BadgerBodger
    1
Everything posted by BadgerBodger
  1. Quality was fine barring one section of gutter which was a different gauge but marked as the same (maybe old/new stock). Sent off to almumasc for takeoff and did my own based on install guide. We came out roughly the same. I dropped a few things, added others. colour is black.
  2. These are the best I have to hand. The Dow pipes weren’t installed as I’d just struck the scaffold. Laid to a nominal fall (1:100) Don’t mind the wonky roof. We straightened it up as much as we could but it runs out by 150+ mm. The photo was just after a heavy summer downpour which is why the gutter was full.
  3. Encapsulation is an acceptable strategy so long as there is an adequate record maintained of its location, encapsulation, asbestos type etc. This record would then need disclosing to any future buyers etc. Read up on it, and make your own discussion. This came up a couple of months ago and the general consensus was that work falling outside NNLW was pretty affordable and discharging the ongoing risk/responsibility was worth the squeeze. Just one note, if the asbestos tiles were bonded with bitumen there is a good chance that if tested, that bitumen would test positive for chrysotile too. It was also bound within the bitumen around that time too.
  4. Depends on the size of the crack and potentially, what its cause is. When did it crack? During curing? After? What it when it was loaded. When did you load it after pouring? What was loaded? What were the weather conditions when you poured… yadayadayada the list goes on but each cause may require a different action for “satisfactory” rectification. Different structures actually have different permissible crack widths, it’s expected to some extent and designing out cracking can result in some hefty tonnages of steel (structure dependent). The problem is, in my experience, most repairs for cracks are fairly destructive involving injection, raking out and in some cases simply recasting. If they really are minor, you already have a decorative finish and it’s not a water retaining structure, I’d leave it. .
  5. I just got alumasc heritage 125 wide (not deep) about 60m gutter and 30m downpipe -6200 plus and other bits a d bobs which cost about-30 Through local BM better rate than online.
  6. Precast stairs are not a good option for much other than a straight flight or a stair core. they are HEAVY ( think a flight of 12 steps was 1.4t on my last job and if had flights with half landings weighing up to 3t before) and unless within a dedicated structure (like a precast stair core) they require a lot of engineeering consideration. they certainly ain’t gonna give the impression of anything floating. cast in situ however… but both would need a lot of engineering.
  7. Fosroc for the dry shake I’ll dig into the spec for the actual product and I usually see the Adocure products for the curing agent/sealer. I know the dry shake we had last time was on special order from France. So maybe not that one!
  8. So I’ve overseen a reasonable amount of power floated floor finishes and @-rick- has it figured. We use dry shake and a curing agent/sealer. We don’t protect the floors after and build entire power plants atop. There is some damage but not a huge amount considering we drive 120t cranes and 185ft cherry picker on it for 18 months. If I were doing it in my house (which i likely wouldn’t because of my partners taste but also it’s an f*ing hard surface with no texture underfoot) I’d do as above and use some proplex 3mm. OSB at a stretch. But it is repairable and there are a plethora of products to do so. Commercial concrete floor layers are definately your best bet. Probably think weekends.
  9. I’ll report back next weekend when I’ve used it for lathing the roof. I figured I needed to use 90mm ring shanks for internal caressing to power won over anything else.
  10. Funny question. I was weighing this up last night and ended up buying the 360xi so far as I could tell, there really wasn’t much in it. I think the 360xi has the premium gubbins (power, operational capacity at lower temps) and ties you to a lesser choice of 3rd party fuel cells but the 350 is (marginally) more expensive with a choice of cheaper aftermarket fixings. that was my fast take because I lost patience and didn’t want to waste any more time deliberating.
  11. If you got a spec from a landscape architect it could be as much as 200mm topsoils and a minimum 300mm suitable subsoil. I’ve had success with 100mm topsoil on poor quality subsoil. Bear in mind topsoils comes in variable qualities too. Typical commercial topsoil tends to be sandy loam which is blended but you also have low fertility topsoils which are more suited for wildflower meadow seed mixes - this however I’ve had good success with growing on just about anything even straight onto subsoil.
  12. I‘m just starting to look at installing PV and my installer is proposing the attached in roof „tray“ which seems to address quite a few of the issues being discussed here re fire but also ventilation and weatherproofing. What are people’s thoughts? SUNFIXINGS In Roof Datasheet V032021_ENG.pdf
  13. My general experience with building control is that they are as “hands off” as they need to be/feel they can be. If you don’t give them confidence they (rightly) weigh in on things. Maybe I’ve been lucky but I think if you are using and engineer and an architect with detail drawings they have a tendency to be a bit more relaxed. I’ve gone private because I was warned by one of my designers that the local LBA was struggling and engagement was not necessarily prompt or forthcoming.
  14. Lincolnshire. Day rate - labour only. From found to wall plate inc two external gables and one internal. 101m2 external 150mm cavity wall. Brick/block with English garden wall bond externally. 45m2 internal block some 140mm and some 100mm. All “technicians” work I.e tray, taped insulation, stays etc. insulated block and beam with reinforced slab atop. couple of days left but currently sitting at 13k and forecasting to finish under 18k
  15. IMHO you should definately have used barrier pipe.
  16. Howdens brokers I had a reasonable quote from them for various individual aspects
  17. Have you considered a designed solution, technically this is temporary works and should be considered by an appropriately qualified engineer based on ground residual ground bearing pressure of the outriggers and the bearing capacity of the substrate… if not at the very least, go with the crane suppliers advice. And, if you know you have „bad ground”, throw some geo grid and terram down under the stone for good measure, it will help act a a separation membrane when you’re digging it back up later. the last thing you want is a crane going over!
  18. To throw into the mix. What is the verdict on resin stone baths in people’s experiences?
  19. 5.95 offer received in last fortnight. Took roughly 6 months to pull together doing my own BOQ and pricing.
  20. This puts my quote for 2500 from Yorkshire water into perspective. They only lay 2m onto the property though. Annoying considering I put 575m pipe down the lane for less than 1800
  21. Also I see a shed load of “computer says” with engineers on site… a misinterpreted point or an incorrect layer on a complex drawing can be an extremely costly mistake… It’s like using Chat GPT, the technology is great so long as you A. Know how to use it and B know enough about it/what you are doing to interrogate the output. Amazingly, many lack skills in A, B or both!
  22. I’m reading your other thread and thought I’d throw my two cents in… Perhaps I’m a little more prone to taking risks but if the overall upstand size still fits (I.e the rooflight can still be installed over it), the upstand is at least 150mm on all sides from top of the flat area of zinc and the workmanship of the weld detailing is acceptable (you’d have to make the call on that or get a consultant to comment) and velux haven’t explicitly stated that it can’t be installed over multiple layers of zinc, I’d be inclined to install anyway… If you are still unhappy, the zinc layering means the rooflight doesn’t fit or the upstand is too short, have you considered extending the upstand with solid timber and/or cutting back the zinc in the bracketed areas using a colour match GRP to dress in the detailing. Yes it might not quite give the aesthetic you want but many GRP specialists warrant their work for 20+ years. In industrial roofing with Kalzip (a similar albeit not the same product) this is a typical detailing solution for unplanned or overlooked penetrations. I’m sure if you spoke with the roofing manufacturer and velux technical teams a simple enough solution is in front of you. As much as we would all like it to be, building on site is not always a precise science and one has to be dynamic and pragmatic about things like residual risk in situations such as this. The main problem is that for the most part, most people only think about THEIR job and not how it interlinks, impacts or even obstructs a subsequent task. In fairness I am often frustrated by this but I have to remind myself that it is not their role. Adding to this frustration, the architect does not include explicit instruction and provides “typical” details which overlook the most complicated scenarios (in your case, where the materials overlap). There are many reasons for this which often includes an inability to half the issue in their minds eye and permissible dimensional and installation tolerance in accordance with the British Standards. Adding to this confusion are the manufacturers guidance notes which in many cases are only available by request and are more restrictive than the British Standards which architects specify to. As others have said, don’t beat yourself up about this, it’s a typical conundrum, but it’s also a situation which would be “overcome” by a site or project manager by opening dialogue with all the relevant parties albeit sometimes circumventing a difficult contractor and just telling them what the solution was.
  23. Glysophate sounds like the solution here. Maintain that scorched earth look like a champ.
  24. For building regs you normally need ties 225mm from wall opening jambs at 450mm vertical centres (I think). More than likely an issue…
  25. I found that once I got most of the bigger players discussed here down to the same spec and scope there were much of a muchness for the material cost +\- 10% or so. It was the fitting that varied the most and I just want entirely sure with some that I wouldn’t get more costs down the line. In some cases fitting wasn’t offered. Installation, surveying and delivery varied the most being between 40 and 60% of the material cost. We went to VELFAC, Nordan, Norrsken, Rational, internorm & 21 degrees. Or relevant rep installers. Some were just plain difficult to deal with and went off the list. We’ve needed up with Norrsken based upon reading here and elsewhere. Would have like Nordan (used before) but they didn’t offer fitting. Being honest the Norrsken windows are the only ones we haven’t seen but in reality IMHO they were very similar with the main leading difference being the larger the frame size, the more “solid” they felt. I wasn’t so keen on the Belgae ironmongery (too spindly) and it was the flimsier feeling of them all. The only exception being the internorm lift and slide which was truly magnificent!
