nod
    72
Everything posted by nod
  1. [Edited by mods - please keep it civil] The clue is in Timber frame kits
  2. Not ours My wife would kill me if I spent 90 k on a door
  3. My point is That the TF is more expensive There not going to let you muck in Even if you don’t work 9-5
  4. Hope my new front door doest bust our budget
  5. We looked into a TF kit for our second build Foundation and drainage the same Up to watertight was coming out more than a third With a massive upfront payment There after the same Convenient BUT Your obviously going to pay for that
  6. Building TF will cost you more than building traditional But TF is quicker and more convenient
  7. I’ve found that being ready to pull the trigger is your best bet Have your finances ready We were the third highest offer on our previous plot But in a better position
  8. The heating hasn’t caused those cracks
  9. Simply run the fall towards the house With an acor agaist the house I’ve done lots like this Taking the water straight down the drain is a better option than flooding the lawn
  10. It’s works the same all the way round Just lift the dpc up 20 minutes to roll the dpc out Belt and braces
  11. you need to put 600 mil dpc around the perimeter and sleeper walls prior to the block and beam going down Once the blocks are all in lift the dpc up and set your first blocks for the internal block work on top Effectively wrapping the beams Then your high load dpc goes on the top of the first row that you have just laid
  12. I’ve installed two Matrix on our last two builds and about to install another in the next two weeks under 3k and super easy to install
  13. Most of the new house builders are moving away from the lightweight blocks and back to solid concrete blocks Theres no strength till there is weight on and prone to blowing over Another issue is they get knocked about by the fall protection when the joiners are putting the chambers in Brickies having to rebuild the internal walls on most properties Your dilemma is Do you risk strengthening the mortar and risk cracking the blocks If you add a waterproofer to your mix It will at least hold it back and give it time to grab Also measure your mixes in buckets Your probably a bit weaker than 5-1
  14. As above 200 + 75 A self builder thing is getting hung up on bumps and hollows on the BB The insulation that you put dow won’t lay flat Till you dump 20 tones of sand and cement on it 😂
  15. Yes there shouldn’t be any vat on a new build But some small companies won’t budge and the HMRC will ask you to claim it back off them If they spot it
  16. Rachel’ from accounts is the main culprit
  17. It madness at the moment I’ve Treatment plant to fit for the neighbors The local company I’ve used to supply TPs have gone into liquidation Its a shit show out there at the moment Ive been in the building game for over 40 years and it’s the I’ve seen it for companies going bust Lots of business and lots of cash flow problems
  18. The final sap really means nothing As it relies on you being truthful If buyers where bothered over a sap rating Builders would simply say they had upgraded everything Our U values for windows where taken from estimates supplied They had no way of knowing if I had installed these Or put the bare minimum of installation I questioned why MVRH would lower my sap rating and was told that opening a window was far more economic Sap is a outdated box ticking exercise at best and needs to be scrapped
  19. Surely you have already got a road in for concrete lorries etc Should be first job
  20. Neither Hire four steel plates
  21. You simply cut the top of the leg off If it’s in the way
  22. We once had a steel bath No long soaks Water quickly cooled 🧊
  23. It’s probably been pointed out above It’s unlikely that any will pay out for anything other than subsidence and they will chase you as the builder before they take any liability We used Protec for our first build Inspected the foundations from his car To muddy Forget his Wellies The roof inspection was done from the ground Though he did say I’d done a cracking job😁 Final inspection was done from our hallway No walk round As with the previous inspections 10 minutes Job done They rely on BC doing there job before they get there
  24. We use them quite often Usually housing associations as part of the soundproofing Simple system
