more appropriate shape but wondered if all the vemts in a system have to be the same. Can the hive mind offer any wisdom on this, please?
Apologies, Dave. What I meant to say was room thermostats that will control the call for heat. Currently, the full ground floor heating can be on or off but no control over the temperature. Everything that is down the line from the room thermostat is in place. I should add that I won't be installing these myself but will have an electrician put them in. Thanks.
I have UFH in my slab and upstairs but as yet have no controllers connected. I understand that I need programmable controllers - can anyone recommend any for this purpose?
What ya building.
vivienz replied to Russell griffiths's topic in General Self Build & DIY Discussion
I got fed up with all the self build magazines pretty quickly. Stuffed full of ads and promotion, as J says. Even the supposed case studies were often houses of architects or property developers seeking to promote their business and/or sell the house they had recently built. -
Solar VAT
vivienz replied to eandg's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
If they are installed as part of a solar PV system, then yes, is my understanding, -
Ugly MVHR vents
vivienz replied to vivienz's topic in Mechanical Ventilation with Heat Recovery (MVHR)
.......and a self builder. I can be very unrealistic about things not connected with the build? -
Ugly MVHR vents
OH doesn't mind looking at those. -
Ugly MVHR vents
I did consider that but they are still nowhere near flush. I've got my eye on the concave ones, which is what I should have had in the first place but got what I was given. -
Ugly MVHR vents
Sorry, Declan, but we've been in for 7 weeks and I still hate them. I do agree with @epsilonGreedy that it's the protrusion that troubles me, along with the shine against my flat matt white ceilings. The link that posted from an earlier thread looks promising. @AnonymousBosch I didn't say I wanted pretty, just less ugly. I'm a realist with things like this and have learned to manage my expectations. -
My MVHR vents are utilitarian at best, ugly at worst. Does anyone know of a source of less unattractive ones? For preference, I'm after something with a less shiny finish and more flush. Picture of the offending items attached.
